jblenkle Posted September 28, 2013 Share Posted September 28, 2013 Matt Patrol - 34,600 Link to comment Share on other sites More sharing options...
Colecovision Posted September 28, 2013 Share Posted September 28, 2013 I can't figure out how to use the BIN file in blueMSX. How can I play the ROM? When I use Cartridge slot 1 it's not a supported format. There are a number of hacked prototype roms floating aorund the internet. To ensure that everyone playing this round is using the same ROM, i.e. the one used to obtain the Twin Galaxies high score, please download the attached and either play on a real CV using a multicart or use your favourite emulator (blueMSX is recommended).Matt Patrol (1984)(Atarisoft)(Prototype).zip (CRC: 90007079) Link to comment Share on other sites More sharing options...
jblenkle Posted September 28, 2013 Share Posted September 28, 2013 Rename the file with a .rom extension... I can't figure out how to use the BIN file in blueMSX. How can I play the ROM? When I use Cartridge slot 1 it's not a supported format. Link to comment Share on other sites More sharing options...
Colecovision Posted September 28, 2013 Share Posted September 28, 2013 Rename the file with a .rom extension... Thanks! Link to comment Share on other sites More sharing options...
gamecat80 Posted September 28, 2013 Share Posted September 28, 2013 23150 Higher score, but I always loose at least one life from those damn landmines... Link to comment Share on other sites More sharing options...
jblenkle Posted September 29, 2013 Share Posted September 29, 2013 Yeah, I think the mine section is the toughest part of the game...I think the secret is that you just have to go through it slow. If you speed up at all you usually mis-time your jump and get blown up. 23150 Higher score, but I always loose at least one life from those damn landmines... 1 Link to comment Share on other sites More sharing options...
gamecat80 Posted September 29, 2013 Share Posted September 29, 2013 Yeah, I think the mine section is the toughest part of the game...I think the secret is that you just have to go through it slow. If you speed up at all you usually mis-time your jump and get blown up. It is certainly the hardest section for me. It is the middle section from J to O. I do go thru that section slowly....but if I land too close to one of those landmines it wont let me jump and my moonbuggy gets blown up. The most difficult are the sections where the landmines are closer together and you don't have much clearance to land between them. After I finally passed that section it got easier again. Link to comment Share on other sites More sharing options...
Ikrananka Posted September 30, 2013 Author Share Posted September 30, 2013 Rename the file with a .rom extension... You actually don't even need to do that. After selecting File > Cartridge Slot 1 > Insert the file selection dialog box appears - just change the "Files of type" dropdown at the bottom from "ROM image" to "All Files (*.*)" Link to comment Share on other sites More sharing options...
Ikrananka Posted September 30, 2013 Author Share Posted September 30, 2013 It is certainly the hardest section for me. It is the middle section from J to O. I do go thru that section slowly....but if I land too close to one of those landmines it wont let me jump and my moonbuggy gets blown up. The most difficult are the sections where the landmines are closer together and you don't have much clearance to land between them. After I finally passed that section it got easier again. Don't jump too close to the mines. If you practice and consistently jump a little further ahead of each mine then you'll have no problem when you land between the two mines close together. Jumping a little further ahead ensures that you land also land a little earlier giving you enough time to jump over the second mine. Link to comment Share on other sites More sharing options...
Manoau2002 Posted October 1, 2013 Share Posted October 1, 2013 9800 Link to comment Share on other sites More sharing options...
Manoau2002 Posted October 2, 2013 Share Posted October 2, 2013 12250 Made it through the mine field Link to comment Share on other sites More sharing options...
Manoau2002 Posted October 2, 2013 Share Posted October 2, 2013 Yeah, I think the mine section is the toughest part of the game...I think the secret is that you just have to go through it slow. If you speed up at all you usually mis-time your jump and get blown up. Yeah taking it slow seems to be the only way Link to comment Share on other sites More sharing options...
Manoau2002 Posted October 2, 2013 Share Posted October 2, 2013 17900 Link to comment Share on other sites More sharing options...
patbb Posted October 2, 2013 Share Posted October 2, 2013 It is certainly the hardest section for me. It is the middle section from J to O. I do go thru that section slowly....but if I land too close to one of those landmines it wont let me jump and my moonbuggy gets blown up. The most difficult are the sections where the landmines are closer together and you don't have much clearance to land between them. After I finally passed that section it got easier again. What I do when the mine are very close is I press up to jump the first mine then I press up again repetitively, as fast as I can, so that as soon as the buggy lands its jumps right away. All that while going at "normal" speed ... without moving the joystick left or right. Link to comment Share on other sites More sharing options...
gamecat80 Posted October 3, 2013 Share Posted October 3, 2013 Don't jump too close to the mines. If you practice and consistently jump a little further ahead of each mine then you'll have no problem when you land between the two mines close together. Jumping a little further ahead ensures that you land also land a little earlier giving you enough time to jump over the second mine. What I do when the mine are very close is I press up to jump the first mine then I press up again repetitively, as fast as I can, so that as soon as the buggy lands its jumps right away. All that while going at "normal" speed ... without moving the joystick left or right. Yeah, I know now. Just something I'll have to practice. Link to comment Share on other sites More sharing options...
Northcoastgamer Posted October 3, 2013 Share Posted October 3, 2013 49,130. Practice on the championship course. As for the tiny mines, don't move, let the screen scroll to you, timing your jumps. Link to comment Share on other sites More sharing options...
Tony Cruise Posted October 4, 2013 Share Posted October 4, 2013 (edited) I am hopeless at the mine section - it stresses me out. This is the only time I made it past! 22,350 Edited October 4, 2013 by Electric Adventures Link to comment Share on other sites More sharing options...
CoLethalVision Posted October 4, 2013 Share Posted October 4, 2013 27,400 Link to comment Share on other sites More sharing options...
Manoau2002 Posted October 4, 2013 Share Posted October 4, 2013 22600 Link to comment Share on other sites More sharing options...
DonPedro Posted October 4, 2013 Share Posted October 4, 2013 Couldn't get past the minefield. 11,750 Link to comment Share on other sites More sharing options...
ed1475 Posted October 5, 2013 Share Posted October 5, 2013 10,850 Link to comment Share on other sites More sharing options...
Colecovision Posted October 5, 2013 Share Posted October 5, 2013 8,400 Link to comment Share on other sites More sharing options...
Manoau2002 Posted October 5, 2013 Share Posted October 5, 2013 27100 Link to comment Share on other sites More sharing options...
+Darrin9999 Posted October 5, 2013 Share Posted October 5, 2013 4950 Link to comment Share on other sites More sharing options...
