debug with skunkboard
Hi all,
im trying to debug with skunkboard (jserve.exe and jcp)
the jseve.exe looks good ..
reseted skunboard, green screen, i open, and ...
(waiting on localhost:4567) -> so far so good
but the jcp -c stucks at:
C:\>jcp -c
jcp v02.03.01 built on Oct 14 2009
Skip 0 bytes, base addr is $4000, length is 0 bytes
Finished in 0 millis, 0KB/second.
Starting console...
any ideas?
did i started the tools in correct order?
(remark: one time he "waited for 68k handshake" but after waiting long time i aborted)
Are you sure that's updated? The latest one was built June 2013.
Oh nevermind. This post is older than that.
Edited by JagChris
hi there,
as i tested today the skunkboard console skunkWRITEFILE i noticed that it writes nothing into my dumpfile.txt and the console hangs :-(
any idea? i am using windows (7)
i did a very trivial test (nearly 1:1 as in the skunkboard PDF description)
can someone test it with his dev env?
would be helpfull so i can see if the problem is my PC
http://www.hochrhein-it.de/tmp/jaguar/SkunkDebug.zip
greetz to all jagcoders
Otto fixed your problem :)
It is due to the label 'testbytes' falling on an odd address. if you put .EVEN on the line before it, your code should work fine :) (Well it does for me :) )
One thing I have learnt is that a lot of weird errors are often just caused by alignment issues, be they OP, RISC, Blitter etc. The worst ones I had were writing the SoundEngine and I would add a line of code or two and the whole thing would die, even though the code I was modifying hadn't been called at that point.. then adding a NOP in an unused bit of code would fix it. Transpired that the alignment of some memory was out of alignment, but it took me a few hours to clock it! and then I had fun and games due to a bug in ALN that I had to work around :D
So glad we now have RLN and someone actively fixing it (praise be to shamoo! :D )
