RobertLM78 Posted June 30, 2013 Share Posted June 30, 2013 (edited) So, I found this atarisoft.dsk on the whtech page, and moved a few files over to the TI (not every game, since the disk image is >90k). When I run the LOADer, I get a single option in the menu: 1 Terminate. Does every game need to be on the disk, or am I missing something? Thanks! Edit: the whtech atari directory ftp://ftp.whtech.com/games/Atarisoft/ Edited June 30, 2013 by RobertLM78 Quote Link to comment https://forums.atariage.com/topic/214034-atairsoft-games-on-whtech/ Share on other sites More sharing options...
+Lee Stewart Posted July 1, 2013 Share Posted July 1, 2013 So, I found this atarisoft.dsk on the whtech page, and moved a few files over to the TI (not every game, since the disk image is >90k). When I run the LOADer, I get a single option in the menu: 1 Terminate. Does every game need to be on the disk, or am I missing something? Thanks! Edit: the whtech atari directory ftp://ftp.whtech.com/games/Atarisoft/ The programs on all three disks appear to work fine. It's the LOAD programs that are screwed up. The ROBOTRON disk XB LOAD program works for the programs that are actually on the disk. The ATARI and ATARISOFT disk LOAD programs obviously do not work. If you want to play the games, use the Editor/Assembler cartridge and run any game you choose as E/A Option 5 "Run Program File"—they all appear to be E/A 5 programs and all of those I tried ran fine. ...lee Quote Link to comment https://forums.atariage.com/topic/214034-atairsoft-games-on-whtech/#findComment-2784646 Share on other sites More sharing options...
RXB Posted July 1, 2013 Share Posted July 1, 2013 The programs on all three disks appear to work fine. It's the LOAD programs that are screwed up. The ROBOTRON disk XB LOAD program works for the programs that are actually on the disk. The ATARI and ATARISOFT disk LOAD programs obviously do not work. If you want to play the games, use the Editor/Assembler cartridge and run any game you choose as E/A Option 5 "Run Program File"—they all appear to be E/A 5 programs and all of those I tried ran fine. ...lee Or uses RXB and use the EA option of RXB to load them. Quote Link to comment https://forums.atariage.com/topic/214034-atairsoft-games-on-whtech/#findComment-2784762 Share on other sites More sharing options...
RobertLM78 Posted July 1, 2013 Author Share Posted July 1, 2013 The programs on all three disks appear to work fine. It's the LOAD programs that are screwed up. The ROBOTRON disk XB LOAD program works for the programs that are actually on the disk. The ATARI and ATARISOFT disk LOAD programs obviously do not work. If you want to play the games, use the Editor/Assembler cartridge and run any game you choose as E/A Option 5 "Run Program File"—they all appear to be E/A 5 programs and all of those I tried ran fine. ...lee Thanks Lee and RXB for the responses . That was easy enough - sorry about my density Quote Link to comment https://forums.atariage.com/topic/214034-atairsoft-games-on-whtech/#findComment-2784781 Share on other sites More sharing options...
