+Gemintronic Posted May 17, 2012 Share Posted May 17, 2012 (edited) Watching two seasoned programmers figure things out is a privilege and genuinely interesting.. but, what does it have to do with the question of ASM or BASIC? I'll forgive both of them if they make this a bB minikernel! Edited May 17, 2012 by theloon Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted May 17, 2012 Share Posted May 17, 2012 but, what does it have to do with the question of ASM or BASIC? It shows, what you can accomplish in ASM, but not in bBasic. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted May 17, 2012 Share Posted May 17, 2012 (edited) but, what does it have to do with the question of ASM or BASIC? It shows, what you can accomplish in ASM, but not in bBasic. However, it also shows that mere mortals cannot comprehend ASM. As a starting place BASIC lets you get familiar with coding. It also gives you a little instant gratification in getting a workable game up and running faster (for the novice). Finally, the ability to use inline assembly lets you ease into low level programming. Clever ASM may look sexy, but when the beginner realizes he can't comprehend much less reproduce the result.. Edited May 17, 2012 by theloon Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted May 17, 2012 Share Posted May 17, 2012 BASIC and ASM are for pussies. I use pure machine language. Beep. Boop. Beep. 1 Quote Link to comment Share on other sites More sharing options...
Pioneer4x4 Posted May 17, 2012 Share Posted May 17, 2012 It's all one and zeros, ones and zeros... Quote Link to comment Share on other sites More sharing options...
Joe Musashi Posted May 17, 2012 Share Posted May 17, 2012 It works!! I've successfully gotten a routine running. I laid out graphics for digits 0-8 from $FE00 to $FE4B, and graphics for digit 9 & letters A-H from $FE4C to $FE97. You can add more very easily. I was too tired to do this for the demo, but you will get the idea. I am only doing a loop of 8 scanlines in height, but you can do more. I layed it out as bunch of equates to make it easier to read. I'll see what you guys think. Macro's would be a good idea as well as a command line utility as Spiceware suggested. This saves 4 cycles, and a zero page ram location over a regular 48 bit display. In the demo the top numbers are generated by a standard 48 bit display, and the bottom numbers are done by the faster (uses less cycles) 48 bit routine. Very cool trick with the timer! I thought a bit more of what you said in post #41 about using PLA and tried a variant that places the loop counter sequence in the stack. Instead of doing dec loopCount ldy loopCount it uses pla tay to restore the loop counter in Y. This only saves 2 cycles and requires 8 bytes in the zero page to store the counter sequence. On the plus side it works with the usual 7,...,0 sequence which may be required for some use case. I took the liberty to add this variant to your example code. It's labeled ".loopMedium48bit". testTIM8T_2.asm Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 17, 2012 Share Posted May 17, 2012 Watching two seasoned programmers figure things out is a privilege and genuinely interesting.. but, what does it have to do with the question of ASM or BASIC? Nothing. An artist never knows when or where inspiration will strike, but knows it's best to take advantage of it when it does I'll forgive both of them if they make this a bB minikernel! While I won't be doing it, I have no problem with somebody else taking my routines and incorporating them into bB. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 17, 2012 Share Posted May 17, 2012 Alternatively you can also use pla/plp and tsx. A bit more complicated to use, but this requires no zero page RAM. Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 18, 2012 Share Posted May 18, 2012 Very cool trick with the timer! I thought a bit more of what you said in post #41 about using PLA and tried a variant that places the loop counter sequence in the stack. Instead of doing dec loopCount ldy loopCount it uses pla tay Nice! I was thinking today about using a PHA to store the temp ram for digit 6, and then having the stack naturally decrement. I was trying to use LDA absolute,X and LDY absolute,X addressing. I forgot that tsx doesn't affect any flags though, so no looping off it, and loading the temp digit was a problem. Nothing I tried worked well so far. You can always do something like this to loop: TSX DEX TXS I built a demo off of Eckhards 48 bit display (that you could move around) a few years ago. It scrolled the text in 4 directions as well as scrolled colors. The 48 bit display portion went something like this: ;each loop takes one scanline, but the exact cycle the ;loop starts on varies with the sprite positioning... .loopDrawGfx tsx ;2 @2 dex ;2 @4 stack pointer holds the line color txs ;2 @6 ldy tempZero ;3 @9 lda rgSix,Y ;4 @13 6th byte sta tempOne ;3 @16 lda rgOne,Y ;4 @20 1st byte sta GRP0 ;3 @23 lda (displayPtrs),Y ;5 @28 2nd byte sta GRP1 ;3 @31 lda (displayPtrs+2),Y ;5 @36 3rd byte sta GRP0 ;3 @39 stx COLUP0 ;3 @42 stx COLUP1 ;3 @45 lda rgFour,Y ;4 @49 4th byte ldx rgFive,Y ;4 @53 5th byte ldy tempOne ;3 @56 sta GRP1 ;3 @59 stx GRP0 ;3 @62 sty GRP1 ;3 @65 sta GRP0 ;3 @68 dec tempZero ;5 @73 bpl .loopDrawGfx ;2³ @75/76 I was updating both player colors because the display moved around, and it was simpler this way then trying to figure out how to use the playfield or background for coloring. While I won't be doing it, I have no problem with somebody else taking my routines and incorporating them into bB. I feel the same way. If I didn't want people using my stuff I wouldn't post at all. As it is, the community here for the most part is very open and we like to share our ideas. Great things come out of it! Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 18, 2012 Share Posted May 18, 2012 (edited) And for all you ram minimalists, here is a demo for using TIM1T as a temporary storage. This program uses no ram, and yet it is doing looped 48 bit displays. 128 bytes of zero page ram free and never used. Enjoy!! testTIM1T.zip Edited May 18, 2012 by Omegamatrix 5 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted May 18, 2012 Share Posted May 18, 2012 @Omegamatrix: I started a topic in the bB section, but, which two bits in SWCHB are free? Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 18, 2012 Share Posted May 18, 2012 I had it wrong. There are actually 3 bits in SWCHB that are free, not just two. To use them do this once in your code to adjust the DDR register: lda #$34 ; 0011 0100 output on pins D5, D4, and D2 sta SWBCNT ; (1's set individual DDR bits to output, and 0's are for input) Then you can read and write to SWCHB like a normal register. The writes only affect pins you set to one. If you don't use some of the switches in your program (like the player difficulties) then you can make them 1's as well. Here is an old demo I did where I wrote and read to the unused pins in SWCHB. TestSWCHB(rev1.1).zip 1 Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted May 18, 2012 Share Posted May 18, 2012 Omegamatrix, looking at your reset-ram code from #39, it took me several minutes to figure out, why the code has to be this way. Seeing your code at #60, I thought that you're one guy who fights for every byte. Now I've learned, I'm wrong: you're fighting for every bit. Respect! Quote Link to comment Share on other sites More sharing options...
roland p Posted May 18, 2012 Share Posted May 18, 2012 And for all you ram minimalists, here is a demo for using TIM1T as a temporary storage. This program uses no ram, and yet it is doing looped 48 bit displays. 128 bytes of zero page ram free and never used. Enjoy!! Cool, I can't wait for games that don't use RAM Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 18, 2012 Share Posted May 18, 2012 A game that uses no ram is possible. To be fair I would say no zero page ram, but anything on the stock 2600 is fair game. That leaves you with a lot of resources: Accumulator ( has to be used ) X register Y register Stack pointer Timer ( all modes ) SWCHB ( up to eight bits available ) Interrupt bit in the status register All collisions ( 15 bits ) REFP0, and REFP1 ( 1 bit each ) The GRPx registers, ENxx registers, and so and so on. The idea with all these extra registers are simple. Imagine a game with a man running and jumping over a single Playfield block that appears at random. Keep the man (drawn by grp0) in the center of the screen, and position grp1 to the left or right of him on the side of the screen opposite the moving block. Make grp1 the same color as the background and it is hidden. After the screen is drawn test grp1 by deliberately positioning it on top of of an object and read the collision registers. You could also just write a kernel that never has a collision and set manual collisions in the blanking part of the screen. Instant data storage. With redpx keep to sets of gfx, and manually keep the player orientated the same, and again test refpx off screen the same way, position objects during blanking time, read the collisions, and you know what bits have been set in refpx. Lots of registers could be extended the same way as a roundabout for data storage. Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 19, 2012 Share Posted May 19, 2012 I was thinking more about TIM64T today, and I found a way to make it work as a loop counter. It requires the user to read the timer, and then store the value read back in. It takes the same amount of cycles as a regular 48 bit loop, but you save a temporary ram location, and you can ultimately leave the loop 4 cycles sooner, which might be good for tight coding. You do add 4 more cycles coming in though... There is no special arrangement of ram, and you can have a counter value $00-$FF. As soon as you load the timer it immediately decrements, so you just have to make sure you store and load at the right times. If you wait to long you have a timer that decrements by 2, which could also be useful in the right situation. I ran a small test program that displays nothing. You just let it run and open Stella's debugger to see the values the timer had. testTIM64T.zip 1 Quote Link to comment Share on other sites More sharing options...
alex_79 Posted May 19, 2012 Share Posted May 19, 2012 The writes only affect pins you set to one. If you don't use some of the switches in your program (like the player difficulties) then you can make them 1's as well. Actually you can use the entire SWCHB register to store data and still being able to read all of the switches. You can store a value into the Data Register no matter how the bits are configured in the Data Direction Register (SWBCNT) and the value will be preserved even on subsequent changes to the DDR. You only need to set the bits to output when you need to read back the value you stored, or when using instructions that needs to read/modify/write data. So you can store a value to SWCHB, set the port to input, read the switches, set the port to output and read back the value you stored before. Note that this only works on port B, while port A value (SWCHA) may be affected by the controllers connected to the console even when the pins are set to output. 1 Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted May 19, 2012 Share Posted May 19, 2012 So you can store a value to SWCHB, set the port to input, read the switches, set the port to output and read back the value you stored before. Note that this only works on port B, while port A value (SWCHA) may be affected by the controllers connected to the console even when the pins are set to output. That is amazing! So you have an extra register available at all times. You are right about Port A. I remember testing it before with the joystick and it did affect the value. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted May 22, 2012 Share Posted May 22, 2012 If you don't use some of the switches in your program (like the player difficulties) then you can make them 1's as well. Personally I wouldn't recommend making any bit that is connected to an external switch into an output. Lets say you make a difficulty switch port bit into an output. If that difficulty switch is in the B position it will connect the corresponding RIOT pin directly to ground (for as long as its in the B position). If your code sets the difficulty port data register bit to a "1" then that pin on RIOT will try and drive a logic high straight into the ground plane (GND) because the switch is a permanent short circuit. This isn't good for RIOT and is best avoided. Quote Link to comment Share on other sites More sharing options...
