iesposta Posted April 2, 2013 Share Posted April 2, 2013 Here is the bB file game5.bas Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 2, 2013 Author Share Posted April 2, 2013 Thanks! I've got a busy schedule tomorrow and I'm out of time tonight, I'm hoping to take a look at this again on Wednesday. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 2, 2013 Author Share Posted April 2, 2013 I never set playerXheight. Is this needed? rem it out saves 40 bytes. I did some testing last night (in Stella) and it looks like it is needed. If you put the playerheights back in you no longer get the jerky movement on the player sprite, it's very smooth. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 3, 2013 Author Share Posted April 3, 2013 I did some testing last night (in Stella) and it looks like it is needed. If you put the playerheights back in you no longer get the jerky movement on the player sprite, it's very smooth. I made one simple change you made to my my "game5" source, I just added the player<x>height statements back in. It now works perfectly on real hardware. There is no jerky movement with the player sprite. This was a quick 2 minute test, I haven't tried anything else yet or made a more detailed comparison of the code differences, but the player heights are definitely required. Quote Link to comment Share on other sites More sharing options...
iesposta Posted April 3, 2013 Share Posted April 3, 2013 Glad it is working on Harmony. Never had that happen to me, but that bouncing in the Food Fight is due to not having the datafetchers near the drawscreen. I'll have to look at the compiled asm code with and without player heights defined. I'm curious as to why they are needed because I have seen them in my compiled asm code and I never knew of that command. Quote Link to comment Share on other sites More sharing options...
iesposta Posted April 3, 2013 Share Posted April 3, 2013 One bug that is easy to see. Start your game. Move left. Press fire and float to the top! Also if you jump while walking sometimes you jump up levels. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 3, 2013 Author Share Posted April 3, 2013 One bug that is easy to see. Start your game. Move left. Press fire and float to the top! Also if you jump while walking sometimes you jump up levels. Yep, I knew about that. The code for making the player jump doesn't work well at all. It needs to be changed. If you are at the far left or right of the screen you'll float to the top because as it's written now you stop jumping when you touch the playfield, and the far left & right of the screen don't have a defined playfied. The platforms are only background colors. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 4, 2013 Author Share Posted April 4, 2013 Many thanks, iesposta! I changed my current build to match the changes you made and it works perfectly on real hardware now. No screen rolling and no delays in sprite movement at all. Now that I'm confident this demo will work, I'm going to dive in to trying to make this in to a real game. I haven't gotten my development AtariVox from golden ax yet but I should by the end of the week, speech will definitely be incorporated into this. I have more ideas in my head than I'll probably be able to use. It's definitely going to be a pitfall themed game and I'm looking forward to working on it. I could see this taking a very long time to finish. Attached is the latest demo. The jumping issue is fixed and it works on the Harmony. game12.bin Quote Link to comment Share on other sites More sharing options...
iesposta Posted April 4, 2013 Share Posted April 4, 2013 You are welcome! I did get a chance at work to check the compiled asm differences. If you use set player heights it is defined twice, first in a block of code and then a 2nd time with the player pointers - the same values. If you don't set them they are set once with the same values in the player pointer code -- but it moves jerkily. So I really didn't figure anything out except set them if you have movement problems Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted April 4, 2013 Share Posted April 4, 2013 I have nothing productive to say, but this is gorgeous! I'm very excited to see more. Excellent work so far. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 4, 2013 Share Posted April 4, 2013 The scorpion can get stuck inside a barrier if you time your entry into a screen right. This happens because each scorpion seems to share the same x position as its counterparts in other screens. maybe this should change Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 4, 2013 Author Share Posted April 4, 2013 I have nothing productive to say, but this is gorgeous! I'm very excited to see more. Excellent work so far. Thanks Kevin, comments like that inspire me to keep working on it. I've been trying to figure out the details on DPC+ for a while now and this project works pretty well with the current limitations. At least so far. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 4, 2013 Author Share Posted April 4, 2013 The scorpion can get stuck inside a barrier if you time your entry into a screen right. This happens because each scorpion seems to share the same x position as its counterparts in other screens. maybe this should change Yep, I noticed that, just haven't tried to fix it yet. I've got a really long way to go to make this a complete game. 1 Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 4, 2013 Author Share Posted April 4, 2013 A few more changes today. Added alligators, rolling logs, shooting arrows, fixed the problem with the scorpion, maybe a few other things I'm not thinking of. There's a treasure on one screen but you can't collect it. You now have to jump up to the ladder and vines to go up to a higher platform. Once I add collision detection and treasures it will be an actual playable game. It's tested and works on a real Harmony. game16.bin game-16.txt 1 Quote Link to comment Share on other sites More sharing options...
Brian O Posted April 4, 2013 Share Posted April 4, 2013 Looking good. Feels like Keystone Kapers meets Pitfall. -B Quote Link to comment Share on other sites More sharing options...
bogax Posted April 13, 2013 Share Posted April 13, 2013 (edited) I messed with your (game-16.txt) code some I changed it in four spots I guess you'll have to decide if it's any improvement I changed where the score get's set to the room should work as long as room < 16 score = 0 score = score + room ======= I think your jump/collision code is a mess ;P . I think you should clean it up. I tryed, not sure I got it right. edit: I tryed to remove the redundancies I didn't try to clean it up it's still a mess ======= I put the arrange sprite code in bank 2 and put the paramters in a table. Saves gosubs to other banks which take a (relative) lot of time and code. Even if you going to call it from another bank, you ought to make just one call and one return. I added some stuff to fill the table which I hope is not harmfull room 0 sets ballx,y to 180 room 15 sets player8x,y to 180 then there's exceptions for stuff that didn't/couldn't go in the table which gets called with on room gosub Since arranging the sprites in bB results in a lot of redundant loading of the index (room) (which irks me ) I also did a version in asm ======= I changed the draw_room code to on-goto and got rid of the string of if-thens game-16_mod.bas game-16_mod_w_asm.bas Edited April 14, 2013 by bogax Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted April 17, 2013 Author Share Posted April 17, 2013 I messed with your (game-16.txt) code some I changed it in four spots I guess you'll have to decide if it's any improvement I changed where the score get's set to the room should work as long as room < 16 score = 0 score = score + room ======= I think your jump/collision code is a mess ;P . I think you should clean it up. I tryed, not sure I got it right. edit: I tryed to remove the redundancies I didn't try to clean it up it's still a mess ======= I put the arrange sprite code in bank 2 and put the paramters in a table. Saves gosubs to other banks which take a (relative) lot of time and code. Even if you going to call it from another bank, you ought to make just one call and one return. I added some stuff to fill the table which I hope is not harmfull room 0 sets ballx,y to 180 room 15 sets player8x,y to 180 then there's exceptions for stuff that didn't/couldn't go in the table which gets called with on room gosub Since arranging the sprites in bB results in a lot of redundant loading of the index (room) (which irks me ) I also did a version in asm ======= I changed the draw_room code to on-goto and got rid of the string of if-thens game-16_mod.bas game-16_mod_w_asm.bas Thank you for taking the time to review my code and make changes and suggestions. I haven't looked at what you've done yet as I've been too busy the last few weeks to dedicate any time to Atari related projects. I hope to get back to this project next week. I agree that the jumping code is messy. I didn't spend much time on it and I'm sure it could be done much more efficiently. Just like most of my game projects, I start off with a grand idea and it changes and evolves as I work on it. The playfield changes in the most recent version are so small between screens it seems like a huge waste of ROM space to redefine the playfield with every room change. The only thing that changes right now is the vertical barriers and the trees on top (which are purely cosmetic). I was excited about this as I started on it but it looks like it could turn into another months long (or year long) project to make it into what I really want. I'm considering starting over on something completely different. It has been a great learning exercise on figuring out the DPC+ kernel either way. Maybe I just need to take a little break from coding for a while. Steve Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted August 28, 2013 Author Share Posted August 28, 2013 I've been working on this the last few weeks and wanted to share what I've done so far. It's now a playable game. You run around the jungle searching for treasure, once you find one another is randomly placed somewhere else. Avoid the scorpions, rolling logs, arrows, alligators and pits. You get three lives and will restart at the first screen if you lose a life. There is no sound yet and it still needs quite a bit of polish, but it's playable and kind of fun. I'll be working on it more in the coming week. EDIT: Forgot to mention that there are three difficulty levels/speeds. Right now the speed will ramp up twice, after getting 5 and 15 treasures. jadv.bin jadv.txt 5 Quote Link to comment Share on other sites More sharing options...
+TrekMD Posted August 28, 2013 Share Posted August 28, 2013 Very nice! Quote Link to comment Share on other sites More sharing options...
bogax Posted August 29, 2013 Share Posted August 29, 2013 (edited) I think there would be significant savings if you can get rid of all these gosub's to (and returns from) a different bank (and all the if-thens) if room=0 then gosub r0c bank4 if room=1 then gosub r1c bank4 if room=2 then gosub r2c bank4 if room=3 then gosub r3c bank4 if room=4 then gosub r4c bank4 if room=5 then gosub r5c bank4 if room=6 then gosub r6c bank4 if room=7 then gosub r7c bank4 if room=8 then gosub r8c bank4 if room=9 then gosub r9c bank4 if room=10 then gosub r10c bank4 if room=11 then gosub r11c bank4 if room=12 then gosub r12c bank4 if room=13 then gosub r13c bank4 if room=14 then gosub r14c bank4 if room=15 then gosub r15c bank4 something like goto rxc bank4 continue . . . bank 4 rxc on room gosub r0c r1c r2c .. r15c goto continue bank2 r0c some code return thisbank etc. . . . r15c some code return thisbank Edited August 29, 2013 by bogax Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted August 29, 2013 Author Share Posted August 29, 2013 I think there would be significant savings if you can get rid of all these gosub's to (and returns from) a different bank (and all the if-thens) if room=0 then gosub r0c bank4 if room=1 then gosub r1c bank4 if room=2 then gosub r2c bank4 if room=3 then gosub r3c bank4 if room=4 then gosub r4c bank4 if room=5 then gosub r5c bank4 if room=6 then gosub r6c bank4 if room=7 then gosub r7c bank4 if room=8 then gosub r8c bank4 if room=9 then gosub r9c bank4 if room=10 then gosub r10c bank4 if room=11 then gosub r11c bank4 if room=12 then gosub r12c bank4 if room=13 then gosub r13c bank4 if room=14 then gosub r14c bank4 if room=15 then gosub r15c bank4 something like goto rxc bank4 continue . . . bank 4 rxc on room gosub r0c r1c r2c .. r15c goto continue bank2 r0c some code return thisbank etc. . . . r15c some code return thisbank Good point bogax, I'll do that in the next revision. I am getting low on space in bank 2. Quote Link to comment Share on other sites More sharing options...
PFL Posted August 29, 2013 Share Posted August 29, 2013 I haven't had a chance to play with this but i just wanted to say that that screenshot looks gorgeous. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted January 4, 2014 Author Share Posted January 4, 2014 It's the start of a new year and I'm feeling the urge to start another project. I had lots of free time this week since it was slow at work and I took the time to update my website bjars.com, which took waaaaay longer than I thought. My first site overhaul since 2006 took about 15 hours of work. I did take the time to play a bunch of my old hacks and bB games during that time and I'm ready to start a new game. My favorite old game that I wrote is definitely Bombs Away, I spent the most time playing that one tonight. I lost my most recent updates to the Jungle adventure demo due to a PC crash a few months ago which kind of took the steam out of this project, and while it looks cool, after playing the most recent version I posted I'm thinking of starting over. It looks nice but to me it just seems kind of boring to play. I'm trying now to get inspired to start on something new and try and use the AtariVox I got late last year. I've got tons of reserved space for future games, I only used 3 bytes of my assigned space for Gate Racer II. Happy new year! Now back to the Cotton Bowl... go Mizzou! 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 4, 2014 Share Posted January 4, 2014 Glad to see you back in action, man Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted January 4, 2014 Share Posted January 4, 2014 Well, now you've got 64k to work with - I'm thinkin' Cave In II! 1 Quote Link to comment Share on other sites More sharing options...
