dudeslife Posted November 8, 2013 Share Posted November 8, 2013 Not an emulator. With real ports that you can plug an actual 1541 and joystick into.. is this not possible? Quote Link to comment https://forums.atariage.com/topic/218446-why-cant-someone-shrink-a-c64-down-to-raspberry-pi-size/ Share on other sites More sharing options...
Hatta Posted November 8, 2013 Share Posted November 8, 2013 That's about what the C64DTV was. Not much reason to make it smaller than a joystick. 1 Quote Link to comment https://forums.atariage.com/topic/218446-why-cant-someone-shrink-a-c64-down-to-raspberry-pi-size/#findComment-2862909 Share on other sites More sharing options...
mphokie Posted November 9, 2013 Share Posted November 9, 2013 Have you seen this: http://www.vesalia.de/e_keyrahv2.htm for the keyboard/joystick ports? Here's a promising OS for the Raspberry Pi: http://www.commodorepi.co.nr/ I know it's not exactly what you're asking about, but it's close (I wonder if the ZoomFloppy would work w/a Raspberry Pi) Quote Link to comment https://forums.atariage.com/topic/218446-why-cant-someone-shrink-a-c64-down-to-raspberry-pi-size/#findComment-2862937 Share on other sites More sharing options...
TMR Posted November 9, 2013 Share Posted November 9, 2013 The Turbo Chameleon in stand-alone mode and with a joystick dock isn't much bigger than a RasPi and can use a PS/2 keyboard and 1541 (it also emulates a couple of disk drives) with the breakout cable connected. Quote Link to comment https://forums.atariage.com/topic/218446-why-cant-someone-shrink-a-c64-down-to-raspberry-pi-size/#findComment-2862958 Share on other sites More sharing options...
