ivop Posted June 14, 2020 Share Posted June 14, 2020 (edited) Northern Lights with buck 27 colors I'm not a big fan of dither, but I just had to use knoll dither with ciede predistance once On an eight core 3.5GHz AMD64 it took thirteen(!) minutes just to dither and render the destination picture. And all cores were in use! I suppose it could take hours on lesser CPUs. Tip: if you ever use knoll dither, immediately save the output.png-dst.png file somewhere else. If you use it later as input, be sure to disable dither in your new run and set both /predistance and /distance to yuv. The line artifacts in the deer luckily resolved. Sadly, there are still some in the darker areas. What dither did BTW is introduce some blues! Without dither, it was all green bands. Edit: white speck is not en error BTW. It's a celestial body ivop_northern-lights.xex Edited June 14, 2020 by ivop 10 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4563524 Share on other sites More sharing options...
ivop Posted June 15, 2020 Share Posted June 15, 2020 Oh-oooh. Buck's in trouble 16 colors ivop_meateater.xex 4 1 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4564208 Share on other sites More sharing options...
ivop Posted June 16, 2020 Share Posted June 16, 2020 Bald Eagle 37 colors ivop_bald-eagle.xex 11 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4565113 Share on other sites More sharing options...
ivop Posted June 17, 2020 Share Posted June 17, 2020 Swan 12 colors ivop_swan.xex 8 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4565787 Share on other sites More sharing options...
ivop Posted June 17, 2020 Share Posted June 17, 2020 Eddy Merckx The Cannibal 6 shades Hopefully no anoying line artifacts He turned 75 today. ivop_merckx.xex 5 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4566040 Share on other sites More sharing options...
amarok Posted June 26, 2020 Share Posted June 26, 2020 Today I'd like to present you a photo which for me became the most challenging so far. I cannot tell you exactly how many attempts I have made. Everytime the result was far from my expectations. Despite everything, I decided to publish the final conversion. There are 59 individual colors. I hope you like it. amarok_girl.xex 14 2 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572394 Share on other sites More sharing options...
ivop Posted June 26, 2020 Share Posted June 26, 2020 (edited) 1 hour ago, amarok said: I hope you like it. Yeah, I like it! A lot I assume you also still see some, what I call, annoying artifacts Especially in the left eye (right for the viewer). The blue overflows into the white. I recognize this problem. What turns up blue, is RastaConverter attempting to be close to something greyish most of the time. The luminance of the blue is closer. When I see that happen, I edit the source image so it's all (extremely) white But with such a good conversion, you can also take either output.png or output.png-dst.png as an input for a new conversion. Be sure you then set /predistance to the same as your previous conversion's /distance. And use the exact same palette! That way you can edit out the problematic parts in the eyes. All white, and perhaps even two or three blues for the irisses. Just guessing. But could be tried. During editting (with The Gimp, Photoshop, ...) you have to be very careful to not introduce any new colors. Select by color, use the pipette to get the exact same color when you go fill parts with other colors, and so on I have used this method for some of my best conversions. Once you're close, you have to accommodate RastaConverter a little Most of the time I used the output.png-dst.png image to "adjust" some errors, like the shadow of Michael Jackson's Jacket on his pristine white shirt Edited June 26, 2020 by ivop 2 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572423 Share on other sites More sharing options...
Gunstar Posted June 26, 2020 Share Posted June 26, 2020 Soaring. 35 colors. Soaring.xex 17 1 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572618 Share on other sites More sharing options...
Kyle22 Posted June 27, 2020 Share Posted June 27, 2020 8 hours ago, amarok said: Today I'd like to present you a photo which for me became the most challenging so far. I cannot tell you exactly how many attempts I have made. Everytime the result was far from my expectations. Despite everything, I decided to publish the final conversion. There are 59 individual colors. I hope you like it. amarok_girl.xex 22.04 kB · 10 downloads Her eyes are pretty. It is all good except for the shameful face covering. 1 1 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572716 Share on other sites More sharing options...
amarok Posted June 27, 2020 Share Posted June 27, 2020 @ivop, thank you for your advices, it is very helpful. In fact, in couple of my converions I used corrected output-dst.png as an input for RastaConverter, but not in this time. Many often I use Gimp for preprocessing, especially correction of colors like desaturation as you suggested. For me the worst thing is the long time for getting the results in RastaConverter. I hope that in a near future someone will prepare a GPU based RastaConverter ?. Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572830 Share on other sites More sharing options...
_The Doctor__ Posted June 27, 2020 Share Posted June 27, 2020 I though she was a Ninja! Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572832 Share on other sites More sharing options...
+Philsan Posted June 27, 2020 Author Share Posted June 27, 2020 Toleman F1 TG183, 1983, Bruno Giacomelli, 36 colors. Philsan_Toleman_1983.xex 11 1 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572850 Share on other sites More sharing options...
Gunstar Posted June 27, 2020 Share Posted June 27, 2020 US Navy bird. 35 colors. USNavybird.xex 15 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4572936 Share on other sites More sharing options...
Mathy Posted June 27, 2020 Share Posted June 27, 2020 Hello guys On 6/26/2020 at 7:04 PM, amarok said: 20 hours ago, Kyle22 said: Her eyes are pretty. It is all good except for the shameful face covering. If I remember correctly, this is a famous picture of a woman living in a tribe of nomads. Covering your face is often a necessity in places where the combination of wind and sand will otherwise sandblast your face. Men can grow beards to prevent that, women usually can't (and most women and men wouldn't like that). Sincerely Mathy 4 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4573229 Share on other sites More sharing options...
_The Doctor__ Posted June 27, 2020 Share Posted June 27, 2020 I still think she looks like a Ninja! Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4573235 Share on other sites More sharing options...
Gunstar Posted June 28, 2020 Share Posted June 28, 2020 She is just prepared for Covid-19... 1 2 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4573501 Share on other sites More sharing options...
Gunstar Posted July 2, 2020 Share Posted July 2, 2020 A Fantasy Castle. 49 colors. FantasyCastle.xex 12 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4576873 Share on other sites More sharing options...
amarok Posted July 2, 2020 Share Posted July 2, 2020 Violin, 25 colors. amarok_violin.xex 15 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4577173 Share on other sites More sharing options...
Gunstar Posted July 4, 2020 Share Posted July 4, 2020 Tie Fighter Squadron. 49 colors. This one I redid many times, attempting to get the explosions better defined. This isn't the best for explosion definition, just the best over all. TieSquadron1.xex 9 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578449 Share on other sites More sharing options...
Faicuai Posted July 4, 2020 Share Posted July 4, 2020 (edited) On 6/27/2020 at 6:52 PM, Mathy said: Hello guys If I remember correctly, this is a famous picture of a woman living in a tribe of nomads. Covering your face is often a necessity in places where the combination of wind and sand will otherwise sandblast your face. Men can grow beards to prevent that, women usually can't (and most women and men wouldn't like that). Sincerely Mathy Well, in reality, there is no such thing as covering your face for "wind-and-sand" for the "Afghan-girl", which was captured by one of my all-time-fav. photographers Steve McCurry, neither of which relate to the above random face-cover. picture (if that is what you were referring to, of course...) The Afghan girl covers her face because of her religion, and because she lives in a place that is quite inhospitable for women, and especially young boys... That is the truth. Here she is, as Steve saw it... and later in life, deprived from any real chance of growth and progress: Edited July 4, 2020 by Faicuai Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578558 Share on other sites More sharing options...
ivop Posted July 4, 2020 Share Posted July 4, 2020 (edited) About the "ninja" photo: A piercing gaze They say beauty is in the eye of the beholder. Sometimes, that beauty is just in their eyes. This magnificent shot shows that iPhone photographs have been incredible for years. This image by Kim Hanskamp was taken way back in 2013 and selected as the winner in the people category. https://kimhanskamp.com/a-wards/ It was part of the iPhone Photography Awards. I think it is Hanskamp herself: https://kimhanskamp.com/wp-content/uploads/2019/12/kim2-1810x1280.jpg The freckles are somewhat less on this photo, but that changes per season. I know personal experience. The "ninja" also wears mascara Edited July 4, 2020 by ivop Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578585 Share on other sites More sharing options...
emkay Posted July 4, 2020 Share Posted July 4, 2020 (edited) 45 minutes ago, Faicuai said: The Afghan girl covers her face because of her religion, and because she lives in a place that is quite inhospitable for women, and especially young boys... That is the truth. It's not something for a thread like this, but your sentence is partly wrong and right. There is NO text in the Q'RAN where female people have to hide their face. Vice Versa. It is written that , if some "higher person in law" gets close, they AREN'T allowed to hide their face. It is only allowed to protect people when they see danger. That whole "Burka" and "NIQAP" or "hidshab" is Moslem religion based thing is a western plucked out of the air invention, and a basis to have meaning collision on both sides. And, as you wrote, there are a lot dangerous possibilities particular for young women , so they are allowed to wear those "protection suits". Edited July 4, 2020 by emkay Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578589 Share on other sites More sharing options...
ivop Posted July 4, 2020 Share Posted July 4, 2020 14 minutes ago, emkay said: It's not something for a thread like this, but your sentence is partly wrong and right. There is NO text in the Q'RAN where female people have to hide their face. Vice Versa. It is written that , if some "higher person in law" gets close, they AREN'T allowed to hide their face. It is only allowed to protect people when they see danger. That whole "Burka" and "NIQAP" or "hidshab" is Moslem religion based thing is a western plucked out of the air invention, and a basis to have meaning collision on both sides. And, as you wrote, there are a lot dangerous possibilities particular for young women , so they are allowed to wear those "protection suits". Our posts will probably be moderated into oblivion, but read An-Noer:31 and Al-Ahzab:59. Perfectly clear. Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578599 Share on other sites More sharing options...
Mathy Posted July 4, 2020 Share Posted July 4, 2020 Hello faicual 1 hour ago, Faicuai said: ... if that is what you were referring to ... It was. Thanks for correcting me. Sincerely Mathy 1 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578624 Share on other sites More sharing options...
Faicuai Posted July 4, 2020 Share Posted July 4, 2020 Well if anyone here feels brave enough to take a rasta-conversion shot at the Afhgan girl, here it is, in full glory: And for those that do like PJ - photography, this book is a must have, by many reasons: Let's see what comes out of it... 1 Quote Link to comment https://forums.atariage.com/topic/200118-images-generated-by-rastaconverter/page/109/#findComment-4578680 Share on other sites More sharing options...
