Save Action! config?
Some of the options are stored in $04xx. The margin is simply the standard OS zero page location (82 = $52).
That's also why it is reset to 2 when pressing "RESET".
Edited by JAC!
Ok, here's my test. I created a Action! file on D1: called simply S:
proc main()
 BYTE bell=$4E0
 BYTE screen=$4F1
 BYTE lmargin=$52
 lmargin=0
 bell=$60   ;off-$60,on-$4C
 screen=$00 ;off-$00,on-$22
return
I load Action!, hit <CONTROL><SHIFT>M, then type R"D1:S"
It works, configures Action! how I like it.
Two more questions:
1. Any idea how to set it to INSERT mode? I couldn't find anything that changed in the $400 block.
2. Does anyone know how to set the default directory in MyDOS from Action!? The docs say to use CIO function code 41. I have no idea how to do that... :-)
proc main()
 BYTE bell=$4E0
 BYTE screen=$4F1
 BYTE lmargin=$52
 lmargin=0
return
Two more questions:
Well done! I always wondered how to do that.
This works for setting current directory.
Proc Main()
xio(1,0,41,0,0,"D1:<folder>")  ; where <folder> is the name of your subdirectory
return
The first number ('1' above) has to be a currently unused channel, I believe.
For SpartaDOS the command number is 42 instead of 41
Edited by a8isa1
xio command works great!
Current code (turned off key click too)
proc main()
 BYTE bell=$4E0
 BYTE screen=$4F1
 BYTE lmargin=$52
 BYTE noclik=$2DB
 lmargin=0
 noclik=1
 XIO(1,0,41,0,0,"D1:ACTION")
return
I also put it in the default directory (D1: for my MyIDE+Flash, D8: when in the Ramdisk) so now I start Action!, go to the monitor and type R"S".
The last piece of the puzzle for me is to set it to insert mode... If I can find where that is stored.
PERFECT!
proc main()
 BYTE bell=$4E0
 BYTE screen=$4F1
 BYTE lmargin=$52
 BYTE noclik=$2DB
 BYTE insert=$9D
 lmargin=0
 noclik=1
 insert=$FF ;off-$00,on-$FF
 XIO(2,0,41,0,0,"D1:SRC")
return
How do you find these locations? I don't even know where to start!
And my next goal (after I finish my game) is to figure out some way to make the bottom line in the editor useful. (It would be nice to have a indicator on whether I'm in Insert or Replace mode, for example.)
Yes, that's exactly what I do in these cases. "WRITE 0000 ffff C:\temp\first.bin" in Atari800Win before and after the change. Then I use VBinDiff.
You have to igore some ZP locations , the stack and the screen, the rest is what is interesting.
http://www.cjmweb.net/vbindiff/
