New project videogame HOUSE GHOST to be adjusted
agsoftware
Hello Dears Members of the TI99/4A,
I have a problem to solve: below is a new source of a video game in EXTENDED BASIC, but there is an error at line 1760 and gives me a SYNTAX ERROR IN 1760, and I unfortunately can not fix yet on why TI99 / 4A, I have very little experience, since I am only an expert in systems programming on MSX. So I ask your kind help to correct the line 1760.
Then a second thing: I wish this game should work well with both the joystick and the keyboard simultaneously, and the character to 1UP
must use the space bar to jump and not the key A.
On this game I found only 3 buttons to play: P Q left right and A to jump, to go up and down using the stairs, I could not, I hope
you can understand how it works!
We say that this game by the name of GHOST HOUSE, it's not my project, but I would change to improve it, because I alone make such a project from scratch, I just can not, because of my lack of esperieza TI99/4A.
I look forward to your positive response.
Best Regards
Andrea Gasparrini from Italy
1760 ACCEPT AT(F+7,22)VALIDATE(UALPHA)BEEPSIZE(1):KI$ :: QK$=QK$&KI$ :: NEXT F :: QK$=QK$&"2" :: GOTO 1610
HOUSE GHOST in EXTENDED BASIC for TI99/4A
100 CALL CLEAR :: B$="BONUS  " :: C$="PUNTI    " :: D$=" LA SAGA CONTINUA" :: T$="MASS.PUNT."
110 DIM HF$(5),OR$(12),LL$(3),LV(3,3),KY$(3),J(1),KE(4) :: QK$="ALZQP2" :: AB=91 :: NI$="					   "
120 RESTORE 1970 :: FOR F=1 TO 4 :: READ Q$,Q :: NEXT F :: CALL CHAR(136,Q$) :: FOR F=1 TO 5 :: HF$(F)="MDW 999" :: NEXT F
125 CALL COLOR(0,2,2) :: RESTORE 1790 :: FOR F=1 TO 18 :: READ Q,Q$ :: CALL CHAR(Q,Q$) :: NEXT F
130 GOSUB 1560 :: LF=23 :: SC=0
140 KT,KL=0 :: T=1 :: XI=57 :: KTS=1 :: V=1 :: Y2=128 :: J(1)=12 :: J(0)=10
150 CALL MAGNIFY(3) :: CALL DELSPRITE(ALL) :: CALL COLOR(2,3,2) :: GH=J(INT((1-0+1)*RND)+0)
160 LV(1,1)=121 :: LV(2,1)=73 :: LV(3,1)=25 :: LV(1,2)=121 :: LV(2,2)=121 :: LV(3,2)=73 :: LV(1,3)=1 :: LV(2,3)=1 :: LV(3,3)=2
170 RESTORE 1930 :: FOR F=1 TO 12 :: READ OR$(F) :: NEXT F :: RESTORE 1940 :: FOR F=1 TO 4 :: READ KE(F) :: NEXT F
175 RANDOMIZE :: CM=INT(3*RND)+1
180 CALL DELSPRITE(ALL) :: CALL CLEAR :: CALL SCREEN(3) :: CALL VCHAR(1,1,47,72) :: CALL VCHAR(1,30,47,72) :: CALL HCHAR(20,1,47,32)
190 CALL COLOR(12,11,2,1,14,2) :: XI=25 :: FOR F=21 TO LF-1 :: CALL SPRITE(#F,124,12,170,XI) :: XI=XI+16 :: NEXT F
200 DISPLAY AT(21,10)SIZE(18):C$;SC :: DISPLAY AT(23,10)SIZE(18):T$&SEG$(HF$(1),4,7)
210 ON T GOSUB 1200,1230,1260,1290,1320,1350,1380,1410,1440,1470,1500,1530
220 U=33 :: FOR F=6 TO 18 STEP 6 :: CALL HCHAR(F,4,U,26) :: FOR G=F-3 TO F-1 :: CALL HCHAR(G,4,46,26) :: NEXT G :: U=U+1 :: NEXT F
230 READ E :: FOR F=1 TO E :: READ U,X,Y,RP :: IF U<>1 THEN 250
240 FOR G=X-3 TO X :: CALL HCHAR(G,Y,32,RP) :: NEXT G
250 IF U<>2 THEN 270
260 CALL VCHAR(X,Y,37,RP) :: IF X=1 THEN 270 :: CALL VCHAR(X-2,Y,46,2)
270 NEXT F
280 CALL SPRITE(#1,124,12,LV(V,1),Y2)
290 READ L1,L2,L3,L4,L5,L6,L7,L8,L9,L10,EX$
300 XS=3 :: FOR F=1 TO 3 :: IF SEG$(OR$(T),F,1)="*" THEN 320 ELSE READ XA,YA,LL$(F) :: CALL SPRITE(#XS,60,ASC(SEG$(OR$(T),F,1))-60,XA,YA)
310 XS=XS+1
320 NEXT F
330 IF KT<>2 THEN 340 ELSE CALL SPRITE(#5,140,3,168,208) :: GOTO 350
340 READ X6,Y6 :: IF T<>CM THEN 350 :: CALL SPRITE(#5,140,3,X6,Y6)
350 IF T<>12 THEN 360 ELSE IF GH<>12 THEN 360 :: YU=5 :: XU=13 :: XD=121 :: GOTO 380
360 IF T<>10 THEN G1=1 :: GOTO 440 ELSE IF GH<>10 THEN G1=1 :: GOTO 440
370 YU=23 :: XU=7 :: XD=72
380 CALL CHAR(40,RPT$("80",) :: CALL CHAR(132,"03050B1A0301031E1316170F06283000C060D0D8C081C2FCC0E0F0E0C0281800")
390 CALL CHAR(128,"03060B132381433F030707070E04041CC0A0D048C480C078C868E8F0C040406")
400 IF KTS>=8 THEN 420
410 FOR F=XU TO XU+4 :: CALL HCHAR(F,YU,40,6) :: NEXT F
420 CALL SPRITE(#10,131,10,XD,(YU+1)* :: SD=128 :: G1=0
430 G1=0
440 IF KTS>3 THEN OP=INT((4-1+1)*RND)+1 ELSE OP=KTS
450 RESTORE 1970 :: FOR F=1 TO OP :: READ Q$,VU :: NEXT F :: CALL CHAR(136,Q$)
460 CO=INT((14-3+1)*RND)+3 :: IF VU<>10 THEN 480
470 XT=LV(2*RND+1,1) :: YT=200*RND+20 :: CALL SPRITE(#6,136,CO,XT,YT) :: GOTO 490
480 FOR F=1 TO 3 :: CALL SPRITE(#5+F,136,INT((14-3+1)*RND)+3,LV(F,1),80,0,INT(((8--8+1)*RND)+-+1) :: NEXT F
490 FOR F=1 TO 12 STEP 4
500 CALL COINC(#1,#5+V,9,U) :: IF U=-1 THEN 1010
510 IF G1=1 THEN 520 :: SD=SD+4 :: CALL PATTERN(#10,SD) :: IF SD=132 THEN SD=124
520 CALL KEY(0,X1,L) :: IF L=0 THEN CALL MOTION(#1,0,0) :: IR=0 :: GOTO 500
530 ON POS(QK$,CHR$(X1),1)+1 GOTO 540,560,760,640,840,870,900
540 CALL MOTION(#1,0,0) :: CALL PATTERN(#1,124) :: IR=0
550 NEXT F :: GOTO 490
560 CALL PATTERN(#1,AB+2) :: FOR S=8000 TO 10000 STEP 1000 :: CALL SOUND(-160,S,4,S/2,5) :: CALL POSITION(#1,X2,Y2) :: CALL MOTION(#1,-8,IR)
570 IF Y2<25 OR Y2>220 AND IR<>0 THEN IR=0
575 CALL COINC(#1,#5+V,9,U) :: IF U=-1 THEN 1010 ELSE CALL COINC(#1,#5,9,U) :: IF U=-1 THEN GOSUB 1170
580 NEXT S
590 SS=S :: CALL PATTERN(#1,AB+6) :: CALL MOTION(#1,5,IR) :: FOR S=10000 TO 8000 STEP-1000
600 CALL SOUND(-260,S,4,S/2,5) :: CALL POSITION(#1,X2,Y2) :: IF Y2<30 OR Y2>225 THEN CALL MOTION(#1,5,0)
610 CALL COINC(#1,#5,3,U) :: IF U=-1 THEN GOSUB 1170 ELSE CALL COINC(#1,#5+V,9,U) :: IF U=-1 THEN 1010
620 NEXT S :: CALL MOTION(#1,0,0) :: CALL POSITION(#1,X2,Y2) :: CALL LOCATE(#1,LV(V,1),Y2) :: CALL GCHAR(LV(V,1)/7,Y2/7.3,U)
630 IF U=32 THEN 940 ELSE IR=0 :: GOTO 540
640 CALL COINC(#1,#5+V,9,U) :: IF U=-1 THEN 1040
650 SO=0 :: CALL COINC(#1,L1,L2,2,U) :: IF U=-1 THEN EX=L3 :: CA=L5 :: LE=L4 :: GOTO 680
660 CALL COINC(#1,L6,L7,2,U) :: IF U=-1 THEN EX=L8 :: LE=L9 :: CA=L10 :: GOTO 680
670 GOTO 540
680 CALL POSITION(#1,X2,Y2) :: FOR G=116 TO 120 STEP 4 :: CALL PATTERN(#1,G) :: CALL MOTION(#1,-6,0) :: SC=SC+20
690 DISPLAY AT(21,10)SIZE(18):C$;SC
700 CALL KEY(0,X1,L) :: IF L=0 THEN CALL MOTION(#1,0,0) :: GOTO 700
710 CALL COINC(#1,EX,Y2,5,U) :: IF U=-1 THEN 740
720 CALL COINC(#1,#5+V,9,U) :: IF U=-1 THEN 1010
730 NEXT G :: GOTO 680
740 CALL MOTION(#1,0,0) :: CALL LOCATE(#1,LV(LE,1),Y2) :: V=LE :: IF T<>CA THEN T=CA :: GOTO 180
750 GOTO 540
760 FOR S=3 TO 6 :: CALL COINC(#1,#S,2,U) :: IF U=-1 THEN 780
770 NEXT S :: GOTO 540
780 SS$=SEG$(OR$(T),V,1) :: IF SS$="C" THEN 540
790 IF SS$<>"?" AND KT<>2 THEN 540 ELSE TT=T :: VV=V :: T=ASC(SEG$(LL$(V),1,1))-95 :: V=ASC(SEG$(LL$(V),2,1))-95
800 BO=INT((5-1+1)*RND)+1*100 :: SC=SC+BO :: IF SS$="?" THEN 180
810 FOR P=1 TO 3 :: KY$(P)=SEG$(OR$(TT),P,1) :: NEXT P
820 KY$(VV)="?" :: OR$(TT)="" :: FOR P=1 TO 3 :: OR$(TT)=OR$(TT)&KY$(P) :: NEXT P :: KT=0
825 IF KTS>=5 THEN 830 :: RANDOMIZE :: CM=INT((KE(KTS)-1+1)*RND)+1 :: GOTO 180
830 RANDOMIZE :: CM=INT((12-1+1)*RND)-1 :: KT=0 :: GOTO 180
840 CALL POSITION(#1,X2,Y2)
845 IF Y2<30 THEN 990 ELSE CALL GCHAR(LV(V,1)/6.8,Y2/7.2,U) :: IF U=32 THEN 940 :: IR=-6 :: AB=91 :: CALL PATTERN(#1,AB+F)
850 CALL COINC(#1,#6,13,U) :: IF U=-1 THEN 1010
860 CALL MOTION(#1,0,-6) :: GOTO 550
870 CALL POSITION(#1,X2,Y2)
875 IF Y2>220 THEN 1000 :: CALL GCHAR(LV(V,1)/6.8,Y2/7.2,U) :: IF U=32 THEN 940 :: IR=6 :: AB=104 :: CALL PATTERN(#1,AB+F)
880 CALL COINC(#1,#6,13,U) :: IF U=-1 THEN 1010
890 CALL MOTION(#1,0,6) :: GOTO 550
900 IF KTS<3 THEN 540 :: CALL DISTANCE(#1,#10,DI) :: IF SQR(DI)>20 THEN 540 :: CALL DELSPRITE(ALL)
910 CALL CLEAR :: CALL SCREEN(2) :: CALL MAGNIFY(4) :: CALL SPRITE(#1,128,12,96,96,#10,124,14,96,128)
920 DISPLAY AT(20,6):"LIONEL MIO EROE!" :: DISPLAY AT(22,7):"YOU RESCUED ME" :: FOR F=1 TO 400 :: NEXT F :: CALL CLEAR
930 DISPLAY AT(20,6)$ :: FOR F=1 TO 300 :: NEXT F :: IF LF>=24 THEN 140 ELSE LF=LF+1 :: GOTO 140
940 CALL POSITION(#1,X2,Y2) :: CALL MOTION(#1,6,0) :: FOR S=900 TO 110 STEP-20 :: CALL SOUND(-160,S, :: CALL COINC(#1,LV(V,2),Y2,3,U)
950 IF U<>-1 THEN 980
960 CALL MOTION(#1,0,0) :: CALL LOCATE(#1,LV(V,2),Y2) :: IF V<>1 THEN V=V-1
970 CALL GCHAR(LV(V,1)/6.8,Y2/7.4,U) :: IF U<>32 OR U=37 THEN 1160 :: CALL MOTION(#1,6,0)
980 NEXT S
990 T=ASC(SEG$(EX$,1,1))-95 :: CALL DELSPRITE(ALL) :: Y2=225 :: GOTO 180
1000 T=ASC(SEG$(EX$,2,2))-95 :: CALL DELSPRITE(ALL) :: Y2=24 :: GOTO 180
1010 CALL MOTION(#1,0,0) :: IF VU=0 THEN 1040 ELSE CALL DELSPRITE(#6) :: CALL DELSPRITE(#5+V) :: BO=(INT((5-1+1)*RND)+1)*100
1020 GOSUB 1180
1030 CALL POSITION(#1,X1,Y1) :: CALL GCHAR(X1/7,Y1/7.4,U) :: IF U=32 THEN 940 ELSE 540
1040 IF LF=21 THEN 1070 ELSE CALL DELSPRITE(ALL) :: LF=LF-1 :: KL=KL+16 :: XI=9+KL :: Y2=128
1050 CALL CLEAR :: CALL SCREEN(2) :: DISPLAY AT(10,6)$
1060 V=1 :: GOSUB 2010 :: GOTO 180
1070 DISPLAY AT(10,8)SIZE(16):"LA SAGA FINISCE" :: GOSUB 2010
1080 CALL DELSPRITE(ALL) :: CALL CLEAR :: FOR F=5 TO 1 STEP-1 :: IF VAL(SEG$(HF$(F),4,7))>SC THEN 1100
1090 NEXT F
1100 IF F=5 THEN 130 ELSE EG=F+1 :: GOSUB 1140 :: GOSUB 1700 :: DISPLAY AT((EG+3)*2,11):"   ";SC :: ACCEPT AT((EG+3)*2,11)SIZE(3)BEEP:N$
1110 S$=N$&" "&STR$(SC) :: FOR F=EG TO 5 :: S2$=S$ :: S$=HF$(F) :: HF$(F)=S2$ :: NEXT F :: GOSUB 1700 :: FOR F=1 TO 1000 :: CALL KEY(0,X1,L)
1120 IF L<>0 THEN 130
1130 NEXT F :: GOTO 100
1140 CALL CHAR(40,"0101010101050C1F0F00010101050D0DB0B0A080808000F0F830A08080808080") :: CALL MAGNIFY(4)
1150 CALL SPRITE(#1,40,12,30,25,0,0,#2,40,12,30,205,0,0,#3,40,12,145,25,0,0,#4,40,12,145,205) :: RETURN
1160 IF S<=300 THEN 1040 ELSE 540
1170 CALL MOTION(#1,0,0) :: KT=2 :: KTS=KTS+1 :: CALL LOCATE(#5,169,215) :: BO=T*(V*10)*10
1180 DISPLAY AT(1,11)SIZE(15)BEEP:B$;BO :: SC=SC+BO :: DISPLAY AT(21,10)SIZE(18):C$;SC :: FOR P=1 TO 200 :: NEXT P
1190 DISPLAY AT(1,11)SIZE(15):RPT$(" ",11) :: RETURN
1200 DATA 6,1,6,4,7,1,12,11,3,1,12,17,3,1,12,23,3,2,12,11,6,2,18,22,2,121,78,80,2,1,1,1,1,0,0
1210 DATA ab,25,200,cb,3,76
1220 RESTORE 1200 :: RETURN
1230 RESTORE 1240 :: RETURN
1240 DATA 5,1,6,10,3,1,6,14,15,1,12,11,3,1,12,16,3,2,6,10,6,73,68,32,3,2,1,1,1,0,0
1250 DATA b`,25,55,ga,3,92
1260 RESTORE 1270 :: RETURN
1270 DATA 6,1,6,16,4,1,12,9,3,1,12,15,3,1,12,24,3,1,12,19,3,2,6,16,12,121,116,32,3,3,1,1,1,0,0
1280 DATA `a,25,200,hb,50,208
1290 RESTORE 1300 :: RETURN
1300 DATA 6,1,6,10,2,1,6,14,3,1,6,19,2,1,12,10,12,2,1,22,5,2,12,10,6,25,164,3,1,1,121,68,80,2,4
1310 DATA de,25,200,x,50,160
1320 RESTORE 1330 :: RETURN
1330 DATA 4,1,6,7,20,1,12,4,20,2,6,7,12,2,18,22,2,121,44,32,3,5,1,1,1,0,0
1340 DATA ec,73,200,jb,3,200
1350 RESTORE 1360 :: RETURN
1360 DATA 3,1,6,9,2,1,12,20,3,2,6,12,6,73,84,32,3,6,1,1,1,0,0
1370 DATA cd,121,55,x,25,40,e`,53,56
1380 RESTORE 1390 :: RETURN
1390 DATA 5,1,12,15,3,1,12,20,2,1,12,23,6,2,6,14,6,2,18,22,2,73,100,32,3,7,1,1,1,0,0
1400 DATA gh,25,55,ia,60,164
1410 RESTORE 1420 :: RETURN
1420 DATA 3,1,6,10,12,2,1,22,5,2,6,10,6,73,68,32,3,8,25,164,3,1,5
1430 DATA hf,73,55,x,52,182
1440 RESTORE 1450 :: RETURN
1450 DATA 4,1,6,10,12,1,12,16,3,2,6,10,6,2,12,20,6,73,68,32,3,9,121,148,80,2,9
1460 DATA fg,121,200,k`,25,200,x,3,160
1470 RESTORE 1480 :: RETURN
1480 DATA 4,1,6,12,3,1,6,18,2,1,6,24,3,2,1,22,5,25,164,3,1,7,1,1,1,0,0
1490 DATA jk,73,55,x,3,196
1500 RESTORE 1510 :: RETURN
1510 DATA 4,1,6,10,12,1,12,12,8,2,6,22,6,2,12,11,6,73,164,32,3,11,121,76,80,2,11
1520 DATA ki,25,200,x,3,72
1530 RESTORE 1540 :: RETURN
1540 DATA 5,1,6,6,3,1,12,6,3,1,12,12,3,1,12,17,2,2,6,21,6,73,156,32,3,12,1,1,1,0,0
1550 DATA ij,121,200,x,3,32
1560 CALL CLEAR :: CALL SCREEN(2) :: FOR F=1 TO 9 :: CALL COLOR(F,16,2) :: NEXT F
1570 GOSUB 1140
1580 DISPLAY AT(5,10):"THE HOUSE" :: DISPLAY AT(8,13):"GHOST" :: DISPLAY AT(16,7):"				 " :: DISPLAY AT(18,13):"$    "
1590 DISPLAY AT(22,9):"PREMI UN TASTO" :: CALL SPRITE(#5,124,11,82,119)
1600 GOSUB 1950
1610 CALL DELSPRITE(#5)
1620 CALL CLEAR :: DISPLAY AT(1,:"THE HOUSE GHOST" :: DISPLAY AT(6,:"SCEGLI L'OPZIONE" :: RESTORE 1670
1630 S=1 :: FOR F=11 TO 15 STEP 2 :: READ S$ :: DISPLAY AT(F,6):S;"  ";S$ :: S=S+1 :: NEXT F
1640 DISPLAY AT(24,4):NI$
1650 GOSUB 1950
1660 ON POS("123",CHR$(X1),1)+1 GOTO 1650,1680,1730,1780
1670 DATA CLASSIFICA :,SCEGLI I TASTI,INIZIA IL GIOCO
1680 GOSUB 1700
1690 GOSUB 1950 :: GOTO 1610
1700 X=1 :: CALL SCREEN(2) :: CALL CLEAR :: DISPLAY AT(1,5):"SCORE RANK TABLE" :: FOR F=8 TO 16 STEP 2 :: DISPLAY AT(F,;HF$(X)
1710 X=X+1 :: NEXT F
1720 DISPLAY AT(22,7):C$;SC :: DISPLAY AT(24,4):NI$ :: RETURN
1730 CALL CLEAR :: DISPLAY AT(24,3):NI$
1740 DISPLAY AT(1,7):"CONTROLLO TASTI";QK$ :: QK$="" :: RESTORE 1770 :: DISPLAY AT(6,9):"SCEGLI IL TASTO PER"
1750 FOR F=1 TO 10 STEP 2 :: READ K$ :: DISPLAY AT(F+7,9):K$
1770 DATA SALTO,ENTRARE PORTA,SALIRE SCALE,MUOVI A SINISTRA,MUOVI A DESTRA
1780 RETURN
1790 DATA 35,FFABD5ABD5ABD5AB,33,DBA55A2418000000,34,FFC3A59999A5C381,36,7E81BDA1A1BD817E,37,81818181FF81818181
1800 DATA 60,0F12325252929292925252323212121FF0484C4A42495D4949424A4C4C4848F8
1810 DATA 47,FFFFFFFFFFFFFFFF
1820 DATA 92,03070207030103070706070303010103C0E0C0C0C080C06060E0E0C080808080
1830 DATA 96,0307020703010307060D0D010306070EC0E0C0C0C080C060E0F0F8C0C06060E0
1840 DATA 100,03070207030103070F1F1B0706161C0CC0E0C0C0C080C06070B8D8C0C0C060E0
1850 DATA 104,03070303030103060607070301010101C0E040E0C080C0E0E060E0C0808080C0
1860 DATA 108,0307030303010306070F1F0303060607C0E040E0C080C0E060B0B080C060E070
1870 DATA 112,03070303030103060E1D1B0303030607C0E040E0C080C0E0F0F8D8E060683830
1880 DATA 116,03071B1B1B191F1F0707030700000000C0E0C0C0C08098F8F8D8C0C0C0C0C0E0
1890 DATA 120,030703030301191F1F1B030303030307C0E0D8D8D898F8F8E0C0C0E000000000
1900 DATA 124,03070103020103070F1F1B030606060EC0E040C0C080C0E0F0F8D8C0C0C0C0E0
1910 DATA 46,0
1920 DATA 140,00000000000000000000000000000000001E12121E2040A08040000000000000
1930 DATA **D,**D,**D,**C,*D*,C*D,**D,*C*,D*C,*C*,**C,C**
1940 DATA 6,6,9,9
1950 FOR G=3 TO 15 :: FOR F=1 TO 4 :: CALL COLOR(#F,G) :: CALL KEY(0,X1,L) :: IF L<>0 THEN RETURN
1960 NEXT F :: NEXT G :: GOTO 1950
1970 DATA 030F1F1B3135313B3F1E1B1C1E3F77C0C0F0F0D88CAC8CDCFC78D83878FCEE03,0
1980 DATA 0106187789010101010101010101010080C0F0FC22000000000000000040C000,0
1990 DATA 000020130F0F1F7F1F1F0F0F13210100008084C8F030B8F8FEF8F0F0C8040000,0
2000 DATA 00060301030D1A163C3E3E341B0D0F0300B0E0C0A0F078F87CFCFC3CF8F0F0C0,10
2010 FOR F=5000 TO 110 STEP-210 :: CALL SOUND(-160,F,10) :: NEXT F :: RETURN
strangely, UALPHA variable is not valid...
try simply this :
10 UALPHA=5
RUN
it will give you SYNTAX ERROR also.
UALPHA is a reserved word in Extended BASIC as are all words that are statements, clauses, etc. See page 40 of the TI Extended BASIC manual for a complete list.
...lee
Edited by Lee Stewart
