ti99iuc Posted February 23, 2013 Share Posted February 23, 2013 Hi friends ! can someone help me to know a new thing about TI99 Basic ? i looking for a command needed to delete a group of lines in a program. example, delete all the lines from 3000 to 5000 i looking for this command on the TI Basic manual or XB manual but i do not found any... Some Help ? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 23, 2013 Share Posted February 23, 2013 ... i looking for a command needed to delete a group of lines in a program. I don't think there is any official, easy way to do it in either TI Basic or TI Extended Basic. The only way I know is to type the line number followed by <enter>---certainly painful. That said, someone surely has written a utility to do the job. ...lee Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 23, 2013 Author Share Posted February 23, 2013 (edited) ..... mmm... so i'm not so idiot because i not found how to do now i feel myself better but not solve the problem... i can't do any utility because the memory is fully used... no way... only the classic line number and enter will be the solution Thank you ! Edited February 23, 2013 by ti99userclub Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted February 23, 2013 Share Posted February 23, 2013 If you're working in Classic99, then you could copy and paste something like this 3000 3250 3500 3750 4000 4250 4500 4750 5000 Quote Link to comment Share on other sites More sharing options...
+adamantyr Posted February 23, 2013 Share Posted February 23, 2013 Super Extended Basic introduced advanced line editing commands, including copy, move and delete line blocks. Quote Link to comment Share on other sites More sharing options...
kl99 Posted February 23, 2013 Share Posted February 23, 2013 (edited) If you are working on Classic 99. I would recommend getting the program listing into the clipboard via LIST "CLIP". Paste the clipboard data in any text editor on your pc. Change it to your needs, mark all and CTRL+C, now get back to Classic99 and select in a new (empty) XB instance the Classic99\Edit\Paste from XB. Mechatronic XBII has a dedicated command for this as well if I remember right. Edited February 23, 2013 by kl99 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 23, 2013 Author Share Posted February 23, 2013 no guys... i must work on a real machine ! ... the problem is to convert a program for using with classic99.. but if i attach the PEB the program give me an error after first whistle... instead without PEB i haven't this error... so for now i saved the program in two part... now i will merge it using classic99 ... now i can .. instead about Super Extended Basic i have the cartridge but i must looking for the correct command to use Quote Link to comment Share on other sites More sharing options...
RXB Posted February 24, 2013 Share Posted February 24, 2013 LOL well guys any XB that includes GKXB has all the editing commands built into it. RXB, GKXB, SXB and many others. Here is a video of RXB that is built into Classic99 now. Shows everything you asked and more. Editing and all the GKXB commands or features in RXB, GKXB and SXB. Rich Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 24, 2013 Author Share Posted February 24, 2013 (edited) LOL well guys any XB that includes GKXB has all the editing commands built into it. RXB, GKXB, SXB and many others. Here is a video of RXB that is built into Classic99 now. Shows everything you asked and more. Editing and all the GKXB commands or features in RXB, GKXB and SXB. Rich It's very interesting Rich !! ... but i need it on a real machine ! ... could you help me about it please ? Edited February 24, 2013 by ti99userclub Quote Link to comment Share on other sites More sharing options...
kl99 Posted February 24, 2013 Share Posted February 24, 2013 Okay, real console then: If it's a TI Basic (non XB) program only, try loading it with Mini Memory cartridge, with this you have 4K more RAM. or if we have to use XB: Does the program uses files, if not you can reduce the number of maximum files to 1: CALL FILES(1) [or CALL FILES(2) if you want to save it later] NEW OLD DSK1.YOURPGRM The more info you give us (program specs...) the better we can help you. To remove several lines at once you can use the DEL command from Super Extended Basic: DEL The DEL command will delete a line or group of lines from your Extended Basic program. The format is: DEL start line - end line start line and end line define the block of lines to be deleted. If start line is omitted, line deletion will begin at the first line of the program. In this case, end line must be preceded by a dash. If end line is omitted and start line is followed by a dash, then program lines from start line through the end of the program will be deleted. At least one valid program line must exist between start line and end line. If not, a Bad Line Number error will result. If only one number is given, without a dash, then that one line will be deleted, if it exists. If it does not exist, a Bad Line Number error is generated. After the DEL command has executed any open files are closed and all variable values are lost. Furthermore with SEB you got: COPY start line - end line, new start line, increment MOVE start line - end line, new start line, increment Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 24, 2013 Author Share Posted February 24, 2013 (edited) If it's a TI Basic (non XB) program only, try loading it with Mini Memory cartridge, with this you have 4K more RAM. or if we have to use XB: Does the program uses files, if not you can reduce the number of maximum files to 1: CALL FILES(1) [or CALL FILES(2) if you want to save it later] NEW OLD DSK1.YOURPGRM The more info you give us (program specs...) the better we can help you thank you, i tried but no way program do not load... i must load from a CS1... Minimemory in Basic or Call Files (1 or 2) in XB don't work... program stop to load after first long whistle... To remove several lines at once you can use the DEL command from Super Extended Basic: Furthermore with SEB you got: COPY start line - end line, new start line, increment MOVE start line - end line, new start line, increment i'll try to remove parts and save parts for merging after in Classic99... ... but i can use only basic because the program can't load in XB or other... only in TI Basic withouth PEB ... LOL ... incredible... Edited February 24, 2013 by ti99userclub Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted February 24, 2013 Share Posted February 24, 2013 (edited) Record/tranfer audio from Cassette to PC. Load audio file with MESS or Win994a from TI Basic. Save program. Use TiDir to extract and copy source. Paste source to text editor. Mark lines 3000 through 5000 and hit Delete. Edited February 24, 2013 by sometimes99er Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 24, 2013 Author Share Posted February 24, 2013 mmmm.... yes this could be a solution... but i must organiza to do it... i use an Apple usually... Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 25, 2013 Share Posted February 25, 2013 (edited) mmmm.... yes this could be a solution... but i must organiza to do it... i use an Apple usually... Load Virtualbox and a old copy of Windows on your Mac to run Windows based programs. I actually use VB and Win98 on my Win 7. It took me about 1/2 hour to set it up. Runs real fast too. It actually runs my DOS emulators faster than in DOSbox. Edited February 25, 2013 by hloberg Quote Link to comment Share on other sites More sharing options...
kl99 Posted February 25, 2013 Share Posted February 25, 2013 Still didn't get it, if the program is written for TI Basic or TI Extended Basic? The problem is: A) saving the program on disk B) running the program if PEB attached Please specify Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 25, 2013 Author Share Posted February 25, 2013 (edited) hi Klaus.. i answered it in Post number #11 ... anyway: program is written in TI BASIC. problem was: A) saving the program on disk. Edited February 25, 2013 by ti99userclub Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 25, 2013 Author Share Posted February 25, 2013 Load Virtualbox and a old copy of Windows on your Mac to run Windows based programs. I actually use VB and Win98 on my Win 7. It took me about 1/2 hour to set it up. Runs real fast too. It actually runs my DOS emulators faster than in DOSbox. VirtualBox... yes, i will try... thank you Quote Link to comment Share on other sites More sharing options...
RXB Posted February 25, 2013 Share Posted February 25, 2013 You should run Virtual PC or VM Ware to run Windows on a Apple unless you have a Intel Mac like I do. I run OS X, Windows 8, Windows 7 with each on a 1 TB drive. My last drive is a backup for Documents and Music/Video. I run VM Ware on my Windows 8 and run several computers under that can run all the Emulators for the TI. I never have used Mess for the Apple, but should give it a shot someday. I mostly use Classic99 on Windows 7 the most. Rich Quote Link to comment Share on other sites More sharing options...
CantStopClicking Posted February 26, 2013 Share Posted February 26, 2013 You should run Virtual PC or VM Ware to run Windows on a Apple unless you have a Intel Mac like I do. I run OS X, Windows 8, Windows 7 with each on a 1 TB drive. My last drive is a backup for Documents and Music/Video. I run VM Ware on my Windows 8 and run several computers under that can run all the Emulators for the TI. I never have used Mess for the Apple, but should give it a shot someday. I mostly use Classic99 on Windows 7 the most. Rich Rich, Do you happen to have the Xcode tools installed on your Mac? I'd like to get a build of MESS for Darwin but it requires compiling. Last time I tried to install Xcode it broke something so, I'm hesitant to try it right now. No one seems to have a current downloadable binary for OS X. And MESS performs poorly under Parallels. But, that could be do to my ancient Mac. Also, are you running VMware ESXi or Workstation/Fusion? -Dano Quote Link to comment Share on other sites More sharing options...
RXB Posted February 26, 2013 Share Posted February 26, 2013 Rich, Do you happen to have the Xcode tools installed on your Mac? I'd like to get a build of MESS for Darwin but it requires compiling. Last time I tried to install Xcode it broke something so, I'm hesitant to try it right now. No one seems to have a current downloadable binary for OS X. And MESS performs poorly under Parallels. But, that could be do to my ancient Mac. Also, are you running VMware ESXi or Workstation/Fusion? -Dano Like I said I have not used Mess. But I run on Windows 8 VM Ware Workstation of a IBM 300 PL and a Pentium 4 2Ghz for my emulators under 98SE and XP. You can pick up a copy of Vitual PC off many pirate sites as it is no longer supported but works fine. (Mine is legit from MS as a Beta tester) Rich Quote Link to comment Share on other sites More sharing options...
