ti99iuc Posted April 30, 2012 Share Posted April 30, 2012 Hi ! a friend of mine posted on the italian ti99iuc forum a question about an error during the programming in assembler... i can't help, maybe know how to solve this problem ? Thankyou ! TI 99 Freeze when i call the Function DSRLNK? I done the examples on the manual, and looking for a solution on this prolem... i tried to change flag, record lenght but it's not working... the same problem using the emulator ... on the real TI the DSK2 power on the red light but freeze. This is the source code: ... PAB EQU >F80 PABBUF EQU >1000 PNTR EQU >8356 ... PDATA BYTE >00 I/O OPCODE BYTE >0A FLAG/STATUS DATA PABBUF DATA BUFFER ADDRESS BYTE >80 LOGICAL RECORD LENGTH CCOUNT BYTE >00 CHARACTER COUNT DATA >0000 RECORD NUMBER (RELATIVE RECORD FILES) BYTE >00 SCREEN OFFSET NLEN BYTE NAMEND-FNAME NAME LENGTH FNAME TEXT 'DSK2.RS232ROM' NAMEND EQU $ EVEN ... LI R0,PAB LI R1,PDATA LI R2,NAMEND-PDATA BLWP @VMBW LI R6,PAB-PDATA+NLEN MOV R6,@PNTR BLWP @DSRLNK DATA 8 Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/ Share on other sites More sharing options...
Willsy Posted April 30, 2012 Share Posted April 30, 2012 No. This doesn't look correct to me. I think the first problem is this line: LI R6,PAB-PDATA+NLEN PDATA and NLEN are symbolic addresses *IN CPU MEMORY* (probably in the >A000 range). However, the value loaded into PNTR (>8356) must be a *VDP* address. The value loaded into CPU memory address >8356 should be the VDP address of the name byte in the PAB. In the above code, that is simply PAB+>0A (or PAB+10 in decimal). So, the code should be changed to read as follows: PAB EQU >F80 PABBUF EQU >1000 PNTR EQU >8356 PDATA BYTE >00 i/o opcode BYTE >0A flag/status DATA PABBUF data buffer address BYTE >80 logical record length CCOUNT BYTE >00 character count DATA >0000 record number (relative record files) BYTE >00 screen offset NLEN BYTE NAMEND-FNAME name length FNAME TEXT 'DSK2.RS232ROM' NAMEND EQU $ EVEN LI R0,PAB LI R1,PDATA LI R2,NAMEND-PDATA BLWP @VMBW LI R6,PAB+10 <---- changed here MOV R6,@PNTR BLWP @DSRLNK DATA 8 I assume the user wants to open the file DSK2.RS232ROM for OUTPUT as a FIXED INTERNAL 128 file? That is what the PAB says (if I decoded it correctly!) I have attached a PAB info cheat sheet that I made about two years ago; it saves me having to find the correct page in the editor assembler manual! Please pass my best regards on to our Italian friends. Mark PAB Info.pdf Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511570 Share on other sites More sharing options...
ti99iuc Posted April 30, 2012 Author Share Posted April 30, 2012 Hi Willsy, thankyou for your help, i will pass all the informations and your regards for sure ! Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511578 Share on other sites More sharing options...
lucien2 Posted April 30, 2012 Share Posted April 30, 2012 No. This doesn't look correct to me. No. I think it is correct. The address written at >8356 must point to the name length, not the first character of the name. So, it's PAB+9, not PAB+10. Or PAB+(NLEN-PDATA) as written in the original post. I tested the code from the original post with classic99 and it creates a file "DSK2.RS232ROM" of type INT/FIX 128. Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511693 Share on other sites More sharing options...
+Lee Stewart Posted April 30, 2012 Share Posted April 30, 2012 No. This doesn't look correct to me. No. I think it is correct. The address written at >8356 must point to the name length, not the first character of the name. So, it's PAB+9, not PAB+10. Or PAB+(NLEN-PDATA) as written in the original post. I tested the code from the original post with classic99 and it creates a file "DSK2.RS232ROM" of type INT/FIX 128. Mark indeed referenced the wrong byte; however, the name length is always byte 9 of the PAB as you point out, so the calculation, NLEN-PDATA, of the position within the PAB of the namelength byte, though fortunately correct, is unnecessarily complex (sort of like this sentence ). Were NLEN other than 9 bytes after PDATA, the branch to DSRLNK would not work in either case. ...lee Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511738 Share on other sites More sharing options...
+InsaneMultitasker Posted April 30, 2012 Share Posted April 30, 2012 No. This doesn't look correct to me. No. I think it is correct. The address written at >8356 must point to the name length, not the first character of the name. So, it's PAB+9, not PAB+10. Or PAB+(NLEN-PDATA) as written in the original post. I tested the code from the original post with classic99 and it creates a file "DSK2.RS232ROM" of type INT/FIX 128. Mark indeed referenced the wrong byte; however, the name length is always byte 9 of the PAB as you point out, so the calculation, NLEN-PDATA, of the position within the PAB of the namelength byte, though fortunately correct, is unnecessarily complex (sort of like this sentence ). Were NLEN other than 9 bytes after PDATA, the branch to DSRLNK would not work in either case. ...lee Not to muddy the waters but be careful: It is true that the name length is byte 9 when using level 3 file IO routines (ie, open/read/write/close/restore/delete) however the length byte, PAB, and scratchpad RAM requirements change when using the direct sector/file access routines (ie, read sector, write direct file, rename file). Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511780 Share on other sites More sharing options...
Willsy Posted April 30, 2012 Share Posted April 30, 2012 Sorry! My bad. Even my own cheat sheet shows the correct byte (9) for the name length. However, please take a look at the code as originally posted. The address MOVd to >8356 is incorrect, because it is computed from *CPU* memory addresses, which are determined at load time by the option 3 loader. The address in >8356 should be a VDP address, and is computed from the equate PAB (>F80), which is a VDP address. Therefore, I believe my original observation to be correct, albeit with the wrong byte offset. So, to be clear, the corrected line of code should be: LI R6,PAB+9 Please refer to ED/AS manual, page 303. I had to go look myself, as I rarely get involved with DSRLNK; I wrote the disk handling code for TurboForth in 2009 and haven't touched it since (in fact, it's just about the only bit of code that hasn't changed!!) Apologies for the confusion - I will endeavour to check first! That's what happens when you post from your work desk, trying to look like your doing real work! Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511826 Share on other sites More sharing options...
+Lee Stewart Posted April 30, 2012 Share Posted April 30, 2012 Sorry! My bad. Even my own cheat sheet shows the correct byte (9) for the name length. However, please take a look at the code as originally posted. The address MOVd to >8356 is incorrect, because it is computed from *CPU* memory addresses, which are determined at load time by the option 3 loader. The address in >8356 should be a VDP address, and is computed from the equate PAB (>F80), which is a VDP address. Therefore, I believe my original observation to be correct, albeit with the wrong byte offset. So, to be clear, the corrected line of code should be: LI R6,PAB+9 Please refer to ED/AS manual, page 303. I had to go look myself, as I rarely get involved with DSRLNK; I wrote the disk handling code for TurboForth in 2009 and haven't touched it since (in fact, it's just about the only bit of code that hasn't changed!!) Apologies for the confusion - I will endeavour to check first! That's what happens when you post from your work desk, trying to look like your doing real work! Begging your pardon, Mark, but the original code is the same as yours, but with an address calculation for the offset instead of a literal value: NLEN-PDATA, though operating on CPU address space, nonetheless, computes to the proper offset, viz., 9. ...lee Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2511942 Share on other sites More sharing options...
up.n.down Posted May 1, 2012 Share Posted May 1, 2012 Hello everybody, I'm the original user that posted the question to the Italian TI-99 user club forum. I wasn't registered as an AtariAge user, so Ciro kindly posted the question here for me. At first I would like to thank everybody for all the feedback, I wasn't expecting so much In particular, I would like to thank Mark for his cheat sheet, very useful to have it handy! Returning to the argument of the post, I'm really stumped because I think the code is right. Yes, those are CPU addresses, but computing the difference between the two simply gives you an offset that is added to a VDP address, so at last the assembler geenrates a valid VDP address (I hate having "magic numbers" around my code and il ti easier for my mind to understand what that means. Complex? Maybe. We all are somehow... Let's the assembler work for us) I really don't understand what's up with this code. On the physical console, all I have is a DSK2 led turned on (and a few seek noises), but than everything hangs. On the MESS, I don't have leds and noises, just hang :-( I don't have at the moment a Classic99 at hand, but I understand that there the same code works. I'm glad, but I neet it to work on the real console... Is there some black magic to do before invoking DSRLNK? I beg you aprdon, but this is my very first assembler program on the TI, so please consider that I may have missed also obvoius things. Once more thanks to everybody, and happy 1st May (for the ones that are in holiday like us in Italy). Ciao, Ugo Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2512435 Share on other sites More sharing options...
Willsy Posted May 1, 2012 Share Posted May 1, 2012 Well, your code does look correct (apologies to Lee! Woops!) Is this the complete code, or is there more code? For example, I am wondering if you are using your own workspace, or the GPL workspace? Are you running this code from the editor assembler option 3 loader? We could do with a little more information. You should also issue a CLOSE command to the disk system to close the file, but I don't think that would crash the computer. How are you returning to the Editor Assembler environment? With an RT (B *R11) instruction? Mark Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2512487 Share on other sites More sharing options...
Willsy Posted May 1, 2012 Share Posted May 1, 2012 Here is program that is complete - it sets up the workspace, creates the file, indicates if there was an error or not, and then returns to the editor assembler. Load with editor assembler option 3. For program name, enter START. REF VMBW,VSBW,DSRLNK DEF START PAB EQU >F80 PABBUF EQU >1000 PNTR EQU >8356 PDATA BYTE >00 I/O OPCODE BYTE >0A FLAG/STATUS DATA PABBUF DATA BUFFER ADDRESS BYTE >80 LOGICAL RECORD LENGTH CCOUNT BYTE >00 CHARACTER COUNT DATA >0000 RECORD NUMBER (RELATIVE RECORD FILES) BYTE >00 SCREEN OFFSET NLEN BYTE NAMEND-FNAME NAME LENGTH FNAME TEXT 'DSK2.RS232ROM' NAMEND EQU $ EVEN MYWS BSS 32 START LWPI MYWS LI R0,PAB LI R1,PDATA LI R2,NAMEND-PDATA BLWP @VMBW LI R6,PAB-PDATA+NLEN MOV R6,@PNTR BLWP @DSRLNK DATA 8 JEQ ERR JUMP IF IO ERROR DETECTED * NO ERROR DETECTED CLR R0 SCREEN ADDRESS LI R1,OKTXT ADDRESS OF TEXT LI R2,5 LENGTH OF TEXT BLWP @VMBW WRITE TO SCREEN JMP EXIT * ERROR DETECTED ERR MOV R0,R2 SAVE ERROR CODE IN R2 CLR R0 SCREEN ADDRESS LI R1,ERRTXT ADDRESS OF TEXT LI R2,4 LENGTH OF TEXT BLWP @VMBW WRITE TO SCREEN EXIT LI R0,3 OUTER COUNTER LI R1,>FFFF INNER COUNTER LOOP DEC R1 JNE LOOP DEC R0 JNE LOOP RT RETURN TO EDITOR ASSEMBLER ERRTXT TEXT 'ERROR' EVEN OKTXT TEXT 'OKAY' EVEN END It uses a simple JEQ instruction to see if there is an error or not. According to section 16.2.4 (page 262) in the ED/AS manual: If no errors occur, the equal bit in the Status Register is reset on return from DSRLNK. If an I/0 error occurs, the equal bit is set, and the error code is stored in the most-significant byte of Register 0 of the calling program's Workspace. Please try this on a real 4A (it works okay in Classic99). If you see ERROR on the screen please let me know and I will add code to display the error code. Mark Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2512510 Share on other sites More sharing options...
up.n.down Posted May 1, 2012 Share Posted May 1, 2012 Thanks Mark, of course there is other code, there is always other code, other code that make things go wrong... :-( I'm saying this because I tried your example on the MESS emulator and it worked. Then I examined your code and compared with my own, and I saw that it was almost the same (AORG >A000 being the only difference). I "just" have some more code before the DSRLNK. I remmed that core out, and, guess it?, DSRLNK started working. So i understood that the culprit is not DSRLNK itself, nor the PAB, but the copy loop right before, that is going to dirty teh PAB copy in CPU RAM and I really don't understand what's going on there. I attach the whole code of my fabolous program I'm trying to make a backup of my CorComp RS232 ROM, as I'm willing to replace it with a Flash EEPROM adding (maybe) some features in it (HDX). So the (bugged) logic of the program is: enable RS232 rom, make a backup of the ROM in CPU RAM, disable ROM, open file, write file, close file. I'm almost sure that there is a bug in the write loop too, but I will address that later if I survive this one. And yes, I'm sure I could find a CorComp ROM somewhere in the net, but forgive me I have to finish this now, simply cannot give up without understanding my own errors. You will see strange things in the code, like BL @PDEBUG or JMP BAILOU or BL @PRINTR, but those are only debug istructions and you can safely ignore them. I added them when I saw that the code was hanging at the DSRLNK call, and keep adding debug also after understanding that the loop was the guilty. BTW, how do you debug such a beast? The only method I found is tou use MESS with -debug switch to enable debugger, but that's sooooo slooooowwwwwww... DEF START REF VMBW,DSRLNK,VSBW,VSBR AORG >A000 PAB EQU >F80 PABBUF EQU >1000 PNTR EQU >8356 CRU EQU >1300 ROMSRC EQU >4000 ROMSIZ EQU >2000 PFFIX EQU >00 PFVAR EQU >10 PFDIS EQU >00 PFINT EQU >08 PFUPD EQU >00 PFOUT EQU >02 PFINP EQU >04 PFAPP EQU >06 PFSEQ EQU >00 PFRAN EQU >01 REGS BSS 32 RTNADR BSS 2 CPUDAT BSS ROMSIZ PDATA BYTE >00 I/O OPCODE BYTE PFFIX+PFINT+PFOUT+PFSEQ FLAG/STATUS DATA PABBUF DATA BUFFER ADDRESS BYTE >80 LOGICAL RECORD LENGTH CCOUNT BYTE >00 CHARACTER COUNT DATA >0000 RECORD NUMBER (RELATIVE RECORD FILES) BYTE >00 SCREEN OFFSET NLEN BYTE NAMEND-FNAME NAME LENGTH FNAME TEXT 'DSK2.RS232ROM' NAMEND EQU $ EVEN WRITE BYTE >03 CLOSE BYTE >01 DTEXT TEXT 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' EVEN START MOV R11,@RTNADR LWPI REGS CLR R13 BL @PDEBUG LI R0,367 LI R1,CPUDAT BL @PRINTR LIMI 0 LI R12,CRU SBO 0 LI R0,ROMSRC LI R1,CPUDAT LI R2,ROMSIZ COPYLP MOV *R0+,*R1+ DECT R2 JNE COPYLP SBZ 0 LIMI 2 BL @PDEBUG MOV R1,R3 MOV R0,R1 LI R0,299 BL @PRINTR MOV R3,R1 LI R0,304 BL @PRINTR MOV R2,R1 LI R0,309 BL @PRINTR LI R0,PAB LI R1,PDATA LI R2,NAMEND-PDATA BLWP @VMBW BL @PDEBUG JMP BAILOU BL @DSR BL @PDEBUG * JMP BAILOU MOVB @WRITE,R1 BLWP @VSBW LI R1,>8000 LI R0,PAB+CCOUNT-PDATA BLWP @VSBW BL @PDEBUG LI R0,PABBUF LI R1,CPUDAT LI R2,>80 LOOP BLWP @VMBW BL @PDEBUG BL @DSR BL @PDEBUG * JMP BAILOU A R2,R1 CI R1,CPUDAT+ROMSIZ JNE LOOP BL @PDEBUG MOVB @CLOSE,R1 LI R0,PAB BLWP @VSBW BL @PDEBUG BL @DSR BL @PDEBUG JMP BAILOU PDEBUG MOVB @DTEXT(R13),R1 MOV R13,R0 BLWP @VSBW INC R13 RT DSR LI R6,PAB-PDATA+NLEN MOV R6,@PNTR BLWP @DSRLNK DATA 8 JEQ DSRERR RT DSRERR LI R0,PAB+1 BLWP @VSBR SRL R1,13 AI R1,>30 SLA R1,8 LI R0,299 BLWP @VSBW BAILOU LI R0,3 LI R1,>FFFF WLOOP DEC R1 JNE WLOOP DEC R0 JNE WLOOP MOV @RTNADR,R11 RT DECODE TEXT '0123456789ABCDEF' REGVAL BSS 2 PRNRET BSS 2 PRINTR MOV R1,@REGVAL MOV R11,@PRNRET SRL R1,12 BL @PRINTC MOV @REGVAL,R1 SRL R1,8 ANDI R1,>000F BL @PRINTC MOV @REGVAL,R1 SRL R1,4 ANDI R1,>000F BL @PRINTC MOV @REGVAL,R1 ANDI R1,>000F BL @PRINTC MOV @PRNRET,R11 RT PRINTC MOVB @DECODE(R1),R1 BLWP @VSBW INC R0 RT END Thanks again. Ciao, Ugo Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2512868 Share on other sites More sharing options...
Willsy Posted May 2, 2012 Share Posted May 2, 2012 That LIMI 2 is ringing alarm bells in my head. There seems to be no reason for the interrupts to be enabled. You run the risk of the VDP address being changed while your screen writing routines are being executed, which can lead to trash being written into VDP (including the VDP registers which may corrupt the screen etc). Give it a try without the LIMI 2. The best program for debugging is Classic99 - it has an incredible debugger with breakpoints, break on read/write from/to memory, read/write from/to registers, read/write from/to VDP. It can even tell you if your code is reading from un-initialised areas of memory. It's easily the best debugger by a mile. I think a close second is TI994W by Fred Kaal. If you have a TurboForth V1.1 cartridge I can write you some code to dump the RS232 ROM to a blocks file or any other type of file. Mark Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513336 Share on other sites More sharing options...
Willsy Posted May 2, 2012 Share Posted May 2, 2012 Also, it might be better to look at a different technique. You are copying the ROM to CPU memory. I wouldn't bother; I would copy it to VDP memory, as that's where it needs to be to write it out to disk. I'll see if I can put something together this evening. I haven't done much assembly language disk access code; just the stuff for TurboForth so it should be fun! Mark Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513345 Share on other sites More sharing options...
up.n.down Posted May 2, 2012 Share Posted May 2, 2012 Thanks King I thought I should copy ROM -> CPU RAM in order to use Disk Controller ROM to write to disk. I didn't find any source stating that you can access devices (call @VSBW or @DSRLNK) with interrupts disabled, this is why I reenabled 'em just after copy. Indeed, I could copy RS232 ROM -> VDP RAM directly, and maybe also in just one big chunk, so I will try this one tonight. For the emulators: I'm on Linux, so I think I am stuck with MESS, am I not? Should I try the recursive emulator approach (Classic99 inside Virtualbox running Windows)? Still dreaming to use Linux native tools to develop (asm990 and so on)... And no, I don't happen to have a TurboForth at hand. But started to read your site and seems interesting Please don't waste your time with this old noob Once more thanks, and again congratulations for the title. Ciao, Ugo Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513364 Share on other sites More sharing options...
ti99iuc Posted May 2, 2012 Author Share Posted May 2, 2012 (edited) And no, I don't happen to have a TurboForth at hand. But started to read your site and seems interesting Up ! you can found the TurboForth in Classic99 cartridge menu, it's ready to go !! i have two original real carts but it's the v1.0, i should upgrade them to the new version... Edited May 2, 2012 by ti99userclub Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513438 Share on other sites More sharing options...
Willsy Posted May 2, 2012 Share Posted May 2, 2012 TurboForth V1.2 will (hopefully) be released in a few days... It looks very very stable. I'm very happy with it. All stupid bugs fixed (I hope!) Mark 1 Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513473 Share on other sites More sharing options...
+InsaneMultitasker Posted May 2, 2012 Share Posted May 2, 2012 TurboForth V1.2 will (hopefully) be released in a few days... It looks very very stable. I'm very happy with it. All stupid bugs fixed (I hope!) And what about the intelligent bugs? Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513493 Share on other sites More sharing options...
lucien2 Posted May 2, 2012 Share Posted May 2, 2012 Still dreaming to use Linux native tools to develop (asm990 and so on)... There is a port of the GNU assembler for the TI: http://www.atariage.com/forums/topic/164295-gcc-for-the-ti/page__st__75?do=findComment&comment=2484308 GCC still has some bugs, but the assembler works perfectly. It's a patch for binutils-2.19.1, I don't know if it works with another version. Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513545 Share on other sites More sharing options...
Willsy Posted May 2, 2012 Share Posted May 2, 2012 Well, I had to have a play! I told myself I had to finish before my cup of tea went cold. I managed it! Here is a program that I *think* works! I was only able to test it with classic99, and if I remember correctly, classic99 doesn't truly emulate the DSRs, so when you map the DSR ROM into memory they don't actually show up - so it saves 8K of zero's. If anyone spots anything wrong then please shout! Anyway, I'm pretty sure this will work on a real TI. Please give it a shot. DEF START REF VMBR,VMBW,DSRLNK SAVEOP EQU 6 memory image save opcode VDPPAB EQU >1000 address of PAB in VDP VDPBUF EQU >1800 address of rom image in VDP LEV3IO EQU 8 code for standard level 3 disk io PNTR EQU >8356 address of name length in VDP pab must be written here MYPAB BYTE SAVEOP,0 DATA VDPBUF BYTE 0,0 DATA 8192 BYTE 0 BYTE 13 TEXT 'DSK2.RS232ROM' EVEN ENDPAB EQU $ * copy pab to vdp ram START LI R0,VDPPAB vdp destination LI R1,MYPAB source LI R2,ENDPAB-MYPAB # bytes to transfer BLWP @VMBW send PAB to VDP * copy DSR ROM to VDP LI R12,>1300 cru address of card SBO 0 turn on DSR ROMS LI R0,VDPBUF we'll put DSR here LI R1,>4000 address of DSR ROM LI R2,8192 8K of ROM BLWP @VMBW send the dsr to VDP SBZ 0 switch off DSR roms * now execute a SAVE command using DSRLNK LI R0,VDPPAB+9 address of name byte in VDP pab MOV R0,@PNTR required for DSRLNK BLWP @DSRLNK DATA LEV3IO standard level 3 disk io RT return to editor assembler environment END It uses the SAVE command, which saves VDP memory to disk as a program image file; the most compact and fastest of the file formats for the TI. See editor assembler manual, section 18.2.1.7, page 297. I've also attached the source as a text file. Hope this helps. Mark SAVE-ROM.txt Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513672 Share on other sites More sharing options...
Tursi Posted May 2, 2012 Share Posted May 2, 2012 Correct, Classic99 doesn't emulate the TI disk system today, it uses its own DSR system. Nice work on the code! Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513706 Share on other sites More sharing options...
up.n.down Posted May 2, 2012 Share Posted May 2, 2012 The code is awesome, indeed. Very elegant. This proves that I have to RTFM a bit more But there is a little problem... it hangs my console with the floppy controller led lit. Both floppies are at IDLE (led turned off). I have to turn off the TI to resume, FNCT+= is not enough I tried your original code (cut & paste from this web page into MESS, extracted from .DSK to TIFILES on Linux command line, transferred to TI via RS232 + MFM and compiled on the TI with no errors), and then I tried to add a private workspace and to disable interrupts, but nothing changes. I cannot try anymore now, I'm risking a divorce right now Ciao Ugo Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513800 Share on other sites More sharing options...
Willsy Posted May 2, 2012 Share Posted May 2, 2012 Hmm... looks like the code us missing somewhere. Dunno. One for the experts I think. Anyone? Is SAVE level 3 operation? I'm a newbie at this disk io stuff. Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513836 Share on other sites More sharing options...
+InsaneMultitasker Posted May 2, 2012 Share Posted May 2, 2012 (edited) Hmm... looks like the code us missing somewhere. Dunno. One for the experts I think. Anyone? Is SAVE level 3 operation? I'm a newbie at this disk io stuff. I'd wager the problem is with the workspace (or lack thereof). Recommend you set up your environment and shut down the interrupts, ie. If the program is called from the GPLWS and DSRLNK uses that same workspace, you end up with a mess on your hands.... MYWS BSS >20 START LWPI MYWS LIMI 0 continue code Try returning with a BLWP @0 I would also adjust the buffer start address from 0x1800 to 0x1200. Otherwise, you are mucking around with VDP space used by some of the disk controllers. For a good overview of the space, check out this doc pages 10 and 11 in particular. ftp://whtech.com/magazines/smartprogrammer/sp8405.pdf Edited May 2, 2012 by InsaneMultitasker 2 Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2513874 Share on other sites More sharing options...
+Lee Stewart Posted May 3, 2012 Share Posted May 3, 2012 Hmm... looks like the code us missing somewhere. Dunno. One for the experts I think. Anyone? Is SAVE level 3 operation? I'm a newbie at this disk io stuff. SAVE is, indeed, a level 3 operation. ...lee Quote Link to comment https://forums.atariage.com/topic/197270-function-dsrlnk-error-someone-can-help/#findComment-2514069 Share on other sites More sharing options...
