senior_falcon Posted January 17, 2013 Share Posted January 17, 2013 I would like to use a workspace (or workspaces) in scratchpat ram with assembly subroutines called from XB. What are the safe memory addresses for this, if any? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
RXB Posted January 18, 2013 Share Posted January 18, 2013 (edited) Welll this is the Source for XB and RXB. I have added only a few to XB for RXB. [0093] *********************************************************** [0094] * Temporary workspaces in EDIT [0095] 8300 VAR0 EQU >8300 TEMPORARY [0096] 8301 VARV EQU >8301 TEMPORARY [0097] 8302 ACCUM EQU >8302 # OF BYTES ACCUMULATOR (4 BYTE [0098] 8302 STPT EQU >8302 TWO BYTES [0099] 8304 VARY EQU >8304 [0100] 8306 VARY2 EQU >8306 [0101] 8304 PABPTR EQU >8304 [0102] 8306 DFLTLM EQU >8306 Default array limit (10) [0103] 8306 CCPPTR EQU >8306 OFFSET WITHIN RECORED (1) [0104] 8307 RECLEN EQU >8307 LENGTH OF CURRENT RECORD (1) [0105] 8308 CCPADR EQU >8308 RAM address of current refs [0106] 8308 VARC EQU >8308 [0107] 8308 CCPADD EQU >8308 RAM address of current color [0108] 830A CALIST EQU >830A Call list for resolving refs [0109] 830A RAMPTR EQU >830A Pointer for crunching [0110] 830C BYTES EQU >830C BYTE COUNTER [0111] 830C NMPTR EQU >830C Pointer save for pscan [0112] 830E CHSAV EQU >830E [0113] 830E CURINC EQU >830E Increment for auto-num mode [0114] 8310 TOPSTK EQU >8310 Top of data stack pointer [0115] 8312 LINUM EQU >8312 Used to determine end of scan [0116] 8314 NMLEN EQU >8314 Current line for auto-num [0117] 8314 CURLIN EQU >8314 Current line for auto-num [0118] 8316 VAR9 EQU >8316 [0119] 8316 XFLAG EQU >8316 SCAN FLAG-BITS USED AS BELOW [0120] 8317 DSRFLG EQU >8317 INTERNAL =60, EXTERNAL =0 (1) [0121] 8317 FORNET EQU >8317 Nesting level of for/next [0122] 8302 AAA1 EQU >8302 [0123] 830C BBB1 EQU >830C [0124] 8308 CCC1 EQU >8308 [0125] *********************************************************** [0126] * Permanent workspace variables [0127] 8318 STRSP EQU >8318 String space begining [0128] 831A STREND EQU >831A String space ending [0129] 831C SREF EQU >831C Temporary string pointer 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0003 EQUATES EDIT-359 [0130] 831E SMTSRT EQU >831E Start of current statement [0131] 8320 VARW EQU >8320 Screen address [0132] 8322 ERRCOD EQU >8322 Return error code from ALC [0133] 8324 STVSPT EQU >8324 Value-stack base [0134] 832A VARA EQU >832A Ending display location [0135] 832C PGMPTR EQU >832C Program text pointer [0136] 832E EXTRAM EQU >832E Line number table pointer [0137] 8330 STLN EQU >8330 Start of line number table [0138] 8332 ENLN EQU >8332 End of line number table [0139] 8334 DATA EQU >8334 Data pointer for READ [0140] 8336 LNBUF EQU >8336 Line table pointer for READ [0141] 8338 INTRIN EQU >8338 Add of intrinsic poly constant [0142] 833A SUBTAB EQU >833A Subprogram symbol table [0143] 833C IOSTRT EQU >833C PAB list/Start of I/O chain [0144] 833E SYMTAB EQU >833E Symbol table pointer [0145] 8340 FREPTR EQU >8340 Free space pointer [0146] 8342 CHAT EQU >8342 Current charater/token [0147] 8343 BASE EQU >8343 OPTION BASE value [0148] 8344 PRGFLG EQU >8344 Program/imperative flag [0149] 8345 FLAG EQU >8345 General 8-bit flag [0150] 8346 BUFLEV EQU >8346 Crunch-buffer destruction leve [0151] 8348 LSUBP EQU >8348 Last subprogram block on stack [0152] * FAC EQU >834A Floating-point ACcurmulator [0153] 834B FAC1 EQU FAC+1 [0154] 834C FAC2 EQU FAC+2 [0155] 834D FAC3 EQU FAC+3 [0156] 834E FAC4 EQU FAC+4 [0157] 834F FAC5 EQU FAC+5 [0158] 8350 FAC6 EQU FAC+6 [0159] 8351 FAC7 EQU FAC+7 [0160] 8352 FAC8 EQU FAC+8 [0161] 8353 FAC9 EQU FAC+9 [0162] 8354 FAC10 EQU FAC+10 [0163] 8355 FAC11 EQU FAC+11 [0164] 8356 FAC12 EQU FAC+12 [0165] 8357 FAC13 EQU FAC+13 [0166] 8358 FAC14 EQU FAC+14 [0167] 8359 FAC15 EQU FAC+15 [0168] 835A FAC16 EQU FAC+16 [0169] 835B FAC17 EQU FAC+17 [0170] 834C AAA EQU FAC+2 [0171] 834E CCC EQU FAC+4 [0172] 8350 BBB EQU FAC+6 [0173] 834C DDD EQU FAC+2 [0174] 834E FFF EQU FAC+4 [0175] 8350 EEE EQU FAC+6 [0176] 8354 DDD1 EQU FAC+10 [0177] 8356 FFF1 EQU FAC+12 [0178] 8358 EEE1 EQU FAC+14 [0179] * ARG EQU >835C Floating-point ARGument [0180] 835D ARG1 EQU ARG+1 [0181] 835E ARG2 EQU ARG+2 [0182] 835F ARG3 EQU ARG+3 [0183] 8360 ARG4 EQU ARG+4 [0184] 8361 ARG5 EQU ARG+5 [0185] 8362 ARG6 EQU ARG+6 [0186] 8363 ARG7 EQU ARG+7 [0187] 8364 ARG8 EQU ARG+8 [0188] 8364 XSTLN EQU >8364 GKXB variable [0189] 8366 XENLN EQU >8366 GKXB variable [0190] 8367 ARG11 EQU ARG+11 [0191] 8368 XCURLI EQU >8368 GKXB variable [0192] 836A XCURIN EQU >836A GKXB variable [0193] 836B ARG15 EQU ARG+15 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0004 EQUATES EDIT-359 [0194] 836C ARG16 EQU ARG+16 [0195] * VSPTR EQU >836E Value stack pointer [0196] 8376 EXPZ EQU >8376 Exponent in floating-point [0197] 8384 RAMTOP EQU >8384 Highest address in ERAM [0198] 8386 RAMFRE EQU >8386 Free pointer in the ERAM [0199] 8388 RSTK EQU >8388 Subroutine stack base [0200] 8389 RAMFLG EQU >8389 ERAM flag [0201] 83AF STKMIN EQU >83AF Base of data stack [0202] 83BD STKMAX EQU >83BD Top of data stack [0203] 83CE PRTNFN EQU >83CE [0204] *********************************************************** Rich P.S. the bad news is that is only GROM 3, I did not include listing for GROM 4, 5, 6 Edited January 18, 2013 by RXB Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted January 19, 2013 Share Posted January 19, 2013 I would like to use a workspace (or workspaces) in scratchpat ram with assembly subroutines called from XB. What are the safe memory addresses for this, if any? Thanks in advance. Most of the XB related assembly I have written uses a workspace in low 8k memory where the assembly routines are LOADed and reside, by defining it using a BSS directive, ie, "WS BSS >20". You'll be hard-pressed to find 32 contiguous bytes though with some creativity, you could probably find 10-12 which would let you use R10,R11 with R13/R14/R15 for the call into your routines. You can also save and restore scratchpad if you have a routine that truly benefits from its usage: call routine from XB start by using a workspace in low 8k memory copy 32 bytes of scratchpad to low memory 'holding area' you define (ie, BSS 32) change your workspace to the 32 bytes you saved execute code change workspace to low memory restore scratchpad from saved memory return to XB (clear GPL status bit/byte if needed) Sometimes you can use the GPL workspace 0x83E0 for simple code but you should not try to call any DSR routines (DSRLNK switches context to GPL workspace) nor should you allow interrupts to fire. Register usage may vary depending on your calling program and your routines. A good reference for CPU and VDP memory maps is the Millers Graphics Smart Programmer's newsletter. Many can be found on WHT's ftp server. I would direct you to the August 1986 newsletter which contains a map of the scratchpad RAM for XB. Some related issues: 84/03 shows XB low/high mem map 84/04 shows overall vdp maps comparing basic/xb 84/05 shows detail XB vdp memory map, including the disk buffer space I have paper copies of about 10 as they are quite the resource. I do not know how many issues were released. tim Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 19, 2013 Author Share Posted January 19, 2013 Thanks, that's what I always thought. I have always used a workspace in the memory expansion, but was just wondering whether there was a way to do it in scratchpad memory. I can always select 32K on the 16 bit bus on my TI, but not everyone has that option. I have MG explorer - the manual contains good memory maps of VDP, scratchpad, and the 32 K expansion. Quote Link to comment Share on other sites More sharing options...
