Does Atarisoft Play On TI-99 4/A?
thegamezmaster
Yes, as a general rule, the Atarisoft titles are playable on beige 99/4A consoles. There were a certain quantity of later 99/4A units which contained firmware that locked out third-party cartridge titles; these have a "V2.2" version number visible on the title screen. However, I've owned several beige 99/4A consoles over the years, purchased from many different sources, and I have yet to encounter one with this problematic firmware, so I think these consoles are scarce enough that you don't have to worry. Even if you are stuck with one, the 99/4A is a common enough machine that it's still pretty easy to find a replacement.
And if you do turn up one of the V2.2 consoles, try and locate a Navarone GROM Buster. It will let you run any third-party cartridge that the V2.2 OS has issues with (it looks for a GROM and if it doesn't find one, it ignores the cartridge). The GROM Buster is a bit HTF, but it works well (I have one for my V2.2 consoles).
Never knew about this. Thanks.
  • 1 month later...
If you use my xbasic loader from the DSK image and ARK file, make sure you protect the first file of each game so it can create the catalog. So if the files are Pacman and Pacmao protect Pacman etc..
Greg
You can download the atarisoft games on "disk" at ftp://ftp.whtech.com/games/Atarisoft/ and copies of the manuals..
There is also a beta ver of robotron floating around but it's not on disk just a ROM image. I load it in my Gram Kracker on the real 4/a.
Greg
Another fix is to use a broken silver 99/4A with good GROMs (hopefully) in it. Just do a pull and replace them in the beige unit. I hope someone can respond in the order they are to be replaced -- as my gray matters is a little too grey and rusty now to remember fully. Try an internet search for the TI-99/4A motherboard schematic -- there should be three chips grouped together with TI markings. I think you need just one chip (GROM-0), but replacing all three won't hurt. Keep them in order by the labeling on the chips, and replace the same way. The socket grouping may be twisted 90 degress from the two motherboards ( = || ).
TI did sell the GROMs individually for quite a few years after 1983. A product price list of available part numbers was sent to quite a few User Groups. This lasted till about 1988-90. There were quite a few hardware projects available in the TI-UserGroup Newsletters back then. The most popular being a 8K SuperCart built using the board from a MunchMan or Parsec cartridge. Most boards that used a GROM and ROM combo worked. An Editor-Assembler GROM; 8K SRAM; along with some other parts were needed for the project. Later a battery backup option (CR2032) was added. The extra 8K (>6000->7FFF) along with the 32K (>2000->3FFF;>A000->FFFF) gave the TI-99 a nice boost in programmable space.
  • 3 weeks later...
Greg
Could you be so kind as to describe the procedure in detail so I might do so as well?
Procedure to download the disks or load robotron in a gram kracker?
Disks you go to the link below and download the DSK images, you can then use them with emulation or use tidir or ti99pc to extract files and send them to your TI with a serial cable and Xmodem OR with HDX (which rocks btw) and or copy to a floppy on your PC if you have the same kind of drive in both using TI99PC.. both of these utilities are on ftp.whtech.com, TIDIR is in the fredkaal directory and ti99pc is in the pc utilities dir.. http://ftp.whtech.com is a nice http interface.
I uploaded the GK images to robotron to the same directory as the atarisoft games too.. If you have a gram kraker you just need to get the files to the TI and then load them using the module load screen.
Let me know if you have any more questions (with specifics) happy to help.
Greg
Greg
Sorry, I seemed to had lost this thread to my feeble memory. Firstly, thanks for the reply. I looked for the files you spoke of, especially the robotron GK image but could only find PDF files on there under games. I'd love to know how to get robotron, either the normal rom or the two joystick hack, to work on actual hardware. I do have a GK but it's been so long since I've used it I can't even remember how to operate the damn thing. I have a CF7 as well. If I remember correctly the CF7 will only work with dsk images and not roms.
http://ftp.whtech.com/games/Atarisoft/atarisoft.ark has all of the games EXCEPT robotron in a TI archiver format tifiles file.
Looking and either I didn't upload robotron correctly or someone removed it.. I'll upload it again to that directory. GK is pretty easy, you plug it in, flip the switches to middle, down, down, middle, up and turn on your TI, pick GK from the menu, select (1) load module, enter the file name for the robotron first file in the chain.. and turn off/on write protect switch as prompted. once it's loaded hit reset, then turn off the GK with the right switch and you should have the robotron cart on the cart menu after the title screen.
Greg
Greg
ftp://ftp.whtech.com/games/Atarisoft/ shows the uploads.. guess the HTTP doesn't show it.. i'll email the site and see what the heck :)
Greg
http://ftp.whtech.co...t/atarisoft.ark has all of the games EXCEPT robotron in a TI archiver format tifiles file.
Greg
Greg
Greg
Thanks. I dl'ed it from the above link. Being a dsk file I should be able to load it onto the CF7. Now I only have to remember how to work that. :P Time to read the directions again. I haven't loaded anything onto it in a couple years.
easiest way?
Tidir on the PC, open the dsk on one side and the backup of your cf card on the right side, then copy things in, restore to cf card.. takes mine about 3 years to restore ftp.whtech.com/fredkaal for tidir if you don't have it
Greg
  • 10 months later...
I have a v2.2 beige unit and would like to do this. Do you know if all TI99/4A units had the GROMS socketed? Or will this involve desoldering? I have not opened my TI99/4A yet, but figured I'd ask.
