moulinaie Posted December 20, 2011 Share Posted December 20, 2011 Hello, In order to add SPEECH to MLC, I need a bloc of 16 bytes free into the 16-bits ram located at >8300. (the famous "readit" routine) MLC runs under TI Extended Basic environment ! I only need this space during the execution of one instruction, then it will be free again. What zone should I use? Is it OK to use the GPL workspace between two GPL calls? Guillaume. Quote Link to comment Share on other sites More sharing options...
matthew180 Posted December 20, 2011 Share Posted December 20, 2011 How about the XB workspace at >83E0 ? R0 to R7 or R8 to R15 (or any 8 consecutive registers) represent 16-bytes of RAM... Look on page 404 of the E/A manual, particularly the areas from >8300 to >8349, >834A to >836D, and >836E to >836F. Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 20, 2011 Share Posted December 20, 2011 I'm using >8348 - but I don't know if it is compatible with XB. However, you don't need 16 bytes. You need 12 (including somewhere in 16 bit memory to hold the value read from the synth). >8348 movb @spchrd,@spdata ; read from speech synth >834e src r0,12 ; wait 12us (e/a page 349) >8350 rt >8352 spdata bss 2 This can be reduced to 6 bytes if you use indirect addressing. If you do it that way, you would load, say, R0 with the address of spchrd and then branch to the read routine in pad ram. This should work, as long as your register workspace is in pad ram. So, first (in 8 bit ram) li r0,spchrd ; address of speech synth read register (>9000) bl @readit Then in pad (16-bit) ram: readit >8348 movb *r0,r1 ; read from speech synth >834a src r0,12 ; wait 12us (e/a page 349) >834c rt Quote Link to comment Share on other sites More sharing options...
moulinaie Posted December 20, 2011 Author Share Posted December 20, 2011 I'm using >8348 - but I don't know if it is compatible with XB. However, you don't need 16 bytes. You need 12 (including somewhere in 16 bit memory to hold the value read from the synth). >8348 movb @spchrd,@spdata ; read from speech synth >834e src r0,12 ; wait 12us (e/a page 349) >8350 rt >8352 spdata bss 2 The problem is that my workspace register is in 8bits RAM! And if I use src r0,12, then it wil access the 8-bit ram, but this can't be done! I can't put my workspace in 16bits ram as my program collaborates with XB and there are very few bytes free... Guillaume. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted December 20, 2011 Author Share Posted December 20, 2011 How about the XB workspace at >83E0 ? R0 to R7 or R8 to R15 (or any 8 consecutive registers) represent 16-bytes of RAM... Look on page 404 of the E/A manual, particularly the areas from >8300 to >8349, >834A to >836D, and >836E to >836F. The fact is that I don't know if the XB expects to find back some values in its registers when returning. So I don't want to use some sensible bytes. I read the manual and it is not totally correct: Its says that >8300 to >830F is free, but it's wrong! When you use CALL LINK with parameters in XB, that's exactly where are stored the type of each argument in the parameter list. Guillaume. Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 20, 2011 Share Posted December 20, 2011 Sure you can! Just copy gpl workspace to RAM, use it, and restore it afterwards. Make sure interrupts are switched off though! Quote Link to comment Share on other sites More sharing options...
moulinaie Posted December 20, 2011 Author Share Posted December 20, 2011 Sure you can! Just copy gpl workspace to RAM, use it, and restore it afterwards. Make sure interrupts are switched off though! To speed up things, that was what I wanted to avoid: copy and restore. But if it's the only way... Guillaume. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 20, 2011 Share Posted December 20, 2011 The fact is that I don't know if the XB expects to find back some values in its registers when returning. So I don't want to use some sensible bytes. I read the manual and it is not totally correct: Its says that >8300 to >830F is free, but it's wrong! When you use CALL LINK with parameters in XB, that's exactly where are stored the type of each argument in the parameter list. Guillaume. The information you cited is for TI BASIC (TIB), not TI Extended BASIC (XB). On p. 418 of the E/A manual, you will see that XB's CALL LINK includes the area you indicated as unavailable in the area it uses at >8300 to >8315 for the same CALL LINK info that TIB uses at >8310 to >8312---apparently, XB needs 3 more bytes than TIB. I should think you could use the area for the FAC beginning at >834A as long as floating point routines are not currently executing. ...lee Quote Link to comment Share on other sites More sharing options...
moulinaie Posted December 20, 2011 Author Share Posted December 20, 2011 I should think you could use the area for the FAC beginning at >834A as long as floating point routines are not currently executing. ...lee Well, that's a good solution even without touching at FAC and ARG, there are two blocs of ten bytes left. I will try that... Thanks a lot to everyone for your help! Guillaume. Quote Link to comment Share on other sites More sharing options...
+RXB Posted December 21, 2011 Share Posted December 21, 2011 (edited) FAC continues into ARG in XB. i.e. 0125] *********************************************************** [0126] * Permanent workspace variables [0127] 8318 STRSP EQU >8318 String space begining [0128] 831A STREND EQU >831A String space ending [0129] 831C SREF EQU >831C Temporary string pointer 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0003 EQUATES EDIT-359 [0130] 831E SMTSRT EQU >831E Start of current statement [0131] 8320 VARW EQU >8320 Screen address [0132] 8322 ERRCOD EQU >8322 Return error code from ALC [0133] 8324 STVSPT EQU >8324 Value-stack base [0134] 832A VARA EQU >832A Ending display location [0135] 832C PGMPTR EQU >832C Program text pointer [0136] 832E EXTRAM EQU >832E Line number table pointer [0137] 8330 STLN EQU >8330 Start of line number table [0138] 8332 ENLN EQU >8332 End of line number table [0139] 8334 DATA EQU >8334 Data pointer for READ [0140] 8336 LNBUF EQU >8336 Line table pointer for READ [0141] 8338 INTRIN EQU >8338 Add of intrinsic poly constant [0142] 833A SUBTAB EQU >833A Subprogram symbol table [0143] 833C IOSTRT EQU >833C PAB list/Start of I/O chain [0144] 833E SYMTAB EQU >833E Symbol table pointer [0145] 8340 FREPTR EQU >8340 Free space pointer [0146] 8342 CHAT EQU >8342 Current charater/token [0147] 8343 BASE EQU >8343 OPTION BASE value [0148] 8344 PRGFLG EQU >8344 Program/imperative flag [0149] 8345 FLAG EQU >8345 General 8-bit flag [0150] 8346 BUFLEV EQU >8346 Crunch-buffer destruction leve [0151] 8348 LSUBP EQU >8348 Last subprogram block on stack [0152] * FAC EQU >834A Floating-point ACcurmulator [0153] 834B FAC1 EQU FAC+1 [0154] 834C FAC2 EQU FAC+2 [0155] 834D FAC3 EQU FAC+3 [0156] 834E FAC4 EQU FAC+4 [0157] 834F FAC5 EQU FAC+5 [0158] 8350 FAC6 EQU FAC+6 [0159] 8351 FAC7 EQU FAC+7 [0160] 8352 FAC8 EQU FAC+8 [0161] 8353 FAC9 EQU FAC+9 [0162] 8354 FAC10 EQU FAC+10 [0163] 8355 FAC11 EQU FAC+11 [0164] 8356 FAC12 EQU FAC+12 [0165] 8357 FAC13 EQU FAC+13 [0166] 8358 FAC14 EQU FAC+14 [0167] 8359 FAC15 EQU FAC+15 [0168] 835A FAC16 EQU FAC+16 [0169] 835B FAC17 EQU FAC+17 [0170] 834C AAA EQU FAC+2 [0171] 834E CCC EQU FAC+4 [0172] 8350 BBB EQU FAC+6 [0173] 834C DDD EQU FAC+2 [0174] 834E FFF EQU FAC+4 [0175] 8350 EEE EQU FAC+6 [0176] 8354 DDD1 EQU FAC+10 [0177] 8356 FFF1 EQU FAC+12 [0178] 8358 EEE1 EQU FAC+14 [0179] * ARG EQU >835C Floating-point ARGument [0180] 835D ARG1 EQU ARG+1 [0181] 835E ARG2 EQU ARG+2 [0182] 835F ARG3 EQU ARG+3 [0183] 8360 ARG4 EQU ARG+4 [0184] 8361 ARG5 EQU ARG+5 [0185] 8362 ARG6 EQU ARG+6 [0186] 8363 ARG7 EQU ARG+7 [0187] 8364 ARG8 EQU ARG+8 [0188] 8364 XSTLN EQU >8364 GKXB variable [0189] 8366 XENLN EQU >8366 GKXB variable [0190] 8367 ARG11 EQU ARG+11 [0191] 8368 XCURLI EQU >8368 GKXB variable [0192] 836A XCURIN EQU >836A GKXB variable [0193] 836B ARG15 EQU ARG+15 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0004 EQUATES EDIT-359 [0194] 836C ARG16 EQU ARG+16 [0195] * VSPTR EQU >836E Value stack pointer [0196] 8376 EXPZ EQU >8376 Exponent in floating-point [0197] 8384 RAMTOP EQU >8384 Highest address in ERAM [0198] 8386 RAMFRE EQU >8386 Free pointer in the ERAM [0199] 8388 RSTK EQU >8388 Subroutine stack base [0200] 8389 RAMFLG EQU >8389 ERAM flag [0201] 83AF STKMIN EQU >83AF Base of data stack [0202] 83BD STKMAX EQU >83BD Top of data stack [0203] 83CE PRTNFN EQU >83CE This is the EQU for source code of XB and FAC leading into ARG is never assumed to remain so you have 34 bytes avaliable all the time. Edited December 21, 2011 by RXB Quote Link to comment Share on other sites More sharing options...
marc.hull Posted December 23, 2011 Share Posted December 23, 2011 Hello, In order to add SPEECH to MLC, I need a bloc of 16 bytes free into the 16-bits ram located at >8300. (the famous "readit" routine) MLC runs under TI Extended Basic environment ! I only need this space during the execution of one instruction, then it will be free again. What zone should I use? Is it OK to use the GPL workspace between two GPL calls? Guillaume. Pardon my ignorance. Why does it have to be in scratch pad ? Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 23, 2011 Share Posted December 23, 2011 Pardon my ignorance. Why does it have to be in scratch pad ? Page 349 in the E/A-manual: During the delay after a read, the 8-bit peripheral bus which is connected to the Memory Expansion unit cannot be used. Therefore, the reads of data from the Speech Synthesizer and the delays must be in the area accessed by the 16-bit bus. Quote Link to comment Share on other sites More sharing options...
