irata0062 Posted August 9, 2012 Share Posted August 9, 2012 Hello, I have tried my Harmony Cartridge with a light 6-switch console but it does not fit with the cart slot. Before I have used it with a vader console and it was working perfect. Now the vader has left this earth (RIP) and I have bought an 6-switch with the a.m. problem. Can anybody help my solving this problem... please! Thanks for your replies! :-) Irata0062 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 9, 2012 Share Posted August 9, 2012 I did as well. I posted my solution here: difficult carts on your sixer? This might help Quote Link to comment Share on other sites More sharing options...
irata0062 Posted August 9, 2012 Author Share Posted August 9, 2012 (edited) Hello and thanks for your help! This might be crazy but I have tipped the box and it worked! But I have the next problem with the harmony cart: The menu screen is running from up to down (looping). When I chose a game it will start with the correct screen after 5 seconds. Does anyone could help me with this... this never happens on my vader! :-( Thanks for your replies! Irata Edited August 9, 2012 by irata0062 Quote Link to comment Share on other sites More sharing options...
+batari Posted August 9, 2012 Share Posted August 9, 2012 Sounds like you are in a PAL region but using an NTSC bios. You can reflash it easily (see the manual). As for fitment, I will write back in a bit about that. Stay tuned. But if tilting the console works, do it Quote Link to comment Share on other sites More sharing options...
+batari Posted August 10, 2012 Share Posted August 10, 2012 (edited) Sounds like you are in a PAL region but using an NTSC bios. You can reflash it easily (see the manual). As for fitment, I will write back in a bit about that. Stay tuned. But if tilting the console works, do it I was on phone and wasn't able to give a detailed reply. The fitment problem is many-fold. Harmony cartridges were conceived as a two-board design, so the main board could be mass-produced to take advantage of the economy of scale, so the same design could work as both Melody and Harmony. For Harmony, a few components could be added to the main board and a daughterboard attached later to create a Harmony. So the idea wasn't perfect. It allowed for the lower price but some things I did not anticipate was that the cart shells were not all created equally, and do not hold the boards in place securely. THe board has to be nearly perfectly-aligned so the dust door will clear the board edge but this proved difficult with the two-board design. There were small issues with the design. A SD card could rotate the board a tad inside the shell (due to torque from the offset daughterboard), throwing it out of alignment (a tiny bit is enough.) THe screw mast hole could have been bigger - it turns out these aren't quite in the same place on all boards. And the last part was that attaching the two boards was an inexact process, even with a jig I made. The board could also have been a tad smaller, and is snapped in with the internal snaps, and these were a little tight. It wasn't so bad that I wanted to issue a recall - the Harmony carts are usually fine. And, the five-figure investment for all of this was already made and would bankrupt me to "fix" ... Until, I ran out of daughterboards. Which I did. So last month I received a new single-board design for Harmony and any unit ordered after about mid-July will have this new design. Advantages are better fitment, smaller cuts (just big enough for SD and USB) and cleaner design, and the single-board is less prone to moving around in the shell when inserting a card. I can post a picture later, or if anyone is going to CGE, I will bring a few Harmony carts there if you want to see them. I will be wearing a Harmony t-shirt Edit: there is a way to fix a Harmony that uses a two-board design. It involves applying a little hot glue between the metal backing of the SD slot and the inside of the shell while the cart is inserted. Just a warning though, if you get glue on the side of the slot or inside, it can jam up the mechanism. I may post a tutorial sometime. Edited August 10, 2012 by batari Quote Link to comment Share on other sites More sharing options...
