e5frog Posted August 2, 2013 Share Posted August 2, 2013 (edited) Have I understood correctly when I'm reading that the menu isn't supposed to have striped, every second line (well, it seems to differ, sometimes between characters) characters like this: Black stripes in characters are even more visible for real. I have only tried it on two CRT 16:9 100Hz NTSC compatible PAL TV:s so far, maybe I should check the normal PAL TV as well... Frankly it's difficult to read some times. EDIT: Tried it on the plain 50Hz PAL (NTSC compatible) TV - no black stripes, damn these double scan TV:s, they suck for old time gaming. Edited August 2, 2013 by e5frog Quote Link to comment Share on other sites More sharing options...
e5frog Posted August 2, 2013 Share Posted August 2, 2013 (edited) This is more like it, seems I need to move around a couple of TV:s. Flickers a little, only the two select bars are stable - but much better than on the 100Hz TV:s that has a very stable image but striped text. I've had problems with these TV:s on scrolling stuff with the C64 as well, it adds flicker that's not there. Edited August 2, 2013 by e5frog Quote Link to comment Share on other sites More sharing options...
maiki Posted February 13, 2014 Share Posted February 13, 2014 Regarding the flickering text: how about using DPC+ and switch from interlaced to progressive output even if the fonts have to be changed? Is that possible? Quote Link to comment Share on other sites More sharing options...
