Arcade GFX hack
Inky
Yes...with a catch.
Yes, because Rasty put a utility called RomHack up on his site long ago. This can open up any type of file and display it as graphics and/or program data. Grab it here:
http://www.rasty.com/me.htm
The catch is that a good share of arcade roms run self-tests looking for altered or bad data (or what it assumes to be bad data). On top of that, the emulator itself will also be looking for a bad checksum. So you would need to bypass the game's self-test, and disable the emulator's nag (if possible).
Better solution...
There is an editor called Age that you can download at Zophar's utilities:
http://www.zophar.net/utilities/mameutil.html
Once changes are made, I suppose you could use the RomDoctor to fix it up... and get the correct checksum etc.
There's an older one as well...but I can't remember what the name of it was (it was used to make those "neon" hacks).
EDIT: Duh...it was Turaco:
http://www.csh.rit.edu/~jerry/turaco/
