bomberpunk Posted November 6, 2011 Share Posted November 6, 2011 it will only work with the play & charge cable plugged in. once the light goes green, i should be able to unplug it and still use it but it immediately dies. brand new AAs in the battery shell don't work anymore either. is this a common thing that happens over time? is there a fix? it's the Limited Edition green (Halo 2?) controller if that makes a difference... Quote Link to comment Share on other sites More sharing options...
bomberpunk Posted November 20, 2011 Author Share Posted November 20, 2011 (edited) i (finally) bought a second 360 controller after owning the system since somewhere in 2008. i thought that since the Play & Charge worked flawlessly, then it must be the shell for the AA batteries that is faulty. i tested the brand new AA battery shell (with brand new AAs) in my problematic controller. it connected, although the green light was very faint. as soon as i touched a key on the chatpad, the chatpad lit up like it was supposed to and the controller immediately died. so then i thought it was the chatpad causing the problems. i disconnected that and again tried connecting my old controller (with the new AA shell). instead of the player 1 light coming on, all four lights came on dimly for a split second and went off. i tried this repeatedly. same result. i hooked up the Play & Charge up once more to make sure the controller wasn't now completely dead. it STILL works flawlessly with and without the chatpad. it's definitely the controller. then i tried removing the outer-casing of the new black controller to swap it out for my old green one, but even my precision tool set won't turn the screws. ah well. i can still use the old one as a wired controller. so eff it. Edited November 20, 2011 by bomberpunk Quote Link to comment Share on other sites More sharing options...
Austin Posted November 20, 2011 Share Posted November 20, 2011 The same thing happened to my stock controller that came bundled with my Slim unit (about a year old now). I bought another play 'n charge kit thinking that the battery pack was simply dead (it was an old model from '06 or so), but a new kit didn't help much. I think there may be a general defect in some of these controllers. At least I can still use it with the charge cable hooked up, but it's not ideal. Quote Link to comment Share on other sites More sharing options...
bomberpunk Posted November 21, 2011 Author Share Posted November 21, 2011 yeah it makes absolutely no sense how only a constant USB connection is the only way they will work. it's almost as if the normal voltage or current is no longer enough to power them. i'm no electronics expert, but perhaps by sucking power from the console gives it a little more juice than usual to make it work properly. **shrugs*** Quote Link to comment Share on other sites More sharing options...
Video Posted November 23, 2011 Share Posted November 23, 2011 Could be the radio transceiver thing in the controller has died....that would stop it from working, unless it was plugged in....but I thought plugging it in only powered it, not was a com cable as well. I would expect it to last at least as long as the system is expected to though. Quote Link to comment Share on other sites More sharing options...
