phaeron Posted January 4, 2022 Share Posted January 4, 2022 Short update, as there was a request for a version with a updated TOC: Additional behavior info on Happy 1050 track buffering, including error handling. New appendix on tape format and decoding. HWMan-20220103.pdf 9 8 Quote Link to comment Share on other sites More sharing options...
ijor Posted July 4, 2022 Share Posted July 4, 2022 (edited) Hi Phaeron, Quote ANTIC supports a third type of NMI, triggered by the System Reset button on 400/800 models. On these models, the System Reset button asserts the /RNMI input on ANTIC, and once this is held for at least two consecutive leading edges of VBLANK, the Reset NMI is triggered. This is not accurate. I didn't actually test the hardware, but I assume you didn't either and you are just misinterpreting my schematics. I attached the relevant section of the schematics below, but added names for a couple of signals to help in the description. The second latch, named XRNMI_DELAY2, is inverted in relation to the first one named RNMI_DELAY. You can see that there are three inversions (one NOR and two inverters) between the first and the second latch. The logic actually works as an edge detector. Then Reset NMI is triggered when the RNMI pin was asserted at the start of the last vertical blank, but it wasn't at the start of the previous one. Edited July 4, 2022 by ijor Quote Link to comment Share on other sites More sharing options...
phaeron Posted July 4, 2022 Share Posted July 4, 2022 6 hours ago, ijor said: This is not accurate. I didn't actually test the hardware, but I assume you didn't either and you are just misinterpreting my schematics. I attached the relevant section of the schematics below, but added names for a couple of signals to help in the description. I tested it as far as verifying the timing of the Reset NMI interrupt relative to vblank, but wasn't able to verify the delay due to the inaccessibility of the 800's CPU board. I'll update the doc. Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 4, 2022 Share Posted July 4, 2022 Is this in aid of debounce or something? Quote Link to comment Share on other sites More sharing options...
ijor Posted July 4, 2022 Share Posted July 4, 2022 7 hours ago, Rybags said: Is this in aid of debounce or something? No, no debouncing here. It is just an edge detector and alignment with the vertical blank. Quote Link to comment Share on other sites More sharing options...
phaeron Posted July 7, 2022 Share Posted July 7, 2022 Minor refresh: Various corrections from readers. Expanded information on light pens, and quirks of the CX-75. ComputerEyes Video Acquisition System. 1050 rev. E firmware. HWMan-20220707.pdf 8 5 Quote Link to comment Share on other sites More sharing options...
FULS Posted July 8, 2022 Share Posted July 8, 2022 (edited) Thank you for the "ComputerEyes Video Acquisition System" addition. I love the graphics of the Atari. That's why I bought ComputerEyes when I was 24 in 1984. I took a vacation in Florida that year and bought some post card that I digitized with ComputerEyes. Click the link below and Load with Basic Enabled. Fuls Digitized Pictures Very interesting read, even though portions of it are over my head in my ever aging brain. Edited July 8, 2022 by FULS 3 Quote Link to comment Share on other sites More sharing options...
ijor Posted July 10, 2022 Share Posted July 10, 2022 On 7/4/2022 at 9:56 AM, Rybags said: Is this in aid of debounce or something? Wanted to post this the other day, but forgot. I answered without thinking before, sorry. Yes, by aligning the edge to the vertical blank, it does perform some kind of debouncing. Since the RNMI signal is sampled only at a single cycle per video frame, oscillations at the middle of the frame are completely ignored. 2 Quote Link to comment Share on other sites More sharing options...
phaeron Posted November 30, 2022 Share Posted November 30, 2022 Update: Disk drives Added info about XF551 firmware rev. 7.4 and 7.7 differences. Added US Doubler firmware information. POKEY More details on initialization mode. Expanded on many audio topics. Rotated around some of the noise generator patterns to canonically start from initialization state. Cycle-precise timer behavior, including STIMER and AUDF1-4 write timing. This is the special page of the update -- it's related to all of the weird POKEY timing stuff I've been doing in Altirra and Acid800. HWMan-20221129.pdf 11 11 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted December 1, 2022 Share Posted December 1, 2022 17 hours ago, phaeron said: POKEY More details on initialization mode. Expanded on many audio topics. Rotated around some of the noise generator patterns to canonically start from initialization state. Cycle-precise timer behavior, including STIMER and AUDF1-4 write timing. This is the special page of the update -- it's related to all of the weird POKEY timing stuff I've been doing in Altirra and Acid800. Hey @Synthpopalooza - just in case you're not following this thread already ... this is RIGHT up your POKEY-tastic alley. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 30 Share Posted May 30 Accessories Stack Lightpen. Cartridges SIDE 2: Added missing CF select bit. Serial I/O bus Fixed typo in protocol diagram that showed 10-18 ms for the ACK-to-data delay instead of 1.0-1.8 ms. 1030: Additional timing and dialing information. Disk drives Happy 1050: Detailed memory map and additional caching behavior. XF551: Added third firmware version between 7.4 and 7.7. Added 1450XLD parallel disk drive. Parallel Bus Interface MIO: Fixed description of $D1FE bit 4, which controls SEL and not MSG. MIO: Fixed inverted IRQ status bits. Added 1400XL/1450XLD V: and T: devices. HWMan-20230529.pdf 6 11 Quote Link to comment Share on other sites More sharing options...
+llabnip Posted May 30 Share Posted May 30 Avery - thanks for your continued effort to document the 8-bit hardware. I’ve found your reference to be to be the pinnacle of information on the system - even surpassing the venerable Mapping the Atari as my go-to guide. I don’t always understand everything (a reflection of the reader, not the writer)… but I feel smarter after having gone through it 🤓🤪😁 1 Quote Link to comment Share on other sites More sharing options...
Teapot Posted May 30 Share Posted May 30 Such an amazing document. So useful even though I've barely been through 20% of it so far. Here's a couple of things I noticed over the past few months. Right at the top of p.59 it states the NTSC dot clock is "12.2727Hz" which seems kinda slow. VSCROL Figure 3 is in the HSCROL section (p.68). In the current version the text describing it is on the next page along with a big gap of empty space (probably because of the next image). Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 30 Share Posted May 30 18 minutes ago, Teapot said: Right at the top of p.59 it states the NTSC dot clock is "12.2727Hz" which seems kinda slow. That's the NTSC dot clock for square pixels with interlaced video, not the dot clock that the NTSC Atari actually uses (7.16MHz non-interlaced). 18 minutes ago, Teapot said: VSCROL Figure 3 is in the HSCROL section (p.68). In the current version the text describing it is on the next page along with a big gap of empty space (probably because of the next image). LibreOffice Writer pagination problem during PDF export. It's a floating frame that the text should flow around and is fine in the editor, but got that gap on export for some reason. I've hit a lot of Writer bugs while working on this doc. The layout is always a bit suboptimal anyway because Writer doesn't have the frame positioning mode I actually want, which is page-relative on the next page. In a professional environment this would probably be handled by manual layout, but it's too much work to relayout all of the figures every time I make an edit. Quote Link to comment Share on other sites More sharing options...
Teapot Posted May 31 Share Posted May 31 5 hours ago, phaeron said: 5 hours ago, Teapot said: Right at the top of p.59 it states the NTSC dot clock is "12.2727Hz" which seems kinda slow. That's the NTSC dot clock for square pixels with interlaced video, not the dot clock that the NTSC Atari actually uses (7.16MHz non-interlaced). But is it Hz or MHz? 5 hours ago, phaeron said: LibreOffice Writer pagination problem during PDF export. It's a floating frame that the text should flow around and is fine in the editor, but got that gap on export for some reason. I've hit a lot of Writer bugs while working on this doc. I thought it might be something like that. I guess I was hoping there was a way to attach it more insistently to a paragraph. You're absolutely right not to fight against bugs like this. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 31 Share Posted May 31 25 minutes ago, Teapot said: But is it Hz or MHz? I have read that as MHz every time - in your original post, and phaeron's reply. I'm usually really god at spotting things like that too. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 31 Share Posted May 31 1 hour ago, Teapot said: But is it Hz or MHz? Ha, I'll fix that. 1 hour ago, Teapot said: I thought it might be something like that. I guess I was hoping there was a way to attach it more insistently to a paragraph. You're absolutely right not to fight against bugs like this. You can anchor to paragraph, but that's actually part of the problem -- because the frame itself takes up space before its own anchor. Which can cause a nice problem if the frame takes enough space to push its own anchor to the next page. It's also not really what I want anyway, because I want the diagram to appear after the text that introduces it, not before. (This isn't the XML standard, we introduce concepts before discussing them.) I took a look at the source document again and it looks like this is actually a consequence of the anchor not being far down enough: In this case, I'm cheating a little bit by anchoring it to the last paragraph in that section, but the layout engine had to push everything to the next page. Now, why the layout was different in the PDF export is another question, but in general this is the price of using auto layout in a word processor instead of manual layout in desktop publishing software. I do try to tweak things a bit when I can to make things look a bit more professional. Sometimes this requires awkward workarounds due to Writer limitations. For instance, Writer doesn't allow creating PDF bookmarks without inserting actual header text into the document -- which in the Reference section is done with tiny 2 pt. invisible text. The gradient on the front cover is also a stretched image because there was a visual issue with Writer's PDF export, it was doing something silly like posterizing the gradient to 6-bit and then tessellating the bands into geometric solid color shapes. But I digress. 1 Quote Link to comment Share on other sites More sharing options...
ClausB Posted May 31 Share Posted May 31 3 hours ago, Stephen said: I'm usually really god at spotting things like that too. Stephen, the proofreading god. 3 Quote Link to comment Share on other sites More sharing options...
Teapot Posted June 3 Share Posted June 3 I have some more: 8.1 Late hardware reset: One symptom that this can cause is a cartridge that fails to reliably run a software image configured a diagnostic cartridge to the OS Probably "configured as a diagnostic" 8.2 MaxFlash 8Mbit cartridge: Bank switching is performed by either read or write accesses to $D500-D5FF, where address bits 0-7 control the bank and bit 7 disables the cartridge when set. Probably "bits 0-6" Quote Link to comment Share on other sites More sharing options...
