Playfield/ score help
rem variables used up so far
rem a,b,c,g,h,p
opening
playfield:
XXXX.XXXX.XXXXXX.XXXXXX.XX..XX..
X..X.X..X...XX.....XX...XX..XX..
XXXX.X..X...XX.....XX.....XX....
X....X..X...XX.....XX.....XX....
X....XXXX...XX.....XX.....XX....
...X...X.XX..XX.XX...X..XXXXXX..
...X...X.XX..XX.XXX..X....XX....
...XXXXX.XX..XX.X.XX.X....XX....
...X...X.XX..XX.X..XXX....XX....
...X...X.XXXXXX.X...XX....XX....
end
dim p0_x = b
dim p0_y = c
dim p1_x = g
dim p1_y = h
rem Loop the screen until the spacebar is pressed
title
COLUBK = rand
drawscreen
if joy0fire || joy1fire then goto skiptitle
goto title
rem This function displays after the title is skipped
skiptitle
COLUPF = rand
COLUBK = 212
player0x = 50 : player0y = 75
player1x = 20 : player1y = 20
score = 5 : scorecolor = 0
missile0height=4:missile0y=255
NUSIZ0 = 16
a = 5
rem Create the playfield
playfield:
.XX.....X...XX..XX..............
..........................X.....
.......X.....X....X.......X.....
.......X........................
.X.................X............
.........................XXXX...
....X......X.....X..............
...X.X..X..X........X...X.....X.
end
goto main
skiptitle2
COLUPF = 45
COLUBK = 212
player0x = 80 : player0y = 75
playfield:
.......................XXXXX....
..................X.............
..XXXXXXX.X.XX.XX.X..XXXXX......
..XX.....XX.......X.............
end
drawscreen
goto main2
 main
if score > 6 then goto skiptitle2
main2
Whats the best way to change playfields? I can get it to change from the title, but I want it to change when a certain score is reached. I was hoping to have atleast 10 seperate levels. I have code under the main2 that handle collision detection point sound, boundries ect. But I cant seem to get the level to change after the intro screen? thanks for any help you can give
