+Nathan Strum Posted May 26, 2013 Share Posted May 26, 2013 (edited) Also, is it just me or are these carts really hard to get into the 2600? Because I've been struggling to make it fit. These work great for that sort of thing. Edited May 26, 2013 by Nathan Strum Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted May 26, 2013 Share Posted May 26, 2013 Also, is it just me or are these carts really hard to get into the 2600? Because I've been struggling to make it fit. I've had zero issues cramming any of the AtariAge carts into my Woodgrain 4-switcher, though I've had a couple of wierdly shaped third party carts stick a little. What model Atari are you using? Heavy 6, Light 6, Woodgrain 4, Vader 4, Jr, or 7800? Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted May 26, 2013 Share Posted May 26, 2013 Woodgrain 4. Quote Link to comment Share on other sites More sharing options...
mkiker2089 Posted May 26, 2013 Share Posted May 26, 2013 The carts are all original Atari carts so I don't know why they wouldn't fit. There's a spring inside that gives some resistance, maybe it's getting stuck? You can use a screwdriver or something to push in a tab on the cart and then push down the cover gate. If it is hard to push down then that's the problem. Quote Link to comment Share on other sites More sharing options...
Sprybug Posted May 26, 2013 Share Posted May 26, 2013 My princess Rescue cartridge arrived today! When I first played it, pressing up on the joystick wouldn't fire. I freaked out a little bit. I switched to the Genesis pad and it fired. Switched back to an Atari joystick, and that fired okay. I had the Difficulties both set to A, and an AtariVox was plugged in. Maybe that caused it to sense a Genesis when the stick was in? No problems since. I see Al has announced this game on the storefront page and Facebook. I hope you sell a lot of copies. This game is what the Atari 2600 is all about - great gameplay! If I can put all my thoughts into the right words, this is one game I want to review! Hmmmmm.... It almost sounds like the joystick wasn't plugged in all the way or you have a loose wire on that joy. Once you replugged it in it made all the connections again. 1 Quote Link to comment Share on other sites More sharing options...
Sprybug Posted May 26, 2013 Share Posted May 26, 2013 Also, is it just me or are these carts really hard to get into the 2600? Because I've been struggling to make it fit. Once mine comes in I'm gonna give it a go on my self made portable Atari 2600 and my AV modded 4 switch wood grain. I won't get it for a while yet, cuz I'll be getting it CIB. I'm curious if I'll have the same issue. From what I understand Al is using old cart cases for the homebrews and occasionally I will come across an old Atari 2600 game that has a little bit of an issue getting in and out of an Atari system only because the dust protector that's supposed to slide up and down rather sticks or sticks in the inserted position causing it not to properly line up with the cover slider on the Atari 2600. 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted May 27, 2013 Author Share Posted May 27, 2013 The PCB inside the cartridge can shift a bit, causing the dust cover mechanism to get stuck. This can usually be fixed by wiggling the cart while pushing it into the console and/or by pressing down on the label side of the cart closest to the 2600 while inserting the cart. ..Al Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted May 27, 2013 Share Posted May 27, 2013 I just got finished watching the game play for this game. It's hugely improved over the WIP version I have on my Harmony. Congratulations on a great translation! Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted May 27, 2013 Share Posted May 27, 2013 Order placed Quote Link to comment Share on other sites More sharing options...
Albert Posted May 27, 2013 Author Share Posted May 27, 2013 Only seven boxed copies of Princess Rescue remain! ..Al Quote Link to comment Share on other sites More sharing options...
Cebus Capucinis Posted May 27, 2013 Share Posted May 27, 2013 Only seven boxed copies of Princess Rescue remain! ..Al Is this a limited run, or will there be more available? I already ordered but it's sort of like frosted mini wheats -- the player in me wants a second run but the collector in me wants limited edition. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted May 27, 2013 Share Posted May 27, 2013 Is this a limited run, or will there be more available? I already ordered but it's sort of like frosted mini wheats -- the player in me wants a second run but the collector in me wants limited edition. Limited to 100 boxes. Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted May 28, 2013 Share Posted May 28, 2013 Only seven boxed copies of Princess Rescue remain! Bummer. I was going to order eight of them, now I guess I'll just skip it. Quote Link to comment Share on other sites More sharing options...
Albert Posted May 28, 2013 Author Share Posted May 28, 2013 Bummer. I was going to order eight of them, now I guess I'll just skip it. I'll save you a boxed copy. ..Al Quote Link to comment Share on other sites More sharing options...
kaz321123 Posted May 28, 2013 Share Posted May 28, 2013 I just ordered one-I hope I made it in time Looks like a very fun game Quote Link to comment Share on other sites More sharing options...
Albert Posted May 28, 2013 Author Share Posted May 28, 2013 I just ordered one-I hope I made it in time Looks like a very fun game Yes, you did, and yes, it is. ..Al Quote Link to comment Share on other sites More sharing options...
mkiker2089 Posted May 28, 2013 Share Posted May 28, 2013 Let me know when the 100 are gone so I can pretend I meant to order one and fuss about it. Cart only for me. I would just feel bad after losing the box anyway. A cart can go in my woodgrain storage tower. then again I used to lose the manuals that came with my NES games as a youngin' and old habits stick with us. My Atari games never had manuals as they all came from flea markets. Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted May 28, 2013 Share Posted May 28, 2013 (edited) Is this a limited run, or will there be more available? I already ordered but it's sort of like frosted mini wheats -- the player in me wants a second run but the collector in me wants limited edition. You've got it all backwards. The collector in me wants the box; the player in me just wants to cram the cart into the Atari. The unboxed edition is unlimited. Only seven boxed copies of Princess Rescue remain! ..Al Crap, it looks like I'll never get my wishlist fulfilled at this rate! Edited May 28, 2013 by stardust4ever Quote Link to comment Share on other sites More sharing options...
IHATETHEBEARS Posted May 28, 2013 Share Posted May 28, 2013 Arrived from vacation last night to find this waiting for me in the mailbox. I'm absolutely stunned. This is an amazing piece of work. Great job! The opening title screen blew me away. I've never seen anything on Atari that looked so good. Very well done! Quote Link to comment Share on other sites More sharing options...
+Razzie.P Posted May 28, 2013 Share Posted May 28, 2013 Got my orders in. 1 boxed and 1 cart Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted May 28, 2013 Share Posted May 28, 2013 Sprybug, I'm curious if you changed the AI a bit from one BJ battle to the next. I've beaten the World 1 boss numerous times, but I keep getting licked by BJ at the end of World 2. I noticed when I run underneath him as he jumps, then I prepare to jump on his head and he doesn't park himself in the same place that he did in World 1. My strategy is to try to get close enough to him right where he stops moving and attempt to multibonk on his head. I die a lot. Boss memorization has always been a weakness of mine with NES style 8-bit games btw. Quote Link to comment Share on other sites More sharing options...
iesposta Posted May 28, 2013 Share Posted May 28, 2013 I see the boxed version can no longer be purchased. That was fast, what, a week? Quote Link to comment Share on other sites More sharing options...
Albert Posted May 28, 2013 Author Share Posted May 28, 2013 I see the boxed version can no longer be purchased. That was fast, what, a week? Yep! I need to update some pages now that the boxed version is sold out. ..Al Quote Link to comment Share on other sites More sharing options...
Sprybug Posted May 29, 2013 Share Posted May 29, 2013 Yep! I need to update some pages now that the boxed version is sold out. ..Al No way...Al, did you save me a copy that you were going to send my way hopefully? How many of the cart & manuals have sold BTW? 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted May 29, 2013 Author Share Posted May 29, 2013 No way...Al, did you save me a copy that you were going to send my way hopefully? You will of course get a boxed copy of the game. ..Al 1 Quote Link to comment Share on other sites More sharing options...
