Jess Ragan Posted May 14, 2013 Share Posted May 14, 2013 http://kiblitzing.blogspot.com/2013/05/its-odd-odd-odd-odd-mod-rebuilding.html I recently found an old Odyssey2 rotting away in my parents' barn, so I decided I'd bring it back to life as a weekend project, while giving the hardware some much-needed modern conveniences. It was one of the later models with hardwired controllers, so I pulled them out and replaced them with 9-pin controller ports, making the system compatible with Atari, Coleco, and Sega joysticks. I also chucked the badly rusted RF modulator box inside the Odyssey2, and replaced it with a composite video cable scavenged from a Chinese TV Games unit. It's still an Odyssey2, with all the baggage that comes with it, but at least I can play its games with my favorite controllers and connect it to a modern television set. The best part is that the mods were sinfully easy, requiring only moderate soldering skill, a few spare parts, and absolutely none of the electrical math I dread. Here's the information I used to hack the system: Joystick information: http://www.racketboy.com/forum/viewtopic.php?t=22012 A/V connections: http://www.the-nextlevel.com/odyssey2/faq/essentials/#51 My only major beef is with the screws I used to attach the two joystick ports. I just used what I had on hand, but I'm pretty sure I could find something better suited to the task, with screw-on bolts for the other ends to keep the ports secure. Aside from that, I'm pretty proud of my work! Now I'm itching to tackle another system; possibly that unloved Vader 2600 in the tractor shed. 2 Quote Link to comment Share on other sites More sharing options...
Serious Posted May 14, 2013 Share Posted May 14, 2013 I'd love to see some photos of what you've done. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted May 14, 2013 Author Share Posted May 14, 2013 Sure! Will these do? 1 Quote Link to comment Share on other sites More sharing options...
Seob Posted May 14, 2013 Share Posted May 14, 2013 (edited) Next step get rid of all cables. Edited May 14, 2013 by Seob Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted May 14, 2013 Author Share Posted May 14, 2013 How'd you manage to mount the joystick connectors on the back? I tried this, but the circuit board got in the way. Did you use D-shell connectors with downward facing pins? I used D-shells with solder cups, myself. I would have used RCA ports instead of an A/V cable, but I didn't have any to spare. I did, however, have a TV Games unit from China that I never wanted to lay eyes on again. I figured I might as well take advantage of it. The advantage to this is that the cable is right there when I need it... I don't have to dig around for one. I noticed that you put in a new AC adapter and power switch. The power switch I can understand (the default power button is kind of crummy... mine's very stiff and a little unpredictable), but why a new AC adapter? An NES power supply works pretty well with a later model Odyssey2, and they're not exactly in short supply. Quote Link to comment Share on other sites More sharing options...
Seob Posted May 15, 2013 Share Posted May 15, 2013 How'd you manage to mount the joystick connectors on the back? I tried this, but the circuit board got in the way. Did you use D-shell connectors with downward facing pins? I used D-shells with solder cups, myself. I would have used RCA ports instead of an A/V cable, but I didn't have any to spare. I did, however, have a TV Games unit from China that I never wanted to lay eyes on again. I figured I might as well take advantage of it. The advantage to this is that the cable is right there when I need it... I don't have to dig around for one. I noticed that you put in a new AC adapter and power switch. The power switch I can understand (the default power button is kind of crummy... mine's very stiff and a little unpredictable), but why a new AC adapter? An NES power supply works pretty well with a later model Odyssey2, and they're not exactly in short supply. Hi Jess, This is Odyssey's european sister the Videopac. They don't come with a power switch at all, so that's why i added it. There are also a lot of different versions of the videopac, some come with a separate power supply some with built in power suplly. This model came with a built in power supply, so a power cord was attached to the console. Since i wanted to get rid of all attached cables i put in the power socket. Don't know if there is a difference internally between the mainboard of the odyssey and videopac, but the console had the room between the mainboard and the back. I also used soldercups d-connetors. Here is a view of the inside. All modding has been don on the bottom part of the console, so i can swap it with a different top if this breaks. Quote Link to comment Share on other sites More sharing options...
