cimerians Posted August 13, 2012 Share Posted August 13, 2012 Ok I tried their forums but it seems nobody seems to know anything about this issue so I return to reliable Atari Age and hope someone has a little advice. Black Screen issue: I have all the BIOS files from my PS2 and even tried renaming them to .rom1, rom2 etc. The issue is a black screen when running an ISO of a game. One thing I noticed is when I click on Config-->Plugin\Bios selector I see the following error appear on the console window: Path: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\gsdx32-avx-r5350.dll File is not a valid dynamic library. Some kinda plugin failure: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\gsdx32-avx-r5350.dll The plugin and DLL file of course are there as this is the default install. I have installed PCSX2 on my D: drive to avoid rights issues and have also tried running it as admin. I read somewhere about compatability issues with Intel chips and Graphics cards using GSDX but pretty sure my i7 and Nvidia 580 are ok. I switched to SSE2, SSE41 and SSSE3 and same issue. Now I'm thinking it may be the BIOS files. I run Win7 64. Here's a copy of the log: PCSX2 1.0.0.r5350 - compiled on Aug 1 2012 Savestate version: 0x9a080000 Host Machine Init: Operating System = Microsoft Windows 7 Service Pack 1 (build 7601), 64-bit Physical RAM = 16375 MB CPU name = Intel® Core™ i7 CPU 960 @ 3.20GHz Vendor/Model = GenuineIntel (stepping 05) CPU speed = 3.206 ghz (8 logical threads) x86PType = Standard OEM x86Flags = bfebfbff 0098e3bd x86EFlags = 28100000 x86 Features Detected: MMX.. SSE.. SSE2.. SSE3.. SSSE3.. SSE4.1.. SSE4.2 Reserving memory for recompilers... Loading plugins... Binding GS: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\gsdx32-sse4-r5350.dll Windows 6.1.7601 (Service Pack 1 1.0) NVIDIA GeForce GTX 580 (8.17.13.142) Binding PAD: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\lilypad-r5350.dll Binding SPU2: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\SPU2-X.dll Binding CDVD: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\cdvdGigaherz.dll Binding USB: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\USBnull.dll Binding FW: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\FWnull.dll Binding DEV9: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\DEV9null.dll Plugins loaded successfully. (GameDB) 9640 games on record (loaded in 154ms) Path: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\gsdx32-avx-r5350.dll File is not a valid dynamic library. Some kinda plugin failure: D:\Library\Video Games\PS2\Emulation\PCSX2 1.0.0\Plugins\gsdx32-avx-r5350.dll Bios Found: USA v02.20(05/09/2006) Console Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 13, 2012 Share Posted August 13, 2012 (edited) I have it working under the same OS. Assuming I remember, I'll check this out later & see what I'm doing that you aren't. edit: I have similar hardware too (Q6600 & GTX 9800), so I doubt hardware is the issue. I do know that my copy of the emulator is several months older than yours, so maybe try one from June or so in the meantime? Edited August 13, 2012 by Rex Dart Quote Link to comment Share on other sites More sharing options...
cimerians Posted August 14, 2012 Author Share Posted August 14, 2012 Good idea thanks. I'll try an earlier build and maybe redump the BIOS files but it seems more of a graphics issue than anything else. Ugh...... Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 14, 2012 Share Posted August 14, 2012 (edited) What game is it? Here's my log, if it's any help: ****User's GPU/RAM/CPU Information**** GPU Name: NVIDIA GeForce 9800 GTX+ -2 MB<Minimum Specs PCSX2 0.9.8.r4600 - compiled on Apr 27 2011 Savestate version: 0x9a010000 Host Machine Init: Operating System = Microsoft Windows 7 Ultimate Edition (build 7600) 64-bit Physical RAM = 4094 MB CPU name = Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Vendor/Model = GenuineIntel (stepping 0B) CPU speed = 2.399 ghz (4 logical threads) x86PType = Standard OEM x86Flags = bfebfbff 0000e3bd x86EFlags = 20100000 x86 Features Detected: MMX.. SSE.. SSE2.. SSE3.. SSSE3 Reserving memory for recompilers... Loading plugins... Binding GS : D:\games\emu\PS2\plugins\771svn GSdx 1.8 sse2.dll Binding PAD : D:\games\emu\PS2\plugins\lilypad-r4600.dll Binding SPU2 : D:\games\emu\PS2\plugins\spu2-x-r4600.dll Binding CDVD : D:\games\emu\PS2\plugins\cdvdGigaherz.dll Binding USB : D:\games\emu\PS2\plugins\USBnull.dll Binding FW : D:\games\emu\PS2\plugins\FWnull.dll Binding DEV9 : D:\games\emu\PS2\plugins\DEV9null.dll Plugins loaded successfully. (GameDB) 9082 games on record (loaded in 478ms) ****PCSX2 Configuration**** [interface] Output(Console) Enabled = True App Priority = Normal [Plugins] GS=GSdx9.dll -Plugin Not Implemented Yet SPU2=SPU2null.dll CDVD=CDVDnull.dll PAD1=LilyPad.dll PAD2=PadSSSPSX.dll DEV9=DEV9null.dll USB=USBnull.dll FW=FWnull.dll [Cpu Options] Frame L. = Limit -Custom FPS = 60 EERec on = True VU1rec on = True VU0rec on = True DC on = True MTGS on = True [Misc] Patches on = True Hacks -Disable ABS hack = True -EE/IOP SYNC hack = True -Tighter SPU2 Sync = False Report Created: 08-13-2012 Ver:1.12 Edited August 14, 2012 by Rex Dart Quote Link to comment Share on other sites More sharing options...
cimerians Posted August 14, 2012 Author Share Posted August 14, 2012 Cool...I still haven't gotten it to work but at least I can reference your config. I'll be doing another report today when I get home and compare it more closely. One thing I did notice is that even though I'm running PCSX2 0.9.8.r4600 like you are....the binding for GS is different for me. Another thing is that with version 0.9.8 I no longer get any errors in the console. Everything looks ok but when running a game its still just a black screen. I tried two different games that were on the compatability list (ripped the CD's using IMGburn). Anyway I'll play around with the settings again tonight and maybe redump those BIOS files as a last resort. Binding GS : D:\games\emu\PS2\plugins\771svn GSdx 1.8 sse2.dll Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 14, 2012 Share Posted August 14, 2012 (edited) Yeah, I don't think my CPU supports SSE4 instructions. SSE2 seems like a good fallback. I also have so many BIOS files in my BIOS directory, I don't know which corresponds to which in the in-app menu. I'd send you my working files, but I can't identify 'em. I could send the whole 12MB mess if you think it might help. edit: I guess I could zip the entire directory, since it seems self-contained. Edited August 14, 2012 by Rex Dart Quote Link to comment Share on other sites More sharing options...
cimerians Posted August 14, 2012 Author Share Posted August 14, 2012 Yeah, I don't think my CPU supports SSE4 instructions. SSE2 seems like a good fallback. I also have so many BIOS files in my BIOS directory, I don't know which corresponds to which in the in-app menu. I'd send you my working files, but I can't identify 'em. I could send the whole 12MB mess if you think it might help. edit: I guess I could zip the entire directory, since it seems self-contained. Cool I'll try them if you can zip them up or somehing. However you want. When I dumped mine (I have a modded slim PS2) it didnt show any errors during the dump but I saw the files didnt exactly match what it says on their FAQ. Like they say ROM1, ROM2 and I had ROM0 and ROM1. Plus there some others in there I have no idea what they are. Possibly a file for the PS2CD drive and another for something else. I just put them all in the BIOS folder and it liked it. Quote Link to comment Share on other sites More sharing options...
