san-d-2000 Posted May 10, 2013 Share Posted May 10, 2013 (edited) I would recommend you to use this test ROM http://atariage.com/...m/#entry2748035 It would be interesting if it uncovers some failure in RAM. Ok so here's the story, i would get scrambled graphics or games would freeze, i bought two SGM's and both had the same result so it wasn't the SGM. First thought was the power supply, in Europe it's very hard or impossible to get a loose power supply, i remembered i still have the US one which i got with my Yurkie Vision, so i ordered a step down converter (220Volt to 110 Volt) online for 70EUR which is now at the postoffice. Than i remembered a fellow collector who also lives in Amsterdam and asked him if he had a cheap system for sale, he only had a boxed one, so i bought the boxed system mainly for the power supply. Tried it at home still the same problem. Than i noticed that pushing the SGM up or down would give different results, so in the end i bent the iron clamps in the extension port with a screwdriver, so they hold the SGM real tight, placed the Colecovision on a realy flat surface and now it all works Only Super Zaxxon doesnt work, which did work before i bended the clams Edited May 10, 2013 by san-d-2000 Quote Link to comment Share on other sites More sharing options...
retroillucid Posted May 10, 2013 Share Posted May 10, 2013 I guess it's time to look for a power replacement (Lord of the Dungeon also never worked on my system so that was already an indication). If Lord of the Dungeon doesn't work Then it might be your power supply for sure. Have you ever tried a Canadian Power supply? Quote Link to comment Share on other sites More sharing options...
san-d-2000 Posted May 10, 2013 Share Posted May 10, 2013 If Lord of the Dungeon doesn't work Then it might be your power supply for sure. Have you ever tried a Canadian Power supply? Just tried Lord of the Dungeon with the power supply from the European system i bought today, and it works now. I think the problem is a worn out expansion port. Any suggestions on fixing that? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted May 10, 2013 Share Posted May 10, 2013 Just tried Lord of the Dungeon with the power supply from the European system i bought today, and it works now. I think the problem is a worn out expansion port. Any suggestions on fixing that? At least, it's not your power supply... Well, I never had to clean out the expension port to be honest But I'm sure you can fix this by using the same products people uses to clean their unit Quote Link to comment Share on other sites More sharing options...
opcode Posted May 10, 2013 Author Share Posted May 10, 2013 Just tried Lord of the Dungeon with the power supply from the European system i bought today, and it works now. I think the problem is a worn out expansion port. Any suggestions on fixing that? Have you tried any of the diagnostic tools? Quote Link to comment Share on other sites More sharing options...
NIAD Posted May 10, 2013 Share Posted May 10, 2013 Than i noticed that pushing the SGM up or down would give different results, so in the end i bent the iron clamps in the extension port with a screwdriver, so they hold the SGM real tight, placed the Colecovision on a realy flat surface and now it all works Only Super Zaxxon doesnt work, which did work before i bended the clams Sounds kind of similar to the problem I had initially with the SGM not recognizing on my main system. My solution was to add two rubber pads to the already existing rubber pads on the bottom/front of my ColecoVision. Once I did this, the SGM has worked flawlessly with my system due to the lineup of the SGM and Expansion Bus being corrected height wise. I have yet to open up the CV in question to make sure PCB is seated properly, but was already expecting to have to adjust the "iron clamps"/guides in the Expansion Bus Interface. BTW, the SGM was recognized without any issue on a couple of ADAM systems that I tested it out on. Weird about Zaxxon Super Game. It makes absolutely no sense. Does this happen with both SGM units that you own? Quote Link to comment Share on other sites More sharing options...
+grips03 Posted May 11, 2013 Share Posted May 11, 2013 Have you tried Deoxit? http://www.deoxit.com/ Quote Link to comment Share on other sites More sharing options...
Arjak Posted May 12, 2013 Share Posted May 12, 2013 Interesting. Good to see King's Valley is getting some love. Konami is always great. How about Thexder? How far have you guys gone. I just received Thexder in the mail and played it for a while today. I like it, even though it continually kicks my ass. After several games, the farthest I've made it is this room in Level 2 where those red molecule enemies always swarm me and take me out in half a minute. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted May 12, 2013 Share Posted May 12, 2013 I just received Thexder in the mail and played it for a while today. I like it, even though it continually kicks my ass. After several games, the farthest I've made it is this room in Level 2 where those red molecule enemies always swarm me and take me out in half a minute. Sounds like you should be using the shield. Just saying. Quote Link to comment Share on other sites More sharing options...
san-d-2000 Posted May 13, 2013 Share Posted May 13, 2013 Well Mystery solved, today i went to the attic searched through about 25 boxes (all Atari stuff) and in the last box i found two Colecovision systems, both work flawless with the SGM, so i guess my Yurkievision has bad DRAM. Was nice to finally play Thexder without the fear of my system crashing mid-game. So a quick question what's more Easy replace the DRAM or do an AV mod on the other other two? Quote Link to comment Share on other sites More sharing options...
Kiwi Posted May 13, 2013 Share Posted May 13, 2013 You may want to contact Yurkie, he might have a warranty on his product. Quote Link to comment Share on other sites More sharing options...
StragglyMarlin5 Posted May 14, 2013 Share Posted May 14, 2013 (edited) I would LOVE to see a SGM version of Missle Command, and Im guessing it wouldnt be terribly hard to make. Would be just like the arcade with the track ball controller Edited May 14, 2013 by StragglyMarlin5 Quote Link to comment Share on other sites More sharing options...
65Gamerguy Posted May 17, 2013 Share Posted May 17, 2013 I just received my Super Game Module today! Wow! I am so impressed by the whole thing. The awesome packaging, everything. I felt like Steve Martin in The Jerk when he sees his name in the phone book. I wanted to jump up and down in the driveway and scream "The Super Game Module is here, the Super Game Module is here!". But since I didn't want to be commited to a mental institution, I remained as calm as I could until I got in the house. Eduardo, and everyone else involved, thank you so much for your dedication, devotion, and everything else. I know it has been a long journey for you to get this finished but I have to say you have done an excellent, if not perfect, job! I really can't thank all you great people that continue to make the ColecoVision better and better! 2 Quote Link to comment Share on other sites More sharing options...
digress Posted May 17, 2013 Share Posted May 17, 2013 I have received the SGM a few weeks ago but didn't have much time til lately to try it out. Looks Great, Works Great in both my colecovision & ADAM. THEXDER on my colecovision. This is beyond cool. I think of thexder as a late 80's game I played on my tandy 1000. I am really impressed with this game version. I am espicaially impressed with the sheer number of colours used on the mech sprites. (how many overlayed sprites were used per frame? ) Kings valley is neat. Reminds me of BAGMAN Dragons Lair & Zaxxon are great too. I had already played them on my ADAM but they are much faster to run in cart form. Bring on Buck Rogers. Oh and of course Donkey Kong. Now I have D2K Arcade on intellivision and that is excellent but I'm looking forward to having the best donkey kong conversion be back on colecovision again. Any documents about how to program for 1) the megacart 2) the SGM. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted May 17, 2013 Share Posted May 17, 2013 Any documents about how to program for 1) the megacart 2) the SGM. For the SGM you have the information here http://atariage.com/forums/topic/203851-super-game-module-technical-forum/ Pixelboy provided me information about Megacart when developing Princess Quest but he got it from Opcode, so you should send a PM to Opcode. Quote Link to comment Share on other sites More sharing options...
opcode Posted May 27, 2013 Author Share Posted May 27, 2013 Is anyone able to watch this? Movie won't load for me.... 3 Quote Link to comment Share on other sites More sharing options...
tomjscott Posted May 27, 2013 Share Posted May 27, 2013 Is anyone able to watch this? http://www.youtube.com/watch?v=s4zzQT8RClc Movie won't load for me.... Plays for me fine. Quote Link to comment Share on other sites More sharing options...
skosh Posted May 27, 2013 Share Posted May 27, 2013 Plays fine for me as well. Quote Link to comment Share on other sites More sharing options...
Jaymiester Posted May 27, 2013 Share Posted May 27, 2013 It shows up in chrome as an unsafe script for me. In order to watch it, I have to right click the icon on the right side of the address bar and click "allow unsafe script" for it to load and play. Hope this helps ya. BTW, cool little video....the guy demoing it is entertaining. Quote Link to comment Share on other sites More sharing options...
opcode Posted May 27, 2013 Author Share Posted May 27, 2013 Yeah, it started working here too. Go figure out, I tried 2 different computers, iPad, iPhone and it didn't work with any of them the first time around. Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted May 28, 2013 Share Posted May 28, 2013 Totally awesome! Quote Link to comment Share on other sites More sharing options...
SKELETOR68 Posted May 28, 2013 Share Posted May 28, 2013 Has anybody in Canada recieved their SGM from the first run? I have Super Zaxxon just itching to be employed on my Coleco. Quote Link to comment Share on other sites More sharing options...
digress Posted May 31, 2013 Share Posted May 31, 2013 Yes I have mine and I am in Canada . all four SGM games are excellent. My favourite is Thexder. By the way if anyone is not sure, l found the Konami‘s Ping—Pong game to be a real sleeper. This is a really fluid game that plays very naturally on the coleco controller with a very exact shot placement and you can really get into it. I was very surprised by the this game. I would actually recommend it above some other games Quote Link to comment Share on other sites More sharing options...
SKELETOR68 Posted May 31, 2013 Share Posted May 31, 2013 Thanks Digress, really looking forward to recieving mine soon. Quote Link to comment Share on other sites More sharing options...
Tony Cruise Posted June 1, 2013 Share Posted June 1, 2013 Really looking forward to receiving mine in the next week or so, then I can try out Kings Valley and Super Zaxxon Plus until I do some more memory optimisation my next game Pyxidis is not running in 1k so needs to SGM. I do want to try and make that one work without, but work in enhanced mode if it detects the SGM and/or extra memory of the Adam. Best of both worlds then. 1 Quote Link to comment Share on other sites More sharing options...
