+SvOlli Posted November 11, 2011 Share Posted November 11, 2011 Hello, I'm trying to get my Harmony up and running on a PAL system with a 2600jr and a 7800. On both, it just won't start: - on the 2600jr, it has the same effect as no cartridge at all - on the 7800, I get a green/grey-ish screen and some noise out of the speakers, that's all I tried it with both, the current firmware eeloader_104e_PAL50.bin + hbios_105_PAL50.bin as well as flashing Adventure (PAL) in development mode. Flashing went fine, but "nothing" happens when I plug the cart in any of these two consoles, which work fine with any other module I have here. Is it broken, or is there anything else I can try? Greetings from Germany, SvOlli Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 11, 2011 Share Posted November 11, 2011 Does it work in normal mode from SD cart? Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted November 11, 2011 Author Share Posted November 11, 2011 Does it work in normal mode from SD cart? No, as I stated, I tried both, the normal SD card mode using the BIOS update, as well as development mode with Adventure. In both cases the result is the same. Quote Link to comment Share on other sites More sharing options...
+batari Posted November 12, 2011 Share Posted November 12, 2011 Are you using a clone or original console? If using an original console, there are a few possibilities. Sometimes the fit is tight so make sure it's inserted all the way. Also, make sure the cart edge is clean - I test all and clean off solder flux but I may gave missed some. A bit of isopropyl alcohol rubbed on the card edge will usually fix it, or a pencil eraser. If none of that works, we'll do an exchange and I'll examine your cart for a post-mortem. Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted November 12, 2011 Author Share Posted November 12, 2011 Thanks for the help, Thomas (forgot this one in the first reply) and batari. I tried the harmony on an original Atari 2600jr and an original Atari 7800, both modded with composite output, since I've got no TV anymore. The 2600jr was the first try. When it didn't work there, I got my 7800 modded as well to make sure that it isn't just a fitting problem. I cleaned the connector, but the problems are still there. Quote Link to comment Share on other sites More sharing options...
Amstari Posted November 15, 2011 Share Posted November 15, 2011 Did the Harmony cart work before and it has stopped working? Or hasn't it ever worked? You can try the NTSC firmware, it will still work on a PAL console. Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted November 15, 2011 Author Share Posted November 15, 2011 Did the Harmony cart work before and it has stopped working? Or hasn't it ever worked? It never worked inside an Atari, neither 2600jr nor 7800. Only flashing via PC is working. Quote Link to comment Share on other sites More sharing options...
