lucifershalo Posted July 7, 2012 Share Posted July 7, 2012 When I was using my NanoCF7 I was able to use my cart normally 2 days ago, I tried using it again with my PEBOX and disks and when I selected 2 Editor Assembler it says ERROR NO MEMORY EXPANSION PRESS ENTER TO CONTINUE I tried to use it , while the PEBOX was unplugged same error message is it defective or is it another problem, do you think? thanks Quote Link to comment https://forums.atariage.com/topic/200016-is-my-ea-cart-defective/ Share on other sites More sharing options...
+retroclouds Posted July 7, 2012 Share Posted July 7, 2012 Chances that your editor/assembler cartridge is broken, is very very unlikely. If broken it would probably not start at all. My tip is that the firehose cable is not closely attached or broken. Might also be the 32k card should be refitted, but I would first check the firehose cable and its connector. Did you also try with another Console? Quote Link to comment https://forums.atariage.com/topic/200016-is-my-ea-cart-defective/#findComment-2554864 Share on other sites More sharing options...
lucifershalo Posted July 7, 2012 Author Share Posted July 7, 2012 thanks but if it is that how I cant start my E/A cart with the pebox unplugged? I could a month ago and I dont have a second console to test it.... Quote Link to comment https://forums.atariage.com/topic/200016-is-my-ea-cart-defective/#findComment-2554873 Share on other sites More sharing options...
Tursi Posted July 7, 2012 Share Posted July 7, 2012 The E/A cart will not start if it can't see a 32k. The NanoPeb has 32k onboard, so either that was plugged in or your PEB was. Quote Link to comment https://forums.atariage.com/topic/200016-is-my-ea-cart-defective/#findComment-2555079 Share on other sites More sharing options...
lucifershalo Posted July 8, 2012 Author Share Posted July 8, 2012 yes I probably tried with the Nanopeb so it cant see the 32k memory expansion in PEbox one "mystery" resolved but when I typed SIZE under XB I had the right memory size so like retroclouds suggest I should investigate the Pebox connection Quote Link to comment https://forums.atariage.com/topic/200016-is-my-ea-cart-defective/#findComment-2555358 Share on other sites More sharing options...
ti99iuc Posted July 8, 2012 Share Posted July 8, 2012 ... yes i agree, you should investigate on the PeBox connection and try with another 32Kb Card eventually... Quote Link to comment https://forums.atariage.com/topic/200016-is-my-ea-cart-defective/#findComment-2555370 Share on other sites More sharing options...
