Images generated by RastaConverter
Philsan
1 hour ago, drpeter said:
With @Philsan's 800XL it took only 8 mins from cold for the effect to develop...
Ok, I retimed the whole thing again.
In a nutshell:
  1. The test in post #3216 loses its blue stripe within TWO (2) minutes from power-up.
  2. The REVISED multi-column test in post #3222:
  • begins losing each individual stripe within TWO (2) minutes from power-up, starting with column 1, then 4, then 2 and then 3 (in that order).
  • By minute #5 after power-up, everything has disappeared, leaving only the far-left reference column visible.
That's about it.
Very interesting.  So even (some of?) the oldest GTIAs are subject to a degree of thermal variability in this regard...  (I'm asssuming it's the GTIA, but without applying a heatsink to the chip might be difficult to prove...)
And in the case of your 800, all players are affected.  Does it show a 'preference' between players? In other words, do rectangles of a particular colour tend to disappear within the vertical bands before others, or is it the same across all colours?
It is worth mentioning a couple of things on my test bed, here:
  1. The machine is an 800, Week-4/1980, originally fitted with a CTIA.
  2. I extracted (carefully) the CTIA and stored it safely (so we don't damage it), and installed a GTIA, manufactured around 1981 or 1982, which was supposed to be "new", and part of my spare-parts inventory. (NOTE: I did test that GTIA extensively with multiple diagnostics, including Acid800 v1.2 Beta)
  3. It would be possible to install a functional heat-sink on GTIA, because we could ease the transfer of heat from the chip into the massive RF shield-frame of the 800, instead of simply radiating it inside of the CPU-card chamber provisioned in the shield-frame. We could definitely explore this, but I would need to find a suitable heat-sink for this purpose (have not seen one, yet).
ONLY in terms of the ORDER in which columns begin to disappear.
I will try to record this for you, and post it here... About 3 mins. of net footage (showing actual changes)...
I guess even a small heatsink would slow down or limit the development of the effect, even if it was not entirely prevented (as a proof of concept)
Edited by drpeter
8 minutes ago, drpeter said:
It's amazing that we're uncovering new facts about this hardware after 40 years!
Here it is (should show correctly on, at least, Windows/10 & Edge browser. If not, just download the clip first, and playback on your end):
Please, ignore magnified saturation of colors:
(assuming this effect has never been previously documented anywhere)
Who'd have thought the need for installing heatsinks in these computers would ever arise?! Very interesting deductions over the last few days - well done.
Would be good to hear if anyone else has ever retrofitted heatsinks to any original components on the A8's to alleviate any specific issue. (That reminds me - back in the late 90's I got into overclocking my then AMD K6-2 233mhz based tower PC and made my own water cooled heatsink. (Seriously - ran an aquarium tank and pump into the PC directly into a heatsink of my own design. Seems insane when I look back but it worked surprisingly well at the time! Not planning on doing the same for the A8 mind - bit overkill - although...........heh heh :dunce:)
I'm not sure I'd go so far as to call it a need! The fact that this is such an edge-case in usage presumably largely explains why it's taken 40 years to come out of the woodwork. I wouldn't so much label this as a fault in the GTIA as a previously-undocumented variation in behaviour. The Altirra Hardware Reference Manual already documents at least one other known one.
25 minutes ago, Faicuai said:
Here it is
Astonishing footage!
With respect to the players, the effect develops in the order:
Player 3 (blue)->Player 1 (pink)->Player 2 (mauve)->Player 0 (green/yellow)
Vertically, there is a subtle top->bottom progression
Horizontally, it's as you said- Column 1->Column 4->Column 2->Column 3
All of these overlap somewhat. But the end result is that the last rectangle standing is the bottom green/yellow in Column 3!
Edited by drpeter
sure, fair points. :)
Should have some more images posted tmrw btw.
IMPORTANT update:
This all got me curious, so I fired up one of my 800XLs (they are IDENTICAL, just a few serial #s apart).
The result is that fading begins almost EXACTLY at the same point as my 800 (minute #2, from power up), but progresses instead for an additional 6 minutes (going all the way to a total of 8 minutes).
The fading process and sequence is very similar to the 800, and it ALSO ends in a complete disappearance of all columns, with the only notable exception being that the bottom stripe of Column three is NOT where or how it ends on the 800XL. Instead, the fading takes in groups of equal sizes on that column, and no single stripe is left alone, at the end. They all die together. 8-)
Actually, that's not all entirely true, as bizarrely for Columns 1 & 2 (only) the player order is:
Player 1 (pink)->Player 3 (blue)->Player 2 (mauve)->Player 0 (green/yellow)
Edited by drpeter
11 hours ago, drpeter said:
OK, this is the corrected version....
a8isa1's 1981 800 <--click me
Takes only 1:15 for all the test segments to black out from a cold start.   I needed to flash a cartridge with drpeter_Artefact_Test_3.1.xex otherwise the machine would be mostly warmed up before the test started.
Edited by a8isa1
13 minutes ago, a8isa1 said:
You can see what happens if you click my link.
Sorry, missed that. Definitely subtly different, but I think fits in with the emerging general pattern, but with some significant variations on the theme
Vertically, top->bottom
Horizontally, Column 1->Column 4->Column 2->Column 3
Edited by drpeter
Do you know how to fix this in RastaConverter in the first place?
Perhaps one can detect the specific loads and stores within a 6 cycle window (not too many combinations I think), and then evaluate that particular kernel line as pretty bad in the late hill climbing sense?
the author @ilmenit, and @phaeron who also subsequently worked on it, have indicated on multiple occasions that they don't have the time to go back to RastaConverter and fix the longer-recognised issue with <=5 cycle windows, so I think for the moment we are left with patching the RastaConverter files themselves when glitches occur.  I sadly lack the coding experience to tackle RastaConverter, although it is open source.
Edited by drpeter
