cadwallader Posted January 4, 2013 Share Posted January 4, 2013 (edited) I've had a Vectrex for about 20 years now and its always had the same problem, however I never knew about this forum with its many solutions until recently. The problem is that the entire displayed image expands or scales so that the edges of it are outside of the displayable boundaries of the picture tube. This causes some of the text and images normally close to the screen boundaries to disappear. For example, in Mine Storm, the number of remaining ships are normally displayed in the lower right corner. When the display expands or scales up, those ships are no longer visible except for faint glow of their upper edges. The scaling is in both the X & Y axes (horizontal & vertical) and is apparently uniform across the screen. About the conditions that seem to bring on the problem, I've found that it occurs randomly while playing and can be cured by simply banging on the console a bit. This problem does not seem to be heat or time related because it can brought on or cured at any time by a slap to the side of the unit. I disassembled the Vectrex and blew dust off the components, looked for obviously damaged parts and faulty connections but haven't seen any despite a fairly throrugh inspection. The high voltage connection to the picture tube is stiff so I manipulated it but that had no effect at all. What did seem to give the display less susceptabilty to this problem was tightening some of the screws holding in the power PCB. I know enough about electronics to have a general idea where this problem originates but not enough to find the exact cause. Hopefully its nothing more than a weak solder joint in a location well known to the experts here. It doesn't see like it would be a component since I haven't seen any bulging capacitors or burned resistors and getting it cured by slapping the machine seems to indicate a connection problem, though it would be great to know where to look for a bad solder joint or loose wire. Attached are two photos of the screen, one under normal conditions and one with the screen exhibiting the expansion I described. In the photo of the expanded screen its possible to see the faint glow of the mostly off-screen Mine Storm ships remaining. Any advice, suggestions, solutions or recommendations will be greatly appreciated. My Vectrex is like an old friend with a long running ailment and maybe now I can find a cure for him. Edited January 4, 2013 by cadwallader Quote Link to comment Share on other sites More sharing options...
iesposta Posted January 4, 2013 Share Posted January 4, 2013 Just tonight I worked on one and the problem turned out to be the X Y Z connection wire. It was causing all kinds of display problems, from no picture, to just a line, to okay, to showing only half the screen because it was so "zoomed in." I broke the red wire that goes to the logic board trying to get the metal piece out of the white plastic connector. It was exactly the same as the wire to a CD Rom drive so I used one of those. Half an inch from the metal piece that slides into the plastic connector gets soldered to the larger red wire that goes to the power board. There is woven metal wires just under the red coating like coax wire. That was shorting with the connection to the logic board and gave me problems until I trimmed it back more. I tend to go on and on but I would check the wiring first and clean or sand the pins that the connectors connect to, and make sure there are no breaks or shorts in the wire connections. Quote Link to comment Share on other sites More sharing options...
iesposta Posted January 4, 2013 Share Posted January 4, 2013 If you have never opened a Vectrex before, it is the Red / Blue / yellow wire bundle that goes from the back bottom logic board (1 connector) to the side power board (2 connectors). Ground the high voltage wire under the suction cup shaped connector by shoving a flat screwdriver or chisel under it while holding the insulated handle and using a second screwdriver to bridge the first screwdriver metal to the ground metal that runs around the tube. If you just unplugged it you will get a small spark. If it has been a while there may be no visible spark. Most times I see no spark, but I have no idea what the amps are when there is a spark, so always consider an open Vectrex deadly until grounded. Quote Link to comment Share on other sites More sharing options...
cadwallader Posted January 4, 2013 Author Share Posted January 4, 2013 Just tonight I worked on one and the problem turned out to be the X Y Z connection wire. It was causing all kinds of display problems, from no picture, to just a line, to okay, to showing only half the screen because it was so "zoomed in." I broke the red wire that goes to the logic board trying to get the metal piece out of the white plastic connector. It was exactly the same as the wire to a CD Rom drive so I used one of those. Half an inch from the metal piece that slides into the plastic connector gets soldered to the larger red wire that goes to the power board. There is woven metal wires just under the red coating like coax wire. That was shorting with the connection to the logic board and gave me problems until I trimmed it back more. I tend to go on and on but I would check the wiring first and clean or sand the pins that the connectors connect to, and make sure there are no breaks or shorts in the wire connections. Thank you for your reply and suggestion. I removed the wiring harness you mentioned and replaced it several times to ensure the contacts got a good scraping but there was no change in behavior. There must be something else loose that causes the expansion (or zooming as you called it). I tried manipulating some of the other wires while the unit was on and found that there wasn't a specific wire that was responsible, however I was able to reproduce the problem most frequently when pushing and pulling on the power cable grommet underneath the console. Its very unlikely the 120V line has anything to do with the screen behavior though it could be causing another loose connection to move. Quote Link to comment Share on other sites More sharing options...
iesposta Posted January 4, 2013 Share Posted January 4, 2013 I read one had a problem with the on/off volume switch being the problem. It is hard to get out however. You might be able to resolder with it in... Quote Link to comment Share on other sites More sharing options...
cadwallader Posted January 5, 2013 Author Share Posted January 5, 2013 I read one had a problem with the on/off volume switch being the problem. It is hard to get out however. You might be able to resolder with it in... I'll definitely take a look at that but I doubt its the problem. If the 120V power was intermittent the effects would be very obvious. In my case the machine is fully powered but has some kind of issue with the picture tube control signals. Quote Link to comment Share on other sites More sharing options...
Game-Tech.US Posted January 5, 2013 Share Posted January 5, 2013 I've not seen this problem specifically, but have you tried reseating all the socketed chips? Quote Link to comment Share on other sites More sharing options...
cadwallader Posted January 5, 2013 Author Share Posted January 5, 2013 I've not seen this problem specifically, but have you tried reseating all the socketed chips? I haven't been able to find anyone documenting this specific problem either, but I'll give your suggestion a try. I closely inspected the PCB solder joints and could find none that were cracked or loose, so maybe it is one of the chips having a little oxidation in the socket. I'll find out. Thanks. Quote Link to comment Share on other sites More sharing options...
Game-Tech.US Posted January 5, 2013 Share Posted January 5, 2013 I haven't been able to find anyone documenting this specific problem either, but I'll give your suggestion a try. I closely inspected the PCB solder joints and could find none that were cracked or loose, so maybe it is one of the chips having a little oxidation in the socket. I'll find out. Thanks. Pay attention to the sockets, the 3 in my Vec had wipers only touching the insides of each chip's legs, so that's where I focused any cleaning efforts. Quote Link to comment Share on other sites More sharing options...
cadwallader Posted January 7, 2013 Author Share Posted January 7, 2013 Pay attention to the sockets, the 3 in my Vec had wipers only touching the insides of each chip's legs, so that's where I focused any cleaning efforts. I tried your suggestion but apparently the chips in my unit made good contact with the socket pins. The only areas of oxidation were outside the contact areas where the pins of the chip make a right-angle bend. I'm still thinking that the voltage to the CRT must be bypassing a resistor or circuit that regulates it, so when the component or circuit is bypassed the voltage to the CRT is increases, resulting in a scaled-up image. Maybe its the flyback transformer that's doing this. Quote Link to comment Share on other sites More sharing options...
cadwallader Posted January 8, 2013 Author Share Posted January 8, 2013 I discovered two clues that may be of importance for solving this problem: 1) If the display is exapnded (zoomed, scaled) when the machine is turned off, it will remain that way when its turned back on. This would seem to indicate that its a connection problem, because the opposite is also true (turn off the machine with a normal display and it will be normal when turned back on). 2) The screen problem I described (expanding, zooming, scaling) looks exactly like the display just after the machine is powered off: it scales or expands just before it fades out. This may mean that there is a voltage drop that is the cause of the effect (rather than an increase in voltage as I thought before). Taken together this makes sense because a weak electrical connection somewhere could easily lower the voltage to the CRT causing a weaker (or expanded picture). I'm still wondering if this is happening in the flyback transformer - maybe a slight arcing in the coils. Any further suggestions would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Game-Tech.US Posted January 8, 2013 Share Posted January 8, 2013 If you have the logic board out, eliminate the on/off switch by jumping around it so the machine is always on if plugged in. Quote Link to comment Share on other sites More sharing options...
cadwallader Posted January 12, 2013 Author Share Posted January 12, 2013 If you have the logic board out, eliminate the on/off switch by jumping around it so the machine is always on if plugged in. I don't have the logic board out, but I carefully inspected both sides of the step-down transformer. I couldn't find anything visibly wrong, however I find it interesting that the tranformer is switched on the low voltage side and not the 120v mains side. That would explain why some of the wires are a bit stiff, probably from the unit being plugged in all the time (years ago) which caused the transformer wire insulation to heat up. Even with the stiffness and a little bit of deformation everything is still OK. The switch itself has good solder joints and despite jiggling, pushing and pulling the knob I couldn't get the problem to repeat. I also looked the fuse under the cardboard cover. OK as well. However I think you have a point that a weakness in the PS somewhere could be causing the voltage drop which expands the screen. Maybe the transformer wires or actual windings of the tranformer are intermittent in some way. I've been tapping on everything in and around it but no reproducing the symptoms. Moving the power board back and forth can cause and correct the problem. Something is weak somewhere. I guess I'm going to have to take everything out and look at the boards more closely. Sometimes taking things apart and putting them back together magically fix some hard-to-find problem. Quote Link to comment Share on other sites More sharing options...
iesposta Posted January 12, 2013 Share Posted January 12, 2013 Moving the power board back and forth can cause and correct the problem. Something is weak somewhere. I guess I'm going to have to take everything out and look at the boards more closely. Sometimes taking things apart and putting them back together magically fix some hard-to-find problem. As I said, that is what mine was doing. The problem was the wires. From the solder to the connector to the conductor inside the wires themselves and the shielding around the conductors. I am certain my problem was the shielding shorting the conductor wire near the logic board where the big red, yellow or blue shielded wires turn into single wires under black "wrap" then go into the connector. Really bad design. Now the display is solid, but the music is sometimes off key. And sometimes it freezes. Read a small bit about this problem, but don't recall any solutions. The first one I fixed had the dot problem. I replaced all electrolytic caps, a power regulator (not the twins, the solo one), and the problem was a "sound IC" under the giant power board heat sink that is used in the display. All that and it still goes strange after warming up. My advice is to avoid the Taiwan ones. I don't think that IC is your problem though. Quote Link to comment Share on other sites More sharing options...
