OX. Posted March 17, 2012 Share Posted March 17, 2012 The program attached "outland" seems to load using e/a option 3 but then needs a program name to start, I've no idea what the program is, I'm just curious to know, any ideas? OUTLAND.zip Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted March 18, 2012 Share Posted March 18, 2012 e/a option 3 DSK1.OUTLAND (no program name to start - simply don't start anything) return to master title screen (fctn quit) option 3 should be OUTLAND Quote Link to comment Share on other sites More sharing options...
Willsy Posted March 18, 2012 Share Posted March 18, 2012 That implies that it needs a super-cart (EA cart with 8k RAM installed in it) to run on real hardware. Basically, you need something with RAM at >6000 on the real hardware.... Quote Link to comment Share on other sites More sharing options...
OX. Posted March 18, 2012 Author Share Posted March 18, 2012 e/a option 3 DSK1.OUTLAND (no program name to start - simply don't start anything) return to master title screen (fctn quit) option 3 should be OUTLAND Excellent, thanks Sometimes! Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted March 18, 2012 Share Posted March 18, 2012 That implies that it needs a super-cart (EA cart with 8k RAM installed in it) to run on real hardware. Basically, you need something with RAM at >6000 on the real hardware.... Yep. I made a CPU memory dump with Classic99 (after loading with e/a option 3), cut out >6000->7FFF and put it in again as a cartridge, effectively turning the original RAM area into ROM, and ... Outland shows up fine, but apparently expect to find RAM in this area, so the cutout is a no go (as is). Quote Link to comment Share on other sites More sharing options...
