José Pereira Posted February 14, 2013 Share Posted February 14, 2013 As most here sure know the A8 isn't the best Machine to have colourful Loading screens. With todays G2F it's possible to get them in many colours but because of heavy use of PMGs and DLIs. But with this isn't possible to use them when loading (that's why the recent games load and show that screens and them they 'disapear' and it's only when the game really starts to load). To have a screen during the loading normally (from what I read) it's best you don't have any DLIs so this almost limit all possible ways to get more colour: -> The screen can only be in Bitmap Mode 4colours because: - Other scanlines new colours you'll need DLIs - Use the ANTIC4 charset Mode to have a 5th colour you can't have a picture because you're limited to 128chars per charset (more charlines new charsets needs a DLI) - You can only use one time each of the PMGs (if you start using one at a xPos it has to be always at the same xPos all screen high and also the same colour, width, resolution,... because if you change these registers then you'll need DLIs) So, the only way and simple it's to have a picture at 4colours in Bitmap Mode GR.15. Then you add the PMGs. Clever position of the PMGs and some pictures that can iuse the 'Oring' of PRIOR0 and we can get, not those many colours of G2F but better than the 4colours only old ones like Spellbound, Mirax Force, Last Guardian, Richard Mumms Tagalon,Captain Crumble,... Today with Emulators and 'speed loading' it seems not worth to remake those screens... It seems so but I think we can remake them. They are just a Load block at the begining of the Tape and it's just go thee and change the picture the new remaked one. My idea is I am ofering to use take those screens and remake them. My remaking still use the same GR.15 4colours Bitmap Mode and I just add the PMGs with no DLIs anywhere on screen so that it's just changing the data on the Tape for the new 21st Century one. But for this I would need some (or one) of the programming guys here. I think that just changing the data on the Tape isn't so hard to do and it's a quick thing, right? Anyone is interested in taking this with me? O.k. just to show one of them that I remaked this Night, Spellbound. On the past they normally done the Loading screens (and the in-game also) as one colour in 3luminances. That was a thing that we can see a screen Miles away and just know it was an A8 screen. Today we aren't no more in that ways of things on A8 (of course some screens look better that way and each case it's a single case biut others we can have the colours and luminances other way. With and without PAL Artifacting (indeed, for the PAL Land guys it can get some nice new colours and luminances...): Now compare this with the old 'Brownish' one: That's what I said, of course it's not a masterpiece because there's no possible DLIs. The idea is just to have the screen on the Tape during the Loading like if was them that had done it on the past. This show better... First I redone some of picture pixels where I know I will put the PMGs (and decide the PRIOR number I'll use): So, this is the same 4colours picture as the Mastertronic original one (that looks so uggly, but only by now...) Next you had the PMGs... Because there's no PF3 in GR.15 I always try to use the 4Missiles as 5th Player so that I can have one colour more (here it's the 8pixels wide of the Green on the left) The other 4 blocks are P0->P3, the 4Layers 8pixels wide the A8 has. Now you can see that I could only use them one time because if I re-use them in other part of the screen or with a new colour then DLIs would be needed: For me the time isn't a problem so: "Is it a hard work or taking much time to replace those old Loading screens?" If it isn't then why not!... Could you, for eaxmple in a week or an weekend replace those screens (and they aren't really nuch... The most knowing/beter game are how many? 20 or so...) What do you say? 1 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/ Share on other sites More sharing options...
Rybags Posted February 14, 2013 Share Posted February 14, 2013 (edited) The problem with loading screens is floppy turbo speed loading. IDE type devices will generally get by with much less CPU devoted to them and just operate at reduced speed. Standard SIO you can have a custom loader which could operate interleaved with heavy colour changing and still work but that means you're restricted to real disks or ATR images only. Less colourful screen with not too many DLIs that execute swiftly should work OK with most SIO turbo modes except the very quickest. But as you said, load screens are kinda superfluous when you're dealing with fast I/O devices or emulation. One lesser explored option though is that load screens could be had but give the user the option to disable and/or have the game time a section of the load. By doing that you can roughly guess how the program is being loaded. If the section loads particularly slowly or very quickly then it likely means standard SIO or IDE which can tolerate a higher amount of interruptions. Edited February 14, 2013 by Rybags Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697120 Share on other sites More sharing options...
Tezz Posted February 14, 2013 Share Posted February 14, 2013 Hi Jose, as Gary's says above a short dli is no problem with ordinary sio disk/cassette rates and longer dli's are possible with sio procedures taken care of within the dli, I was writing a custom loader a couple of years back for the sake of it. As said it's pretty much redundent now with modern storage devices although I do like a good loading picture personally. Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697122 Share on other sites More sharing options...
José Pereira Posted February 14, 2013 Author Share Posted February 14, 2013 (edited) Oops, forget to post the files. Here's the g2f and xex if anyone wants to try replacing the old one:1402 SPELLBOUND A8 Loading screen.zip Edited February 14, 2013 by José Pereira Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697123 Share on other sites More sharing options...
Rybags Posted February 14, 2013 Share Posted February 14, 2013 Additional problem I forgot to add - smaller # of DLIs or interleaved SIO means building the screen by hand. I'm not totally familiar with the various modes of G2F so maybe there is some mode where greatly reduced CPU usage could be had. Possibly the best solution is just have the IO speed test then show a static screen with loading paused, give the user the option to continue loading with or without the screen displayed, otherwise continue loading with that option determined by the speed test. Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697124 Share on other sites More sharing options...
José Pereira Posted February 14, 2013 Author Share Posted February 14, 2013 The idea is have the same as the original game. Original it's 4colours GR.15 so is the new one (just the PMGS added but PMGs are PFs like the others 704->707 more the 711 if 5th Player enabled). I only want to know if you guys would waste so many time in replacing the loading picture on the tape version file. Of course I can only do this using G2F but probably we can get the G2f cleaned of unecessary stuff and just have the 'cleaned' file to replace the old one on the Tape. I don't want nor waste time in re-done these pictures to modern looking. I want to preserve the original Author one with small pixels changing just because of the PMGs and only if I really need it. Keep the original but with the possible PMGs they don't did on the past. It's just this I want nothing more. Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697125 Share on other sites More sharing options...
Magic Knight Posted February 14, 2013 Share Posted February 14, 2013 Looks like my Avatar may be getting a colourful upgrade 1 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697174 Share on other sites More sharing options...
www.atarimania.com Posted February 14, 2013 Share Posted February 14, 2013 Spellbound never had a loading screen on tape, the picture was added by a cracker when he "converted" the game to file. -- Atari Frog http://www.atarimania.com 1 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697175 Share on other sites More sharing options...
José Pereira Posted February 14, 2013 Author Share Posted February 14, 2013 See, if he add the picture then it's time to be 'cracker number two'. For the other games that indeed has a Loading screen it's like a cracker, like if using the original picture you add your name there or any other thing... Because today we have G2F it's then the simpliest way to re-done the picture. It's just clean the not needed stuff and use it in the same way as the original ones. Anyone here ever saw one of those pictures? Are all them done the same way? Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697200 Share on other sites More sharing options...
Marius Posted February 15, 2013 Share Posted February 15, 2013 Would simulation of DLI by using vcount in main loop also give problems with loading? Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697662 Share on other sites More sharing options...
Tezz Posted February 15, 2013 Share Posted February 15, 2013 If you have an irq based kernal polling vcount yes, either way you'll still have very tight timing to deal with. Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697694 Share on other sites More sharing options...
José Pereira Posted February 15, 2013 Author Share Posted February 15, 2013 (edited) Hi. Here's some more, by now more simple ones: LITTLE DEVILS.zip MIRAX FORCE.zip Edited February 15, 2013 by José Pereira 1 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697703 Share on other sites More sharing options...
José Pereira Posted February 15, 2013 Author Share Posted February 15, 2013 (edited) This one hasn't a Loading picture but just a GR.1 words screen. Because I discouver yesterday a remake of the game for the MSX done in 21st century with a nice castle/house Hi-Resolution I decided to see what it could like on A8 like this with no DLIs. And also because the Introduction/after the game loads is also in Hi-Resolution it sures 'matches the spirit': BLINKY'S.ZIP Edited February 15, 2013 by José Pereira 3 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697704 Share on other sites More sharing options...
Marius Posted February 15, 2013 Share Posted February 15, 2013 Great topic btw! Love that Scary School picture a lot! 2 1 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697719 Share on other sites More sharing options...
Tezz Posted February 15, 2013 Share Posted February 15, 2013 (edited) This one hasn't a Loading picture but just a GR.1 words screen.Because I discouver yesterday a remake of the game for the MSX done in 21st century with a nice castle/house Hi-Resolution I decided to see what it could like on A8 like this with no DLIs. And also because the Introduction/after the game loads is also in Hi-Resolution it sures 'matches the spirit': That's a good choice there for an actual usable loading picture José and the correct thinking It was for this intention that I was writing the custom loader a couple of years back. Just a couple of small fixes though attached, you had a few unnessasry dli changes left in there and you've forgotten to set blank scanlines on all the empty rows. I might resurrect the loader tonight and put it to use or better still make use of xxl's xbios. EDIT> I've tweaked the logo a little and set the grey down a level. I'm getting back to work now blinky_fix.zip Edited February 15, 2013 by Tezz 2 Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697756 Share on other sites More sharing options...
José Pereira Posted February 15, 2013 Author Share Posted February 15, 2013 (edited) Was just thinking on XXL's xBIOS when was loading this page. Isn't it also possible to use it to have music played during loading, at least GTIA music? I also remembered that Mirax Force had another/better Loading screen, I think it's the original Tynesoft's. Working on it right now but this shit that better no DLIs it doesn't look good. But I can't figure it anyway better. Edited February 15, 2013 by José Pereira Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697785 Share on other sites More sharing options...
José Pereira Posted February 15, 2013 Author Share Posted February 15, 2013 (edited) Del. Edited February 15, 2013 by José Pereira Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697792 Share on other sites More sharing options...
Tezz Posted February 15, 2013 Share Posted February 15, 2013 Isn't it also possible to use it to have music played during loading, at least GTIA music?Yes you can have two channel music during loading or sample play. Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697810 Share on other sites More sharing options...
tebe Posted February 15, 2013 Share Posted February 15, 2013 msx, G2F gfx is possible during SIO loading with XBIOS http://xxl.atari.pl/?p=1076 decompress from file (compressed data not affected RAM) to RAM with XBIOS is possible Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697819 Share on other sites More sharing options...
+CharlieChaplin Posted February 15, 2013 Share Posted February 15, 2013 Hmmm, well, when loading programs from tape in the past I did not want to waste time and 8k or more for loading a title screen. Later with disk drives this wasn`t such a big problem, unless the program required more than 48k RAM, then this 8k RAM for a title gfx became questionable... Nowadays, I do have floppy drives with speeders / turbo-loaders, SIO2SD, SIO2USB, IDE+, My-IDE 2, SIDE, big RAM enhancements and what not. Still I do not really need a title gfx. while loading a program. For me a simple Gr. 1 or Gr. 2 text (info about program`s name) while loading is enough. Quite often I do even pack/compress games and demos to save space and/or loading time. However, when the program has completely loaded, its nice to see a title gfx and not only some text. But hey, this is just my opinion, to each his own. Attached are some original and "later-drawn" title gfx from various A8 games... -Andreas Koch. title_gfx.zip Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2697907 Share on other sites More sharing options...
Marius Posted February 16, 2013 Share Posted February 16, 2013 @andreas I agree; and when it comes to packing. On the newest devices (like myide) I wished a lot of games did not use packing for speed. I am rather sure those games could load a lot quicker from myide in 'raw' data than when loaded and depacked. Except games that need the depacking so it can use exotical low or high memory locations after loading. Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2698114 Share on other sites More sharing options...
Magic Knight Posted February 16, 2013 Share Posted February 16, 2013 (edited) An A8 rendition Ocean software loader for Head over heels would be interesting and maybe a pokey version of Martin Galways/john dunns soundtrack to go with it. (see 3:06) http://www.youtube.com/watch?v=pkns_VIWGQA Edited February 16, 2013 by Magic Knight Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2698130 Share on other sites More sharing options...
sack-c0s Posted February 16, 2013 Share Posted February 16, 2013 could be a good idea - the harsher sound of the pokey works pretty well for Galways style actually... Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2698156 Share on other sites More sharing options...
xxl Posted February 16, 2013 Share Posted February 16, 2013 POKEY music & DLI during I/O yes, you can use "sta wsync" in DLI xbios.atr Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2698159 Share on other sites More sharing options...
Magic Knight Posted February 16, 2013 Share Posted February 16, 2013 POKEY music & DLI during I/O yes, you can use "sta wsync" in DLI Nice work Quote Link to comment https://forums.atariage.com/topic/208900-remake-of-those-old-loading-screens/#findComment-2698174 Share on other sites More sharing options...
