gardenmaniac Posted November 25, 2012 Share Posted November 25, 2012 So.. just got my flashback 2 I purchased on ebay & one of the joysticks doesn't work..there were no instructions, I found them online thru a link on here. The screen comes up Adventure games or something & you have to use the joystick to choose a game.. so I hooked up one & nothing happened at all.. hooked up the other one & that works fine.. any suggestions? Quote Link to comment Share on other sites More sharing options...
oldjd Posted November 25, 2012 Share Posted November 25, 2012 Contact the seller.They have to offer a return policy-ebay rules. Quote Link to comment Share on other sites More sharing options...
gardenmaniac Posted November 26, 2012 Author Share Posted November 26, 2012 I did send a message to the seller.. hopefully I get some response Quote Link to comment Share on other sites More sharing options...
RickR Posted November 26, 2012 Share Posted November 26, 2012 A partial refund is in order. Quote Link to comment Share on other sites More sharing options...
gardenmaniac Posted November 26, 2012 Author Share Posted November 26, 2012 Sellers has offered to refund "when she gets funds back into her paypal acct".. hmmm... Quote Link to comment Share on other sites More sharing options...
gardenmaniac Posted November 26, 2012 Author Share Posted November 26, 2012 can the joystick be repaired? Quote Link to comment Share on other sites More sharing options...
RickR Posted November 26, 2012 Share Posted November 26, 2012 Maybe. If all directions and the button are broken, could be a problem with the wire or connector. Keep in mind that any 2600 joystick/paddles will work with the FB2. If you have any others lying around, or see any at your local thrift store, they will work fine. Quote Link to comment Share on other sites More sharing options...
thevnaguy Posted November 26, 2012 Share Posted November 26, 2012 can the joystick be repaired? They are not that hard to repair. Just use a meter to check continutity in the wires from the plug to the joystick, then check for a any broken solder connections on the circuit board inside. Most likely if nothing is working the Ground wire is broken. Quote Link to comment Share on other sites More sharing options...
