Intellivision Pierce Posted December 24, 2013 Share Posted December 24, 2013 I wanted to program using SDK 1600, but I couldn't find out how to install it. Quote Link to comment Share on other sites More sharing options...
LidLikesIntellivision Posted December 24, 2013 Share Posted December 24, 2013 I'm just a beginning too. But as far as I understand, it's a Kit with small programs to do very specific jobs. Just like the Unix philosophy, a set of small tools, which one specialized for doing the very best way its job! So you're going to find the as1600 to compile, as well as many other tools! These tools are intended to be used in a command line interface. Yes, I also need some help and manuals for all options available for each tool! For insance, to compile an asm source code, you need to type in your prompt: as1600 -o NameOfYourNewBinFile NameOfYourSourceCode No installation required! (except for eventually given exec permission in a Unix like Os?) Well, just my small contribution. And maybe something wrong here. I'm only starting. Quote Link to comment Share on other sites More sharing options...
intvnut Posted December 24, 2013 Share Posted December 24, 2013 (edited) SDK-1600 is now part of jzIntv. Download and unzip the following archives: The correct jzIntv executables for your platform: Windows (XP or later, hopefully): http://spatula-city.org/~im14u2c/intv/dl/jzintv-1.0-beta4-win32.zip Mac OS X (10.6 or later): http://spatula-city.org/~im14u2c/intv/dl/jzintv-1.0-beta4-osx.zip 64-bit Linux: http://spatula-city.org/~im14u2c/intv/dl/jzintv-1.0-beta4-x86_64-linux.zip The SDK-1600 library and example files: http://spatula-city.org/~im14u2c/intv/dl/jzintv-1.0-beta4-sdk1600.zip And, only if you want to look at it, the jzIntv source: http://spatula-city.org/~im14u2c/intv/dl/jzintv-1.0-beta4-src.zip (Note: If you do not see your OS above, then you will need to build from source. Hopefully, though, one of the three options above will do the trick.) These ZIP files are designed to unpack on top of each other. If you're using a command line zip utility, just do this from the same directory. unzip jzintv-1.0-beta4-XXX.zip unzip jzintv-1.0-beta4-sdk1600.zip After that, you just need to arrange for jzIntv and SDK-1600 to be in your execution path. How you do that depends on your OS. The short version is that you want to add jzintv-1.0-beta4/bin/ to your path, and then all of the SDK-1600 commands (jzintv, as1600, etc.) will now be available to you at the command line. It is a very command-line oriented environment in the UNIX philosophy. I do all my development under Linux without a GUI (other than terminal windows under X), and so am not well versed in the best ways to set it up on Windows or Mac. Hopefully, some other AAers will chime in with how they use the tools on Windows and/or Mac. I know I have users in both of those camps. :-) Edited December 24, 2013 by intvnut Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted December 25, 2013 Share Posted December 25, 2013 I wanted to program using SDK 1600, but I couldn't find out how to install it. Are you using Windows or Mac? Quote Link to comment Share on other sites More sharing options...
doctorclu Posted January 10, 2014 Share Posted January 10, 2014 Also interested and using a Mac. Where can I find examples of source code? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 10, 2014 Share Posted January 10, 2014 At least in Windows the folder structure with examples is: C:\sdk1600\examples\ I was able to edit the hello.asm into this: Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted January 10, 2014 Share Posted January 10, 2014 At least in Windows the folder structure with examples is: C:\sdk1600\examples\ I was able to edit the hello.asm into this: Cheeky. Once he sets up the SDK-1600, he can try setting up P-Machinery, which may help a bit more. Modifying the title screen is even easier! 1 Quote Link to comment Share on other sites More sharing options...
