boxpressed Posted August 7, 2013 Share Posted August 7, 2013 Found these plans on PlayVectrex.com: http://www.playvectrex.com/vectech/vectrack.txt Looks like it is not a true analog trackball, but cool nonetheless! Quote Link to comment Share on other sites More sharing options...
+save2600 Posted August 7, 2013 Share Posted August 7, 2013 Looks like way too much work though! Quote Link to comment Share on other sites More sharing options...
mkiker2089 Posted August 7, 2013 Share Posted August 7, 2013 If it's not analoug then doesn't that defeat the purpose? Why can't it be modded to offer analoug? The PS1 joystick works that way so it's possible. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted August 7, 2013 Share Posted August 7, 2013 I have one, rarely used it. Mitch Quote Link to comment Share on other sites More sharing options...
50TBRD Posted August 7, 2013 Share Posted August 7, 2013 I remember seeing a video of someone playing Patriots with a modded trackball. I've done the spinner mod but this looked really involved. Quote Link to comment Share on other sites More sharing options...
ilovethevectrex Posted August 31, 2013 Share Posted August 31, 2013 it would be awesome if someone made a homebrew multicart with several homebrew trackball games, and then included a vectrex trackball with it. i would so buy it Quote Link to comment Share on other sites More sharing options...
Vectrexer Posted September 25, 2020 Share Posted September 25, 2020 https://www.youtube.com/watch?v=DSqJsToqVrg 1 Quote Link to comment Share on other sites More sharing options...
BinaryStar Posted October 1, 2020 Share Posted October 1, 2020 You can use an unmodified Atari CX-80 or CX-22 in true trackball mode with my modified versions of Star Hawk and Patriots. Star Hawk [Trackball Edition] can be found here : https://www.ebay.co.uk/itm/203123344865 and Patriots Deluxe is available from Packrat : http://www.packratvg.com/vpatriots.html 1 Quote Link to comment Share on other sites More sharing options...
ledzep Posted October 3, 2020 Share Posted October 3, 2020 On 10/1/2020 at 3:21 AM, BinaryStar said: You can use an unmodified Atari CX-80 or CX-22 in true trackball mode with my modified versions of Star Hawk and Patriots. Star Hawk [Trackball Edition] can be found here : https://www.ebay.co.uk/itm/203123344865 and Patriots Deluxe is available from Packrat : http://www.packratvg.com/vpatriots.html How have you modified the code? I mean, how is the trak-ball read (analog joystick pins, button pins) and are you converting gray code to something the Vectrex can use or doing something else? I've always wondered why nobody ever made a "real" trak-ball for the Vectrex, and I've always wondered if the Atari 5200 approach - convert trak-ball output into analog joystick output - would be the best option since people wouldn't need to change the games, only the controller. Quote Link to comment Share on other sites More sharing options...
BinaryStar Posted October 4, 2020 Share Posted October 4, 2020 (edited) My code reads the trackball DIR/CLK signals for each axis and updates the crosshair coordinates. Analog joystick emulation would certainly make it more compatible with games but it wouldn't be true trackball control which was the point of my hacks (and the CX-80 /CX-22 does not require any hardware hacks or adapters). I have more trackball compatible projects coming in the future, such as this one. Edited October 4, 2020 by BinaryStar 2 Quote Link to comment Share on other sites More sharing options...
colecovisionary Posted October 19, 2020 Share Posted October 19, 2020 I have a Vecadapt that allows me to use a Sega master system Sports Pad Trackball on the Vectrex. It is analog and does work with games that require only 2 buttons. Quote Link to comment Share on other sites More sharing options...
ledzep Posted October 22, 2020 Share Posted October 22, 2020 On 10/4/2020 at 8:25 AM, BinaryStar said: My code reads the trackball DIR/CLK signals for each axis and updates the crosshair coordinates. Analog joystick emulation would certainly make it more compatible with games but it wouldn't be true trackball control which was the point of my hacks (and the CX-80 /CX-22 does not require any hardware hacks or adapters). I have more trackball compatible projects coming in the future, such as this one. Sweet! So you're treating the trak-ball controller like a true trak-ball controller, not a joystick (directions only), correct? What pins are being read, then? I mean, are you sacrificing 2 button inputs and bypassing the joystick inputs? There is a spinner controller out there that does the same thing. I was wondering about somehow feeding the trak-ball through the joystick inputs so that the 4 buttons could still be used, which is why I mentioned the Atari 5200 solution. As an aside, I don't consider that Atari 5200 trak-ball/analog joystick emulation an issue because that sort of seems, to me, to simply be having the trak-ball convert the signals internally into something that the Vectrex is used to (analog joystick with direction and speed) vs. having the Vectrex convert the signals (through I assume a couple button inputs) from the trak-ball into what amounts to the same thing. So either the trak-ball does it and hands it off to the Vectrex or the Vectrex does it. I'm not saying the signals are the same, just the treatment of the data would have to be in order to have analog (direction + speed) movement vs. a digital joystick. I'm sure there's much I'm not understanding here so I guess what I'm asking is how do you use the DIR/CLK signals? Could you give an example of what those signals typically look like and how you use that to update the crosshair coordinates compared to how the joystick does (essentially) the same thing? Quote Link to comment Share on other sites More sharing options...
