GratedTopping Posted August 25, 2012 Share Posted August 25, 2012 (edited) I can't get this to work properly in "Classic99". I haven't tried it in any other emulator. It allows you to chose a border and screen color that will remain in programming mode, even through a NEW command. I found it in November 1985's "MICROpendium". For me, the border color changes properly to my choice, but the screen color is off. Note that I did edit this a bit (including an ON WARNING NEXT, for example), but certainly didn't change any of the CALL LOAD statements. I've gone over it a lot in the mag and can't figure it out. Does anybody have a working copy or know what's wrong? Maybe a correction was published in a later MICROpendium...or "Classic99" just messes-up with it? 1 ! 2 ! XB SCREEN COLOURS 3 ! 4 ! (CHANGES YOUR SCREEN DISPLAY TO YOUR CHOICE OF COLOURS WHILE IN COMMAND MODE) 5 ! 6 CALL CLEAR :: ON WARNING NEXT 7 INPUT "BORDER COLOR? (1-16): ":A 8 IF A<1 OR A>16 THEN 7 9 INPUT "SCREEN COLOUR? (1-16): ":B 10 IF B<1 OR A>16 THEN 9 11 CALL CLEAR 12 C=(B-1)+(A-1) 13 CALL INIT :: CALL LOAD(9984,C,C,C,C,C,C,C,C,2,0,7,15+A,4,32,32) 14 CALL LOAD(9999,48,2,0,8,0,2,1,39,0,2,2,0,8,4,32,32,36,2,0,8,8,4) 15 CALL LOAD(10021,32,32,36,2,0,8,16,4,32,32,36,2,0,8,24,4,32,32,36,4,91) 16 CALL LOAD(-31804,39, :: CALL LOAD(-31952,255,231,255,231) NOTE: in line 16, that's an 8 in the first CALL LOAD, but I see it's turning up as a smiley face. . . Edited August 25, 2012 by GratedTopping Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 25, 2012 Share Posted August 25, 2012 Does anybody have a working copy or know what's wrong? Maybe a correction was published in a later MICROpendium...or "Classic99" just messes-up with it? My guess is that one of the colors (probably the screen color B) needs to be shifted to the high nybble. You can do this by multiplying by 16: 12 C=(B-1)*16+(A-1) ...lee Quote Link to comment Share on other sites More sharing options...
GratedTopping Posted August 25, 2012 Author Share Posted August 25, 2012 With that change, it did make it interesting and a bit different. Choosing the 'border color' results in the entire screen being the color of choice. Choosing the 'screen color' makes the text the color of choice. I remember there being a different program somewhere in one of the magazine's issues where it had this purpose specifically. Quote Link to comment Share on other sites More sharing options...
GratedTopping Posted August 25, 2012 Author Share Posted August 25, 2012 On my first try, I did a little change and it worked to my surprise: 12 C=(B-1)+16*(A-1) Of course, I don't understand why, but now the program does as was intended. Your border and screen colours are different. Thanks, Lee, for your assistance. I like your modification, too, and I figure I'll alter the program to allow a person to choose any option. With your change, the text can be a different color; with mine/the original program, the text is the color of the border. Quote Link to comment Share on other sites More sharing options...
Willsy Posted August 25, 2012 Share Posted August 25, 2012 Line 10 is wrong (though it won't have any effect unless you input stupid values. Should be: IF B<1 OR B>16 THEN 9 Quote Link to comment Share on other sites More sharing options...
GratedTopping Posted August 25, 2012 Author Share Posted August 25, 2012 Yes, that was a typo of mine in line 10. That line, and line 8, were added by myself anyway. Line 12 was the key to the problem and was apparently printed incorrectly in the magazine. Quote Link to comment Share on other sites More sharing options...
matthew180 Posted August 26, 2012 Share Posted August 26, 2012 Of course, I don't understand why, but now the program does as was intended. Do you understand how the colors are specified for the tile groups? You need to understand a few key concepts to realize what is going on and take the guessing out of getting the colors you want: * A byte is 8-bits and has a *range* of values from 0-255, and 256 total *number* of values. * 4-bits is a nybble (or nibble), and that 4-bits can store a value *range* from 0 to 15 (or >0 to >F hex), and 16 total *number* values. * That there are two nybbles in a byte. * That the 99/4A has 16 possible colors, so each nybble in a byte can store a color value. * That the 99/4A has 256 tiles, and for specifying color the tiles are grouped into 32 groups of 8 tiles. There is a color table in the VRAM that uses 1-byte per group of tiles, and the high-nybble in the byte specifies the foreground color for the tile group, and the low-nybble specifies the background color for the tile group. The foreground color will be displayed if the tile's pattern has a '1', and the background color will be displayed if the tile's pattern has a '0'. This is a very important concept, because a '0' pattern bit DOES NOT mean the pixel is transparent! The '0' bit means "show the background color", which *could be* set to transparent, but typically not. For example, tile 32, the 'space' character, has all a pattern of all '0' bits, so the space tile will always show the background color set for the 4th tile group. However, the border (and screen background) color is set with a separate register in the VDP. So now you have two "layers" to think about. If you set the "screen background" color to green, then the border will be green. If you fill the screen with a tile, say the 'space' character, then the display area of the screen will be whatever color is set as the *background* color for the 4th tile-group (which is the group that contains tiles 32-39). If the background color for the 4th tile group is red, then you will have a green border with a red center. If you want to see the screen background through the tiles, you have to set the tile group's background color to *transparent*. Then the foreground color (pattern bits set to '1') will show, and the '0' bits will show the screen background color. Quote Link to comment Share on other sites More sharing options...
GratedTopping Posted August 29, 2012 Author Share Posted August 29, 2012 Thanks, 'matthew180'; I never did learn any assembly/CALL LOAD information back in the day and such information is interesting. Quote Link to comment Share on other sites More sharing options...
