atarilovesyou Posted March 5, 2012 Share Posted March 5, 2012 Finally got some time to fire it up and...it won't even fit in the slot (that's what she said). Seriously though, it won't fit. The only way is to bypass the mechanism with two small screwdrivers, slide it back and pop it in. Definitely not something I'll want to do each time. My VCS is the older six switch but works with my other games, I think this shell must not have been QC'ed before shipment. Can somebody please PM me about shipping me a replacement please?...thanks. Quote Link to comment Share on other sites More sharing options...
bomberpunk Posted March 5, 2012 Share Posted March 5, 2012 send a PM to Albert. Quote Link to comment Share on other sites More sharing options...
atarilovesyou Posted March 5, 2012 Author Share Posted March 5, 2012 Can you please PM a link or something, I don't know who Albert is here...is he Batari? Quote Link to comment Share on other sites More sharing options...
bomberpunk Posted March 5, 2012 Share Posted March 5, 2012 Albert is Albert. Quote Link to comment Share on other sites More sharing options...
cd-w Posted March 5, 2012 Share Posted March 5, 2012 The circuit board has probably come loose inside the cartridge shell during shipping. It should be possible to realign it without too much difficulty. Chris Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 5, 2012 Share Posted March 5, 2012 The shell is a re-used cartridge, it's not something newly made. At some point Atari made a change in the cartridges that didn't play well with the sixers. difficult carts on your sixer? This might help Quote Link to comment Share on other sites More sharing options...
atarilovesyou Posted March 5, 2012 Author Share Posted March 5, 2012 The only carts that have had issues on my sixer is the later ones, like Midnight Magic. And the only issue there is a tighter fit; in this case, I think whatever it is that makes the protective plastic flap lift is loose. At any rate, I'm talking to Albert to see what's up. Quote Link to comment Share on other sites More sharing options...
+batari Posted March 5, 2012 Share Posted March 5, 2012 I'm the right person to contact about this. Some shells lead to tighter fits (this is due to differences in shells - particularly the screw mast, which is not relevant on most boards but is somewhat relevant in Harmony). On a Jr or 4-switch this rarely presents a problem because of the geometry of the cart slot (you can just wiggle the cart gently to get it in). However, on a 6-switch, the deep cart slot may lead to a tight fit and you can't wiggle it. To get it to fit in a 6-switch, you may need to apply gentle pressure to the USB plug with your finger so you can move the board a bit toward the label side of the cart. Do this while inserting and if you do it right, it go in easily. Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted March 6, 2012 Share Posted March 6, 2012 Do this while inserting and if you do it right, it go in easily. THAT'S WHAT SHE SAID!!!!! . . . . . Sorry.......can't help myself sometimes.......... Quote Link to comment Share on other sites More sharing options...
atarilovesyou Posted March 6, 2012 Author Share Posted March 6, 2012 I'm the right person to contact about this. Some shells lead to tighter fits (this is due to differences in shells - particularly the screw mast, which is not relevant on most boards but is somewhat relevant in Harmony). On a Jr or 4-switch this rarely presents a problem because of the geometry of the cart slot (you can just wiggle the cart gently to get it in). However, on a 6-switch, the deep cart slot may lead to a tight fit and you can't wiggle it. To get it to fit in a 6-switch, you may need to apply gentle pressure to the USB plug with your finger so you can move the board a bit toward the label side of the cart. Do this while inserting and if you do it right, it go in easily. I gotta say, if that's the only way to get it to work, I'll be returning it. It sure is a great piece of gear, though. If I intended to keep it in all the time maybe it wouldn't be an issue. What I might do is just send them a shell on a cart that I know fits in my VCS. The fit is not the issue, though...it's the plastic tabs. For some reason they won't allow the cart in. Quote Link to comment Share on other sites More sharing options...
+batari Posted March 6, 2012 Share Posted March 6, 2012 (edited) I'm the right person to contact about this. Some shells lead to tighter fits (this is due to differences in shells - particularly the screw mast, which is not relevant on most boards but is somewhat relevant in Harmony). On a Jr or 4-switch this rarely presents a problem because of the geometry of the cart slot (you can just wiggle the cart gently to get it in). However, on a 6-switch, the deep cart slot may lead to a tight fit and you can't wiggle it. To get it to fit in a 6-switch, you may need to apply gentle pressure to the USB plug with your finger so you can move the board a bit toward the label side of the cart. Do this while inserting and if you do it right, it go in easily. I gotta say, if that's the only way to get it to work, I'll be returning it. It sure is a great piece of gear, though. If I intended to keep it in all the time maybe it wouldn't be an issue. What I might do is just send them a shell on a cart that I know fits in my VCS. The fit is not the issue, though...it's the plastic tabs. For some reason they won't allow the cart in. A shell that seems to fit now doesn't necessarily mean the Harmony will fit right in that shell. The issue is that the Harmony board doesn't fit the same in all shells. The one you have may work for the board in it but not as well for Harmony. In some, the Harmony board fits a bit askew becuase it's larger than the regular PCB it replaced. As said, most fit fine and even when they are a little off, the cart may be wobbled a bit to get it in, but not with the heavy sixer. If you want to send it back, I will find one with a better fit in the next batch and send you one of those. Edited March 6, 2012 by batari 1 Quote Link to comment Share on other sites More sharing options...
atarilovesyou Posted March 7, 2012 Author Share Posted March 7, 2012 Can you please send me a PM regarding how to return the cart? I wish I knew that there were possible issues of having the cart fit in my six switch...perhaps something in a sticky? But if there's a chance it's going to have the same issue, I'd rather just remove the dust cover. Do you guys have a six switch to do a quick test?...I didn't realize this was much of an issue. Quote Link to comment Share on other sites More sharing options...
Jinks Posted March 18, 2012 Share Posted March 18, 2012 Do they fit in 7800s?? They are known to really tighten up on carts even with lube. Quote Link to comment Share on other sites More sharing options...
snstay Posted March 18, 2012 Share Posted March 18, 2012 Yes it fits in a 7800 just fine. Quote Link to comment Share on other sites More sharing options...
Mirage Posted March 18, 2012 Share Posted March 18, 2012 I had same issue on light sixer, I just don't remove it too often. Not ideal, but works. A couple times it's taken me like 5 minutes to get it in. Quote Link to comment Share on other sites More sharing options...
atarilovesyou Posted March 18, 2012 Author Share Posted March 18, 2012 The replacement is on its way, so perhaps in the future people can specify which type of 2600 they have so they can make sure they get a shell that fits. I thought for a while about just leaving it in all the time (and you could, why bother using real carts? It's THAT good!) but in the end I'd like it to fit properly. It's definitely a must-own product for any serious 2600 fan, no doubt! Quote Link to comment Share on other sites More sharing options...
