coleconut Posted April 24, 2012 Share Posted April 24, 2012 Might answer all my own questions but asking anyway... I thought it might be fun to translate a CV game into a different language. Using a hex editor, I easily found all the text strings and translated them, but couldnt find the skill level select screen. Assuming therefore that this is not a text screen but an image. So wondering why they did that, assume it takes less bytes than a text screen? And for someone with minimal programming skills what kind of challenge would I have replacing this screen with a different one. I have an MSX game with the proper translated screen but dont know where in either program this screen resides and if I did, if they had the same number of bytes. Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/ Share on other sites More sharing options...
youki Posted April 24, 2012 Share Posted April 24, 2012 Skill level select screen is in the coleco rom bios , not in the game rom. Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-2507679 Share on other sites More sharing options...
+nanochess Posted April 25, 2012 Share Posted April 25, 2012 Yep, pretty useful, only a handful of bytes to call ROM routine and save value. Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-2508681 Share on other sites More sharing options...
hardhat Posted April 25, 2012 Share Posted April 25, 2012 It even sets up all of the video registers and uploads the fonts. It is a pretty powerful OS7 entry point. It is called GAME_OPT in my Mayan guide to programming OS7, and is at 1f7ch, so look for: CALL 1f7ch somewhere in the game. Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-2508745 Share on other sites More sharing options...
+5-11under Posted April 25, 2012 Share Posted April 25, 2012 It even sets up all of the video registers and uploads the fonts. It is a pretty powerful OS7 entry point. It is called GAME_OPT in my Mayan guide to programming OS7, and is at 1f7ch, so look for: CALL 1f7ch somewhere in the game. So if there's extra ROM space, you could potentially copy the applicable BIOS code into your ROM and modify it as you wish. Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-2508749 Share on other sites More sharing options...
Zak Posted May 28, 2020 Share Posted May 28, 2020 hi, i'm using SDCC + col4k, how i can make the call to skill select screen from C ? or it configures in cart0.s ? tnks very much Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4549437 Share on other sites More sharing options...
digress Posted May 28, 2020 Share Posted May 28, 2020 The skill select screens were all programmed game by game. There is no built in routine. just print a similar screen using print_at routine and use keypad input to select the skill and use a variable something like : skill=1; if that keypad 1 is pressed. 7 hours ago, Zak said: hi, i'm using SDCC + col4k, how i can make the call to skill select screen from C ? or it configures in cart0.s ? tnks very much 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4549595 Share on other sites More sharing options...
+bhall408 Posted May 28, 2020 Share Posted May 28, 2020 1 hour ago, digress said: The skill select screens were all programmed game by game. There is no built in routine. Looking at manuals, it appears there is a routine GAME_OPT that will display that standard screen (and leave you in that graphics mode), but it is up to you to implement the code to check for the button press. Would have been nicer if that was also baked into the routine, and it just returned 1-8 for you! 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4549680 Share on other sites More sharing options...
Kiwi Posted May 28, 2020 Share Posted May 28, 2020 This is the skill select screen routine I recreated for Challenger. Both the BIOS and the Skill select were recreated since I didn't know how to call them and I already have a recreated BIOS screen in ICVGM due to Spunky's Supercar!. However, the font graphic was pulled from the BIOS. void SkillSelect(void){ disable_nmi();//necessory to avoid vram corruption put_vram(0x0100,(void*)0x15a3,512);//load font to pattern table starting at 0x0100 duplicate_pattern();//if you're using screen_mode_2_text(); this is required for 3 pattern/1 color table graphic mode. fill_vram(0x2000,0xF0,2048);//make every tile white with transparentry(for background color). paper(5);// set background/border to blue print_at(6,0,"TO SELECT GAME OPTION,"); print_at(6,2,"PRESS BUTTON ON KEYPAD."); print_at(6,5,"1 = SKILL 1/ONE PLAYER"); print_at(6,7,"2 = SKILL 2/ONE PLAYER"); print_at(6,9,"3 = SKILL 3/ONE PLAYER"); print_at(6,11,"4 = SKILL 4/ONE PLAYER"); enable_nmi();//all graphic write finished, turn on NMI so the controllers and sound will work. a=1; delay(5); while(a==1){ delay(1);//keeps loop running at 60 fps. if(keypad_1==1){livesstart=livesmax=5;nextoneup=nextadd=5;shieldmax=3;a=0;skill=1;speed=0;} if(keypad_1==2){livesstart=livesmax=3;nextoneup=nextadd=4;shieldmax=3;a=0;skill=2;speed=0;} if(keypad_1==3){livesstart=livesmax=5;nextoneup=nextadd=4;shieldmax=1;a=0;skill=3;speed=0;} if(keypad_1==4){livesstart=livesmax=3;nextoneup=nextadd=3;shieldmax=1;a=0;skill=4;speed=0;} } paper(0); cls(); screen_off(); } 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4550111 Share on other sites More sharing options...
Zak Posted May 30, 2020 Share Posted May 30, 2020 On 5/28/2020 at 10:36 AM, digress said: The skill select screens were all programmed game by game. There is no built in routine. just print a similar screen using print_at routine and use keypad input to select the skill and use a variable something like : skill=1; if that keypad 1 is pressed. but in asm exists a call that shows the skill selection screen. is: call 1f7ch . I search for same in C. @Kiwi gave me the solution, tnks anyway Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4551335 Share on other sites More sharing options...
Zak Posted May 30, 2020 Share Posted May 30, 2020 On 5/28/2020 at 7:35 PM, Kiwi said: This is the skill select screen routine I recreated for Challenger. Both the BIOS and the Skill select were recreated since I didn't know how to call them and I already have a recreated BIOS screen in ICVGM due to Spunky's Supercar!. However, the font graphic was pulled from the BIOS. void SkillSelect(void){ disable_nmi();//necessory to avoid vram corruption put_vram(0x0100,(void*)0x15a3,512);//load font to pattern table starting at 0x0100 duplicate_pattern();//if you're using screen_mode_2_text(); this is required for 3 pattern/1 color table graphic mode. fill_vram(0x2000,0xF0,2048);//make every tile white with transparentry(for background color). paper(5);// set background/border to blue print_at(6,0,"TO SELECT GAME OPTION,"); print_at(6,2,"PRESS BUTTON ON KEYPAD."); print_at(6,5,"1 = SKILL 1/ONE PLAYER"); print_at(6,7,"2 = SKILL 2/ONE PLAYER"); print_at(6,9,"3 = SKILL 3/ONE PLAYER"); print_at(6,11,"4 = SKILL 4/ONE PLAYER"); enable_nmi();//all graphic write finished, turn on NMI so the controllers and sound will work. a=1; delay(5); while(a==1){ delay(1);//keeps loop running at 60 fps. if(keypad_1==1){livesstart=livesmax=5;nextoneup=nextadd=5;shieldmax=3;a=0;skill=1;speed=0;} if(keypad_1==2){livesstart=livesmax=3;nextoneup=nextadd=4;shieldmax=3;a=0;skill=2;speed=0;} if(keypad_1==3){livesstart=livesmax=5;nextoneup=nextadd=4;shieldmax=1;a=0;skill=3;speed=0;} if(keypad_1==4){livesstart=livesmax=3;nextoneup=nextadd=3;shieldmax=1;a=0;skill=4;speed=0;} } paper(0); cls(); screen_off(); } tnks very much! It is exactly what I was looking for, I thought it was already in the bios de coleco and it only needed to be called, but I see that it has to be done by hand and here your code will work wonders. Thanks for sharing and allowing learning. Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4551336 Share on other sites More sharing options...
Kiwi Posted May 30, 2020 Share Posted May 30, 2020 I managed to invoke it in C out of curiosity and from Hardhat post on what address to call at. It just draws this screen. If you use hexeditor or the debugger to see the memory map, you can see the string for the skill select screen in the bios. This might take a bit of work to do. I added file in lib4k, drawskillselect.s. Looked at other source codes in the folder to see if I got it right. ; drawskillselect.s .module DrawSkillSelect ; global from this code .globl _DrawSkillSelect ; _DrawSkillSelect (void) .area _CODE _DrawSkillSelect: call #0x1f7c ret I type the above. Then click the batch file, build.bat. This replaces cvlib.lib in the lower folder. In coleco.h folder, I just added a line way on the bottom, void DrawSkillSelect(); Replace the coleco.h file in the SDCC include folder. I tried it out with a freshly made source code and the screen came up. void main(void){ //screen_mode_2old(); screen_mode_2_text(); //vdp_out(4,0); screen_on(); DrawSkillSelect(); disable_nmi(); pause(); } It may complain that a function 'DrawSkillSelect' implicit declaration. One of my complaint about C, always peculiar about where the functions are located even though it doesn't matter in asm land. It's basically converting C to asm. I'm not sure how much it sets up the Colecovision. It loads the fonts into VRAM, possible graphic mode 1, and etc. If you're doing 1 player game, fill_vram(0x1980,32,384); will clear half of the screen. Challenger was 29KB when it was completed and I wanted to focus on completing the game back then. So if I needed more memory, I would have done above. 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4551395 Share on other sites More sharing options...
+bhall408 Posted May 30, 2020 Share Posted May 30, 2020 11 hours ago, Kiwi said: Challenger was 29KB when it was completed and I wanted to focus on completing the game back then. So if I needed more memory, I would have done above. Yes, saving some bytes that are better used for your game is a great reason to call the OS routine. Another reason is that if the OS ever got an improved version of that routine, for example, one that didn't require using the keypad, you'd automatically be taking advantage of a much nicer version. Just say'in... 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4551776 Share on other sites More sharing options...
Zak Posted May 31, 2020 Share Posted May 31, 2020 @Kiwi i already have skill selection screen, i use your code and works perfect. i have a problem, in intro CV screen i have garbage at foot, where i must define the " PRESENTS / THE GAME " string ? in crtcv.s ? tnks! Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4552173 Share on other sites More sharing options...
Kiwi Posted May 31, 2020 Share Posted May 31, 2020 10 minutes ago, Zak said: i already have skill selection screen, i use your code and works perfect. i have a problem, in intro CV screen i have garbage at foot, where i must define the " PRESENTS / THE GAME " string ? in crtcv.s ? From the cv programming pdf on page 101. To have the game name, it would have to be at address $8024-80XX. 8024-80XX GAME_NAME String with two delemiters "/" as "LINE2/LINE1/YEAR" I'm not 100% sure where to place this code, but I believe, adding .org 0x8024, and then the string may do the trick. I believe as I'm looking into this... placing the string, in between jp _nmi_asm and ;;CODE STARTS HERE WITH NMI will work without the .org 0x8024. jp _nmi_asm is 3 bytes, so it corresponded with the 8021-8023. .db 0xc9,0,0 ; no RST 28 support .db 0xc9,0,0 ; no RST 30 support .db 0xc9,0,0 ; no RST 38 support (spinner) jp _nmi_asm <-----------Put string data here ;; CODE STARTS HERE WITH NMI .area _CODE From the tniasm.txt I have, do write string, it's said, 2.3.2 String Constants A string constant is anything between single or double qoutes larger than 4 characters. They're used in commands like DB/DW, INCLUDE and FNAME. String constants can not be used in regular expressions. example: DB "a 'double-qouted' string can contain single qoutes" DB 'and a "single-qouted" string can contain double qoutes' So something like DB "WARS/STAR/1983" may be acceptable directive. 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4552180 Share on other sites More sharing options...
+bhall408 Posted May 31, 2020 Share Posted May 31, 2020 10 hours ago, Zak said: i already have skill selection screen, i use your code and works perfect. i have a problem, in intro CV screen i have garbage at foot, where i must define the " PRESENTS / THE GAME " string ? If you have not already, download the various programming guides found here: http://adamarchive.org/archive/ColecoVision/Programming/ 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4552456 Share on other sites More sharing options...
Zak Posted June 1, 2020 Share Posted June 1, 2020 11 hours ago, bhall408 said: If you have not already, download the various programming guides found here: http://adamarchive.org/archive/ColecoVision/Programming/ @Bhaal tnks for the guides. I found the solution looking another library, "LIBCV" ; crt0.s for Colecovision cart .module crt0 .globl _main .globl _cv_init .globl _cv_spint_handler .globl _cv_vint .globl _cv_start .globl ___sdcc_call_hl .area _HEADER(ABS) .org 0x8000 .db 0x55, 0xaa ; Title screen and 12 second delay - swap 0x55 and 0xaa not to skip it. .dw 0 ; Sprite name table for BIOS .dw 0 ; Sprite order table for BIOS. .dw 0 ; Buffer for BIOS. .dw 0 ; Controller map for BIOS. .dw _cv_start ; where to start execution of program. jp 0x0 ; RST 0x08 jp 0x0 ; RST 0x10 jp 0x0 ; RST 0x18 jp 0x0 ; RST 0x20 jp 0x0 ; RST 0x28 jp 0x0 ; RST 0x30 jp spint ; RST 0x38 - spinner - maskable interrupt jp vint ; Vertical retrace - NMI .ascii " / / NOT" i test with "db", ".db", ".org 8024" etc etc. .ascii WORKS OK ! in "crtcv.s" (lib4k) add : (line 74) .ascii "PRESENTA/DIEGO ACCO/2020" very very TNKS TO ALL ! 1 Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-4553001 Share on other sites More sharing options...
ColecoFan1981 Posted May 27 Share Posted May 27 Some of these skill level select screens were different depending on the game. For Turbo, it is only a 1-player game, so only selections 1-4 are present. For Q*bert's Qubes, right above the top of "TO SELECT GAME OPTION" is "WELCOME TO Q*BERT II" and at the bottom, a copyright notice "© PARKER BROTHERS 1984" is added. ~Ben Quote Link to comment https://forums.atariage.com/topic/197017-skill-level-select-screen-noob-alert/#findComment-5474692 Share on other sites More sharing options...
