2 Quick Newb ASM Questions
I'm just getting started learning 6502, and have 2 questions I need some help on. I'm using the Yars' Revenge source code and the 2600 Programming Guide to learn right now.
1st question:
Here's a few lines in the code that confuse me:
.setYarColorValues
lda #DK_BLUE+12
sta yarColor ; save color for Yar
sta COLUP1 ; set color for Yar sprite
lda #BROWN+14
sta reservedYarColor
lda #<player1Score
sta playerScorePtr
lda #<Qotile
sta qotileGraphicPtrs
lda #>Qotile
sta qotileGraphicPtrs+1
lda #NEUTRAL_ZONE_MASK
sta neutralZoneMask
sta reserveNeutralZoneMask
ldx #4
What do the > / < mean for lda and when is it appropriate to use them? I know the # is immediate addressing. The qotile in this case is the qotile graphic:
Qotile
.byte $00 ; |........|
.byte $0F ; |....XXXX|
.byte $1B ; |...XX.XX|
.byte $33 ; |..XX..XX|
.byte $E3 ; |XXX...XX|
.byte $FF ; |XXXXXXXX|
2nd question:
On conditional branch statements (bmi, bcc, etc) does the code continue where it was before after execution of the branch (just making sure I understand branching vs. jumping)?
Example:
StartSwirlAnimation
IF COMPILE_VERSION = NTSC
lda #>SwirlSprites
ENDIF
lda #<SwirlSprites
lda #SWIRL_TRIPLE_FREQ
bit gameState
beq .jmpToCheckUpdateQotileMissile; branch if Swirl not firing at triple freq
lda gameTimer ; get current game timer
ror ; shift D0 to carry
bcc .jmpToCheckUpdateQotileMissile; branch if this is an even frame
ror
bcs CheckToLaunchSwirl ; branch if D1 of game timer set
jmp .checkToUpdateQotileMissile
On the above bcc I bolded, does execution continue to the next ror on the line below after .jmpToCheckUpdateQotileMissile is called?
1. The < and > extract a specific byte of a 2-byte value.
Using an example 2-byte value of $FF10
< extracts the LSB (Least Significant Byte), or $10
> extracts the MSB (Most Significant Byte), or $FF
2. The difference between Branching and Jumping is that Branching is conditional - the branch may, or may not, be taken depending on the condition specified by the 2 letters after the B (BCC = branch if carry clear, BCS = branch if carry set, BPL = branch if number is positive, etc). If the branch is taken, it's a one-way trip, just like it is for Jumping. JSR (Jump SubRoutine) is the command that returns to continue the following code. The return is triggered by RTS (ReTurn from Subroutine).
Edited by SpiceWare
