Chandler Posted August 7, 2013 Share Posted August 7, 2013 hi all i have a couple of jags with issues and would really like to sort them as they look like new! 1: console 1: works fine but no sound! any ideas where i should start to look? 2: console 2: black screen when switched on with cartridge inserted, power LED ok, so dead board? thanks.. Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted August 8, 2013 Share Posted August 8, 2013 1: check REG1. 2: could be a lot of things, hard to tell without more info. 1 Quote Link to comment Share on other sites More sharing options...
Chandler Posted August 9, 2013 Author Share Posted August 9, 2013 ok the jag with no sound is repaired! it was REG 1 so what info do you need for jag no: 2? it has a dark grey / black screen with some small vertical moving lines green led on jag is on and working game inserted, no sound Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted August 10, 2013 Share Posted August 10, 2013 I would check the "easy" things first : voltage, resets signals, clocks, that kind of things. If everything looks OK, check the address and data buses and their control signals (it could be a broken track or defective buffer) ; you'll need an oscilloscope and lots of patience for that. Unfortunately the boot process needs a lot of things to run (Tom, Jerry, 68k, DRAM, ROM), so the fact that it doesn't boot doesn't tell much. Quote Link to comment Share on other sites More sharing options...
