CatPix Posted July 5, 2013 Share Posted July 5, 2013 (edited) Hello all! I would like to know more about the Professionnal Arcade/Astrocade PSU. I found pictures on the net, of which give two different voltage (the first is for the Bally Professionnal Arcade and the second for the Astrovision Astrocade). So, what does it mean really? Can I replace a dead Bally Professionnal Arcade PSU with a simple 12V AC, as it seems to be what it is for the Astrocade ? If so, which wires will be paired as "live" and which as "neutral"? A more tricky question : can the PSU support 50htz? I know it's meant to, but I heard many time that most PSU made for 60 Htz are fine with 50 htz. Edited July 5, 2013 by CatPix Quote Link to comment Share on other sites More sharing options...
Sonaru Posted December 22, 2021 Share Posted December 22, 2021 (edited) You can replace a dead Bally ac adapter with a 12v 1 amp 12 watt adapter I am not sure if the polarity is negative or positive but I believe it's negative. No it will need to be 60hz in order for it to function. Edited December 22, 2021 by Sonaru Quote Link to comment Share on other sites More sharing options...
