Fuji-Man Posted February 7, 2021 Share Posted February 7, 2021 Please change FileName in csv export to have 8.3 instead of 83. Thanks. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted July 29, 2021 Author Share Posted July 29, 2021 ATRTools 030a.zip Build 30 - 07/29/2021 - Fixed: Removed HWND_BROADCAST From SendMessage() in AddFontResource. Shouldn't freeze anymore on startup, ran in to this bug recently on Windows 7... 3 3 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted July 29, 2021 Share Posted July 29, 2021 Fixed for me. thanks 1 Quote Link to comment Share on other sites More sharing options...
marcokitt2000 Posted July 30, 2021 Share Posted July 30, 2021 Great tool thnxxxx Gr. Marco Quote Link to comment Share on other sites More sharing options...
José Antonio Posted December 10, 2022 Share Posted December 10, 2022 Good morning, greetings from Colombia. I hope you can help me, I need to convert an ATX image to ATR and when I load the image in ATR Tools, the "Convert ATX to ATR" option appears gray and disabled in the ATX menu. Is it possible to do this conversion or is it a function not implemented? If possible, can you tell me how? Thanks Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted December 10, 2022 Author Share Posted December 10, 2022 2 minutes ago, José Antonio said: Good morning, greetings from Colombia. I hope you can help me, I need to convert an ATX image to ATR and when I load the image in ATR Tools, the "Convert ATX to ATR" option appears gray and disabled in the ATX menu. Is it possible to do this conversion or is it a function not implemented? If possible, can you tell me how? Thanks That's still in progress... Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted December 10, 2022 Share Posted December 10, 2022 Try it in Altirra's disk menu. Quote Link to comment Share on other sites More sharing options...
José Antonio Posted December 10, 2022 Share Posted December 10, 2022 18 minutes ago, AtariGeezer said: That's still in progress... OK Thanks Quote Link to comment Share on other sites More sharing options...
José Antonio Posted December 10, 2022 Share Posted December 10, 2022 12 minutes ago, DjayBee said: Try it in Altirra's disk menu. It was not possible Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted December 10, 2022 Share Posted December 10, 2022 I forgot about this. If you can run Perl-scripts, this will work for sure (atx.pl file.atx file.atr -copy=1-720): https://forums.atariage.com/topic/251304-repairing-modifying-atx-images/?do=findComment&comment=4425178 I use it all the time to batch-convert ATXs. If an image contains duplicates/phantoms, it takes the first instance found on the track. If you browse the linked thread, you should find more information on how to use the script. 1 Quote Link to comment Share on other sites More sharing options...
MVladimir Posted March 16, 2023 Share Posted March 16, 2023 (edited) I expect some problems with this tool under WIN10 22H2 64bit. No ATASCII characters in "View file" mode. (see attached pic.) Menu View -> Output -> ATASCII marked. Atari specific fonts installed. Under Win 7 32bit the same version (27f) is fine! I try the last available version - 30a - the same result - under W10 64 - no ATASCII, under W7 32 - all OK. How to fix? Or I do something wrong? And this from Win7 32b: Edited March 16, 2023 by MVladimir Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted March 16, 2023 Share Posted March 16, 2023 58 minutes ago, MVladimir said: I expect some problems with this tool under WIN10 22H2 64bit. No ATASCII characters in "View file" mode. (see attached pic.) It works fine in Win10 64 22H2. You need the font file in the directory you are starting it from. BUT: IIRC the font is contained in the EXE and is written to disk when you run ATRtools for the first time. Here is the font for you to try: atari.fon Quote Link to comment Share on other sites More sharing options...
MVladimir Posted March 16, 2023 Share Posted March 16, 2023 (edited) 36 minutes ago, DjayBee said: It works fine in Win10 64 22H2. You need the font file in the directory you are starting it from. BUT: IIRC the font is contained in the EXE and is written to disk when you run ATRtools for the first time. Here is the font for you to try: atari.fon 4.08 kB · 1 download This font file is on place.... anyway thanks for reminder. The problem is somewhere else... Edited March 16, 2023 by MVladimir Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 17, 2023 Author Share Posted March 17, 2023 16 hours ago, MVladimir said: I expect some problems with this tool under WIN10 22H2 64bit. No ATASCII characters in "View file" mode. (see attached pic.) Menu View -> Output -> ATASCII marked. Atari specific fonts installed. Under Win 7 32bit the same version (27f) is fine! I try the last available version - 30a - the same result - under W10 64 - no ATASCII, under W7 32 - all OK. How to fix? Or I do something wrong? And this from Win7 32b: What does it look like when you View as "Raw" ? Quote Link to comment Share on other sites More sharing options...
MVladimir Posted March 17, 2023 Share Posted March 17, 2023 23 minutes ago, AtariGeezer said: What does it look like when you View as "Raw" ? "View file as -> Binary" (hope you mean this as RAW?) and simple "View file" under right click on file menu, shows the same result, as you see on screenshot. Unfortunately..... Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 17, 2023 Author Share Posted March 17, 2023 45 minutes ago, MVladimir said: "View file as -> Binary" (hope you mean this as RAW?) and simple "View file" under right click on file menu, shows the same result, as you see on screenshot. Unfortunately..... Yep, that's what I meant. Have you tried running it with Administrator settings? Quote Link to comment Share on other sites More sharing options...
MVladimir Posted March 17, 2023 Share Posted March 17, 2023 6 minutes ago, AtariGeezer said: Yep, that's what I meant. Have you tried running it with Administrator settings? Yes. Same result. Quote Link to comment Share on other sites More sharing options...
