linuxfanman Posted April 7, 2013 Share Posted April 7, 2013 Hello all, I was just throwing this out to hopefully find an answer. I have a Pong c-100 that I found at my mom and dads this weekend that I used to play when I was a kid. Anyhow, It will display the game, play sound, but it starts on its own and will not keep score. I have it taken apart, and found that it has the 3659-3 IC in it. It also has a 7404-n Hex inverter in it. My question is, does anyone know what could be causing the issues with the score and self starting or if anyone has the pin outs for the 3659-3 IC? Any help would be appreciated. I tested the start switch, no shorts; also tested the diodes, good. I've tested most of the resistors, good. I haven't tested all the caps yet but none seem to be leaky. That leaves the chip or the transistors from what I gather. But I am not to sure. I would love to play my original old pong system that I played back when I was 4 year old again. I also included a schematic of the c-100 to help you help me out... Quote Link to comment Share on other sites More sharing options...
linuxfanman Posted April 9, 2013 Author Share Posted April 9, 2013 Just in case this happens to anyone else and it can help you out.... It turned out to be either R12 or C14. I doubt if it was the resistor but I replaced it anyway. I'm suspecting the capacitor was good enough to test ok with my capacitance meter but under load it failed.. Quote Link to comment Share on other sites More sharing options...
willwinter Posted August 21, 2019 Share Posted August 21, 2019 Hi linuxfanman... I'm currently having this exact problem. I will check out R12 and C14 to see if that will fix it. Thanks! And extra thanks to replying to your own question with your solution! Quote Link to comment Share on other sites More sharing options...
willwinter Posted August 22, 2019 Share Posted August 22, 2019 Hi again linuxfanman, I replaced the .001uf capacitor at C14 and it indeed fixed my issue! I did not replace the resistor at R12. Thanks again! My Pong C-100 is working perfectly now. Best, Will Winter Quote Link to comment Share on other sites More sharing options...
ahofle Posted June 27, 2022 Share Posted June 27, 2022 On 8/22/2019 at 2:13 PM, willwinter said: Hi again linuxfanman, I replaced the .001uf capacitor at C14 and it indeed fixed my issue! I did not replace the resistor at R12. Thanks again! My Pong C-100 is working perfectly now. Best, Will Winter Hello, sorry to resurrect this old thread, but I'm having the exact same issue and trying to replace C14 but need help finding the replacement part. Does the voltage matter? All the .001 uf capacitors I'm finding are 1000V. Any links would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted June 28, 2022 Share Posted June 28, 2022 10 hours ago, ahofle said: Does the voltage matter? All the .001 uf capacitors I'm finding are 1000V. The voltage indicated in capacitors specs is the max rating, so, as long as it's not less than the actual voltage that will be applied to it in the circuit (5v in this case), it's fine. Quote Link to comment Share on other sites More sharing options...
ahofle Posted June 28, 2022 Share Posted June 28, 2022 Thanks! Quote Link to comment Share on other sites More sharing options...
ahofle Posted July 2, 2022 Share Posted July 2, 2022 OK...so I actually have a Super Pong (C-140) and I've replaced this damn C14 capacitor 3 times now with no luck. I've also replaced the NC reset switch with no luck. Once or twice I was able to play with the score working, but usually it just zeros out. Obviously something is intermittent. I put a piece of metal between the capacitor conrtacts and held it in place and everything worked perfectly. Once I let it go, it's back to no scoring. Any suggestions on what to try next? At a loss here. One note is on my C-140 there is no resistor in the R12 spot. I guess that's normal for the C140? Quote Link to comment Share on other sites More sharing options...
ahofle Posted July 5, 2022 Share Posted July 5, 2022 (edited) Updating this for the benefit of others...it turns out the issue was neither the capacitor nor the reset switch itself. The little blue plastic connector that plugs into the board was actually the issue. I was never able to get a clean connection. When I manually bridged the two pins on the board everything worked fine. Tried cleaning it and the contacts with no luck. For kicks, I reattached it 180 degrees from normal and everything magically works perfectly now. Edited July 5, 2022 by ahofle 1 Quote Link to comment Share on other sites More sharing options...
