ti99iuc Posted December 21, 2012 Share Posted December 21, 2012 Hi ! maybe someone can help me to understand why... i have a TI BASIC program on cassette tape about christmas music player. i must load this program on a real TI99 and save it on the Floppy Disk. now the problem is that i be able to load it without PEB connected... when the PEB is connected the loading stop after the first long whistle... if i connect the PEB without the disk controller card the program load right... any idea for helping me ? Thank you Ciro. Quote Link to comment Share on other sites More sharing options...
unhuman Posted December 21, 2012 Share Posted December 21, 2012 It's possible that the basic program uses too much memory. When the hard drive is plugged in, it does take away a small amount of memory. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted December 21, 2012 Author Share Posted December 21, 2012 Oh.... well... have i a chance to save this program on disk ? what you think about ? any idea ? i'm using the CorComp 9900 controller... maybe i could try with the TI Controller ? Quote Link to comment Share on other sites More sharing options...
unhuman Posted December 21, 2012 Share Posted December 21, 2012 Depends on if you're hitting the memory limit. If it loads and runs w/o the disk adapter... The question then becomes does it use the high-order charsets (15 and 16) that are unavailable to XB If you have XB + Memory + disk controller then you might be able to load and save it and just play it under XB. Quote Link to comment Share on other sites More sharing options...
OX. Posted December 21, 2012 Share Posted December 21, 2012 (edited) In Gamebase TI99 there are a few ex-cassette only games that have transfered to disk and have to be loaded using this technique as without the disk controller attached cassette only games have a little extra memory available that the disk controller would otherwise use :- Use Mini Memory module + expanded memory Select TI BASIC CALL INIT CALL FILES(1) OLD DSK1.[program] (Replace with OLD CS1) SAVE EXPMEM2 CALL LOAD(-31888,63,255) NEW OLD EXPMEM2 RUN (Replace with SAVE DSK1.[program]) You could try using this but save it to disk instead of running the program. Edited December 21, 2012 by OX. Quote Link to comment Share on other sites More sharing options...
RXB Posted December 21, 2012 Share Posted December 21, 2012 Ok here is a trick I use for old TI Basic programs that used to much memory to use the disk controller. 1. Do not hook up the Disk Controller so memory is there 2. Do a CALL FILES(1) to give yourself the most memory. 3. OLD CS1 4. LIST "CS1" 5. Turn off computer and hook up Disk Controller. 5. Run this program: 100 OPEN #1:"CS1",INPUT,DISPLAY,VARIABLE 80 200 OPEN #2:"DSK1.LIST",OUTPU,DISPLAY, VARIABLE 80 300 LINPUT #1: X$ 400 OUTPUT #2:X$ 500 IF EOF(1)<>0 THEN 700 600 GOTO 300 700 CLOSE #1 800 CLOSE #2 900 END This will copy the CS1 listing from cassette to Disk and then you can have the program to look at. This is the trick I used to copy all of my programs I wrote on cassette to disk. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted December 22, 2012 Author Share Posted December 22, 2012 Ok here is a trick I use for old TI Basic programs that used to much memory to use the disk controller. 1. Do not hook up the Disk Controller so memory is there 2. Do a CALL FILES(1) to give yourself the most memory. 3. OLD CS1 4. LIST "CS1" 5. Turn off computer and hook up Disk Controller. 5. Run this program: Hi ! just for understand... CALL FILES (1) give me an error without Disk Controller active... so i can't do anything... and more when i turn off the computer all i have done before will be lost !? ... can you explain better please ? Thank you Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted December 22, 2012 Author Share Posted December 22, 2012 Use Mini Memory module + expanded memory Select TI BASIC CALL INIT CALL FILES(1) OLD DSK1.[program] (Replace with OLD CS1) No Way OX, at OLD CS1 and after the starting long whistle the loading stop with the classic error... if i load the program without Disk Controller it start ! something else ? Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 22, 2012 Share Posted December 22, 2012 This program likely uses ALL of the memory available to it under console BASIC. If CALL FILES(1) won't work, you can always try to load the program without a disk controller, edit it to cut out the last 3K or so and save it to tape that way. Load that back from tape once you've reconnected the disk controller--it should load and now save it to disk. You're still missing the last 3K though. Now disconnect the disk controller again and load the original, unmodified program. Now cut out the part tou've saved to disk, leaving the missing 3K in memory. Save it to tape in MERGE format. Reconnect the Disk controller and load the part of the program on disk using Extended BASIC. Look for any TI BASIC incompatibilities. If there are none (or even if there are, at this point), Merge the 3K file into the program from tape. Save the whole program to disk (it will now be in INT/254 format instead of PROGRAM). That will recover it--now you just have to see if it will run or if it needs to be modified somehow for Extended BASIC. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted December 22, 2012 Author Share Posted December 22, 2012 Ok, i will try to do this... i will split the program in two parts and will save all in hxc SD... after, i will do the merging using tiDIR and Classic99 !! i'll come back with the news Thank you for suggestion ksarul Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 22, 2012 Share Posted December 22, 2012 One note, you might have to limit the delete to a single line at first to free up enough memory to work with. . . Quote Link to comment Share on other sites More sharing options...
RXB Posted December 22, 2012 Share Posted December 22, 2012 (edited) Hi ! just for understand... CALL FILES (1) give me an error without Disk Controller active... so i can't do anything... and more when i turn off the computer all i have done before will be lost !? ... can you explain better please ? Thank you Sorry I always had the Mini memory Module plugged into my TI back then. But the rest of what I suggested works with out a Mini Memory system and will transfer fine. Edited December 22, 2012 by RXB Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted December 22, 2012 Author Share Posted December 22, 2012 (edited) Well, i tried with minimemory plugged in too but the program stop the loading after whistle.... the same .. CALL FILES (1) without Controller Card activated give me an error... Edited December 22, 2012 by ti99userclub Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 23, 2012 Share Posted December 23, 2012 CALL FILES depends on the controller being present. The method I described does not require you to do that. Since the tape loads, you should be able to edit the file while it is in memory and do as I explained above, unless the program is also protected from listing. . . Quote Link to comment Share on other sites More sharing options...
RXB Posted December 23, 2012 Share Posted December 23, 2012 CALL FILES depends on the controller being present. The method I described does not require you to do that. Since the tape loads, you should be able to edit the file while it is in memory and do as I explained above, unless the program is also protected from listing. . . Oh he might have a protected program so would have to have a Mini Memory to do a CALL LOAD to fix that problem of editing or saving or listing the file. Quote Link to comment Share on other sites More sharing options...
