Willsy Posted January 2, 2013 Share Posted January 2, 2013 I hope people are doing LOTS of TI coding over the Christmas and New Year holidays! Quote Link to comment Share on other sites More sharing options...
OX. Posted January 2, 2013 Share Posted January 2, 2013 I was wishing that Manic Miner and H.E.R.O ready for release in time for xmas. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 3, 2013 Share Posted January 3, 2013 My New Year resolution is to dig up Ultimate Planet and finish it by Faire time in November I'm just balking a bit at the time needed to re-familiarize myself with the voluminous code. I'll just have to abide by Captain Picard's "Make it so!" Quote Link to comment Share on other sites More sharing options...
unhuman Posted January 4, 2013 Share Posted January 4, 2013 At my real job - we're wrapping up something awesome (you'll see it soon!) and after that - hopefully - there will be somewhat of a reprieve. I've got a partially finished XB game (see my Avatar) that wasn't working out - but maybe it will under the compiler... -H Quote Link to comment Share on other sites More sharing options...
+hloberg Posted January 4, 2013 Share Posted January 4, 2013 Before I start my big project of MULE (see other topic) I plan to do UNO in XB and finish up a multi-player XB game I started many years ago. 1 Quote Link to comment Share on other sites More sharing options...
lucien2 Posted January 4, 2013 Share Posted January 4, 2013 (edited) Instead of working on my 3 unfinished games, I ported this XB program CRISTAUX.zip from my father to VB.NET. I tried to make a reusable TI99 class. Only basic graphics are implemented, no sprites, no sound, no files. VB.NET library.zip Here is the code. Sorry for the french names Public Class TI99 Private couleurs(32) As Byte Private motifs(256 * As Byte Private écran(32 * 24) As Byte Private couleur_fond As Couleur Private accueil As Boolean Private offset_caractères As Byte Protected sélection(32 * 24) As Boolean Private WithEvents timer1 As New Timer Private sélection_inversée As Boolean Public Event Clic(ByVal x As Integer, ByVal y As Integer) Public Event Touche(ByVal e As Windows.Forms.KeyEventArgs) Public Event Start() Private tâche As Threading.Thread Public semaphore As New Threading.Semaphore(0, 1) Private à_afficher As Boolean Private WithEvents timer2 As New Timer Private attendre As Boolean Protected vitesse As Integer Protected compteur_attentes_affichage As Integer Private nombre_attentes_affichage As Integer Protected lecture_sons As New Media.SoundPlayer Protected message_affiché As Boolean Private touche_pressée As Boolean Public Enum Couleur Transparent Noir VertMoyen VertClair BleuFoncé BleuClair RougeFoncé Cyan RougeMoyen RougeClair JauneFoncé JauneClair VertFoncé Magenta Gris Blanc End Enum Private valeurs_couleurs() As Color = { _ Color.FromArgb(0, 0, 0), _ Color.FromArgb(0, 0, 0), _ Color.FromArgb(33, 206, 66), _ Color.FromArgb(90, 222, 123), _ Color.FromArgb(82, 82, 239), _ Color.FromArgb(123, 115, 255), _ Color.FromArgb(214, 82, 74), _ Color.FromArgb(66, 239, 247), _ Color.FromArgb(255, 82, 82), _ Color.FromArgb(255, 123, 123), _ Color.FromArgb(214, 198, 82), _ Color.FromArgb(231, 206, 132), _ Color.FromArgb(33, 181, 57), _ Color.FromArgb(206, 90, 189), _ Color.FromArgb(206, 206, 206), _ Color.FromArgb(255, 255, 255) _ } Private Sub TI99_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load accueil = True Initialiser() Afficher() ChangerVitesse(0) Beep() End Sub Private Function StringToByteList(ByVal s As String) As List(Of Byte) Dim b As New List(Of Byte) Dim c(2) As Char c(0) = vbCrLf c(1) = " " Dim ls() As String = s.Split(c, StringSplitOptions.RemoveEmptyEntries) For Each s2 As String In ls Try b.Add(Byte.Parse(s2, Globalization.NumberStyles.HexNumber)) Catch ex As Exception End Try Next Return b End Function Public Sub CallClear() For i As Integer = 0 To 32 * 24 - 1 écran(i) = 32 + offset_caractères Next End Sub Private Sub Initialiser() Dim b As New Bitmap(32 * 8, 24 * pb_écran.Image = b couleurs = StringToByteList(My.Resources.couleurs_gpl).ToArray motifs = StringToByteList(My.Resources.patterns_gpl).ToArray CallScreen(Couleur.Cyan) CallClear() AfficherAccueil() End Sub Private Sub Afficher(ByVal x As Integer, ByVal y As Integer) Dim bmp As Bitmap = pb_écran.Image Dim c As Byte = écran(x + y * 32) Dim fci As Couleur = couleurs(c \ >> 4 Dim bci As Couleur = couleurs(c \ And 15 If fci = Couleur.Transparent Then fci = couleur_fond End If If bci = Couleur.Transparent Then bci = couleur_fond End If Dim fc As Color = valeurs_couleurs(fci) Dim bc As Color = valeurs_couleurs(bci) For i As Integer = 0 To 7 For i2 As Integer = 0 To 7 Dim b As Boolean = motifs(c * 8 + i) >> (7 - i2) And 1 If sélection(x + y * 32) And sélection_inversée Then b = Not b End If If b Then bmp.SetPixel(x * 8 + i2, y * 8 + i, fc) Else bmp.SetPixel(x * 8 + i2, y * 8 + i, bc) End If Next Next End Sub Public Sub Afficher() For x As Integer = 0 To 31 For y As Integer = 0 To 23 Afficher(x, y) Next Next pb_écran.Invalidate() End Sub Public Sub CallHChar(ByVal y As Integer, ByVal x As Integer, ByVal c As Byte, ByVal n As Integer) For i As Integer = 1 To n écran(x - 1 + (y - 1) * 32) = c + offset_caractères x = x + 1 If x > 32 Then x = 1 y = y + 1 End If Next Invalider() End Sub Public Sub CallHChar(ByVal y As Integer, ByVal x As Integer, ByVal c As Byte) CallHChar(y, x, c, 1) End Sub Public Sub DisplayAt(ByVal y As Integer, ByVal x As Integer, ByVal s As String) Dim e As New System.Text.ASCIIEncoding Dim b(s.Length) As Byte e.GetBytes(s, 0, s.Length, b, 0) For i = 0 To s.Length - 1 écran(x + 1 + (y - 1) * 32) = b(i) + offset_caractères x = x + 1 If x > 28 Then x = 0 y = y + 1 End If Next Invalider() End Sub Private Sub BarreAccueil(ByVal y As Integer) Dim c As Byte = &H60 For i As Integer = 0 To 15 For i2 As Integer = 0 To 2 écran((y + i2) * 32 + i * 2) = c écran((y + i2) * 32 + i * 2 + 1) = c Next c = c + 8 Next End Sub Private Sub AfficherAccueil() BarreAccueil(0) For c As Byte = 1 To 3 écran(5 * 32 + 14 + c) = c Next For c As Byte = 4 To 6 écran(6 * 32 + 14 + c - 3) = c Next For c As Byte = 7 To 9 écran(7 * 32 + 14 + c - 6) = c Next DisplayAt(10, 7, "TEXAS INSTRUMENTS") DisplayAt(12, 9, "HOME COMPUTER") DisplayAt(17, 1, "READY-PRESS ANY KEY TO BEGIN") BarreAccueil(18) écran(22 * 32 + 4) = &HA DisplayAt(23, 4, "1981 TEXAS INSTRUMENTS") End Sub Public Sub CallScreen(ByVal c As Couleur) BackColor = valeurs_couleurs(c) couleur_fond = c Invalider() End Sub Private Sub QuitterAccueil() Beep() accueil = False offset_caractères = &H60 motifs = StringToByteList(My.Resources.patterns_basic).ToArray For i As Integer = 0 To 31 couleurs(i) = &H10 Next CallClear() timer1.Interval = 200 timer1.Start() RaiseEvent Start() End Sub Private Function CaractèreClic(ByVal pt As Point) As Point pt.X = CSng(pt.X) * pb_écran.Image.Width / pb_écran.Width \ 8 + 1 pt.Y = CSng(pt.Y) * pb_écran.Image.Height / pb_écran.Height \ 8 + 1 Return pt End Function Private Sub TraiterClic(ByVal pt As Point) If accueil Then QuitterAccueil() RaiseEvent Start() Else pt = CaractèreClic(pt) RaiseEvent Clic(pt.X, pt.Y) End If End Sub Private Sub TI99_MouseClick(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles Me.MouseClick If accueil Then TraiterClic(e.Location) End If End Sub Private Sub TI99_KeyDown(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles Me.KeyDown If Not touche_pressée Then If accueil Then QuitterAccueil() Else RaiseEvent Touche(e) e.Handled = True End If End If touche_pressée = True End Sub Private Sub TI99_KeyUp(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles Me.KeyUp touche_pressée = False End Sub Private Sub pb_écran_Click(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles pb_écran.MouseClick TraiterClic(e.Location) End Sub Public Sub CallChar(ByVal c As Byte, ByVal s As String) c = c + &H60 For i As Integer = 0 To 7 motifs(c * 8 + i) = Byte.Parse(s.Substring(i * 2, 2), _ Globalization.NumberStyles.HexNumber) Next Invalider() End Sub Public Sub Sélectionner(ByVal x As Integer, ByVal y As Integer) sélection(x - 1 + (y - 1) * 32) = True End Sub Public Sub Désélectionner(ByVal x As Integer, ByVal y As Integer) sélection(x - 1 + (y - 1) * 32) = False End Sub Public Function AucuneSélection() As Boolean For x As Integer = 0 To 31 For y As Integer = 0 To 23 If sélection(x + y * 32) Then Return False End If Next Next Return True End Function Private Sub timer1_Tick(ByVal sender As Object, ByVal e As System.EventArgs) Handles timer1.Tick sélection_inversée = Not sélection_inversée If Not AucuneSélection() Then Afficher() End If End Sub Public Sub CallGChar(ByVal y As Integer, ByVal x As Integer, ByRef c As Byte) c = écran(x - 1 + (y - 1) * 32) - offset_caractères End Sub Public Sub ToutDésélectionner() For i As Integer = 0 To 32 * 24 - 1 sélection(i) = False Next End Sub Public Function Asc(ByVal s As String) As Byte Dim e As New System.Text.ASCIIEncoding Dim b(s.Length) As Byte e.GetBytes(s, 0, s.Length, b, 0) Return b(0) End Function Private Function Arrêté() As Boolean Return tâche Is Nothing OrElse Not tâche.IsAlive End Function Public Sub Démarrer() If Arrêté() Then timer2.Start() tâche = New Threading.Thread(AddressOf TâcheMain) tâche.Start() End If End Sub Private Sub TâcheMain() Try Main() Catch ex As Threading.ThreadAbortException End Try End Sub Public Overridable Sub Main() End Sub Public Sub Invalider() If Not Arrêté() Then à_afficher = True If (vitesse < 5 Or compteur_attentes_affichage > nombre_attentes_affichage) _ And vitesse < 10 Or message_affiché Then attendre = True compteur_attentes_affichage = 0 semaphore.WaitOne() Else If vitesse < 10 Then compteur_attentes_affichage = compteur_attentes_affichage + 1 End If End If End If End Sub Private Sub timer2_Tick(ByVal sender As Object, ByVal e As System.EventArgs) Handles timer2.Tick If à_afficher Then à_afficher = False Afficher() If attendre Then attendre = False semaphore.Release() End If End If End Sub Public Sub Arrêter() If Not Arrêté() Then tâche.Abort() End If End Sub Public Sub CallColor(ByVal i As Integer, ByVal fc As Integer, ByVal bc As Integer) couleurs(i + 15) = ((fc - 1) << 4) + bc - 1 Invalider() End Sub Public Sub ChangerVitesse(ByVal v As Integer) vitesse = v If vitesse < 5 Then timer2.Interval = 250 / (vitesse + 1) Else timer2.Interval = 1 nombre_attentes_affichage = (vitesse - 5) * 500 / 6 + 10 End If End Sub Public Function ImageCaractère(ByVal c As Byte) As Image c = c + offset_caractères Dim bmp As New Bitmap(8, Dim fci As Couleur = couleurs(c \ >> 4 Dim bci As Couleur = couleurs(c \ And 15 If fci = Couleur.Transparent Then fci = couleur_fond End If If bci = Couleur.Transparent Then bci = couleur_fond End If Dim fc As Color = valeurs_couleurs(fci) Dim bc As Color = valeurs_couleurs(bci) For i As Integer = 0 To 7 For i2 As Integer = 0 To 7 Dim b As Boolean = motifs(c * 8 + i) >> (7 - i2) And 1 If b Then bmp.SetPixel(i2, i, fc) Else bmp.SetPixel(i2, i, bc) End If Next Next Dim bmp2 As New Bitmap(16, 16) Dim gc As Graphics = Graphics.FromImage(bmp2) gc.DrawImage(bmp, New Rectangle(0, 0, 16, 16)) Return bmp2 End Function Public Sub Beep() lecture_sons.Stream = My.Resources.Start lecture_sons.Play() End Sub End Class Here is the status of my 3 unfinished games: NYOG'SOTHEP (GCC) NYOG_SOTHEP 2.zip Free high memory (code): 5943 Free low memory (data+stack): ~1000 TODO: - Computer player - Menu to load/save a game TI-WARS (TurboForth/FIG-Forth) TI-WARS 5.zip Free high memory in TurboForth: 686 bytes Free low memory in TurboForth: 8192 bytes Free high memory in FIG-Forth: ~2000 bytes Free low memory in FIG-Forth: I don't have the docs, I think it's not usable TODO: - Battle system - Submarines - Computer player - Remove the map editor to free some memory if necessary SOKOBAN (Assembly) SOKOBAN ASM.zip TODO: - Check when memory is full (levels + recorded moves). - Allow the user to split the current file (levels + recorded moves) to continue the game when the memory is full Edited January 4, 2013 by lucien2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 4, 2013 Share Posted January 4, 2013 ... Free low memory in FIG-Forth: I don't have the docs, I think it's not usable ... The only readily available low memory in TI Forth (the fig-Forth I presume you mean) is the 806-byte segment from 3CDAh-3FFFh, where the return stack resides. You could use some of the memory starting at the low end (3CDAh) because the return stack grows down from 3FFFh. Of course, you would need to experiment to see how much you could use before stepping on the return stack. You could probably also co-opt space from the five TI Forth block buffers (2010h-3423h), this time from the high end, by modifying LIMIT$ . I haven't tried this, so I can't say what might happen if you do. I am not sure how LIMIT$ gets set by the system, so I cannot offer much advice without a little research. I would try reducing LIMIT$ by 1028 bytes to try it (1028 bytes is the size of each of the 5 block buffers). There's more information in TI Forth Instruction Manual "1st Edition 2012" in the "TI-99/4A development resources" sticky thread at the top of this forum. I am in the process of producing a 2nd edition, but have been sidetracked by some TurboForth floating-point stuff I've been working on with @Willsy. ...lee Quote Link to comment Share on other sites More sharing options...
RXB Posted January 4, 2013 Share Posted January 4, 2013 Does Forth support the SAMS? That would be a great place to put screens and swap them out quickly. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted January 5, 2013 Share Posted January 5, 2013 The only readily available low memory in TI Forth (the fig-Forth I presume you mean) is the 806-byte segment from 3CDAh-3FFFh, where the return stack resides. I was using this "Weiand Forth" cartridge. I think I saw some blocks loaded during compilation in low memory. The "LIMIT$" word is not defined. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 5, 2013 Share Posted January 5, 2013 I think I have the manual to the Weiand FIG FORTH module. I also have the cartridge. It is pretty rare, as he only sold a couple of dozen of them IIRC. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted January 5, 2013 Share Posted January 5, 2013 I had the opportunity to play Carcassone this past weekend. It's been a long time since I played a board game - this was simple yet intriguing. The fixed elements would be easy to replicate on a computer though I'm not sure how gameplay would be achieved. It got me thinking there may be some simpler mechanics to be explored in the world of games http://en.wikipedia.org/wiki/Carcassonne_(board_game) Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted January 5, 2013 Share Posted January 5, 2013 Working on a small game to get my feet re-wetted before I dive back into one of my many overambitious unfinished projects. And hoping to test this new one out with the compiler! All I have actually coded so far is a cute little CALL DICE subprogram to draw a 16x16 pixel dice anywhere on the screen. But the finished game should be pretty cool... it's a dice game my son and I devised at the dining room table with actual dice and paper. More info later. 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted January 5, 2013 Author Share Posted January 5, 2013 Does Forth support the SAMS? That would be a great place to put screens and swap them out quickly. TurboForth does. You could also put screens in blocks in screen format and pre-load them. The blocks system in Forth works like a cache; if you pre-load them then they sit in ram, ready to be used. In turboforth the cache is in vdp memory so it occupies no program space at all. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 5, 2013 Share Posted January 5, 2013 I had the opportunity to play Carcassone this past weekend. It's been a long time since I played a board game - this was simple yet intriguing. The fixed elements would be easy to replicate on a computer though I'm not sure how gameplay would be achieved. It got me thinking there may be some simpler mechanics to be explored in the world of games http://en.wikipedia....nne_(board_game) Carcassone is the poster boy of modern social board games, extremely easy to learn, infinite replayability. However, implementing a computerized version on the TI would be quite a challenge given the number of tiles involved unless the SAMS card is used. The game mechanics per se should be feasible as they are pretty straightforward. I say go for it Quote Link to comment Share on other sites More sharing options...
unhuman Posted January 5, 2013 Share Posted January 5, 2013 Carcassone is the poster boy of modern social board games, extremely easy to learn, infinite replayability. However, implementing a computerized version on the TI would be quite a challenge given the number of tiles involved unless the SAMS card is used. The game mechanics per se should be feasible as they are pretty straightforward. I say go for it It's become a family favorite. The expansion packs are great too. It's available on the xbox, so not sure why it wouldn't work on the TI. Might be a challenge to get everything into 2x2 squares and fit the board on the screen - scrolling would be required and keeping all that in your head when you look at things to do would probably be the biggest challenges. But, for scoring and the like, it would be great. Quote Link to comment Share on other sites More sharing options...
