Pset Posted January 17, 2014 Author Share Posted January 17, 2014 There was more to that post like the details of the functions you mentioned, but this forum cut off everything after the quote. I thought I'd be safe not using the code block, but nope. Quote Link to comment Share on other sites More sharing options...
JamesD Posted January 18, 2014 Share Posted January 18, 2014 Anyone have an Aquarius memory map? Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted January 18, 2014 Share Posted January 18, 2014 Anyone have an Aquarius memory map? See here. Quote Link to comment Share on other sites More sharing options...
JamesD Posted January 18, 2014 Share Posted January 18, 2014 (edited) This is untested but it sets the start address for a ROM cart and includes the required 16 byte cart header. If you have to use more than 8K of space you have define another block starting $C000 and tell the linker what code to put above and below the start address. Banked ROM carts require even more work. This doesn't include setting the heap address for the linker or the stack pointer on startup. The heap should be set to $3800 and stack should be the top of RAM which would depend on the memory size the machine has or how much you need. The top of built in ram would be $3FFF, 4K expansion would be $4FFF, 16K would be $7FFF and 32K would be $BFFF. ; CRT0 for the Mattel Aquarius ; ; Stefano Bodrato Dec. 2000 ; ; If an error occurs eg break we just drop back to BASIC ; ; $Id: aquarius_crt0.asm,v 1.8 2009/06/22 21:20:05 dom Exp $ ; MODULE aquarius_crt0 ;-------- ; Include zcc_opt.def to find out some info ;-------- INCLUDE "zcc_opt.def" ;-------- ; Some scope definitions ;-------- XREF _main ;main() is always external to crt0 code XDEF cleanup ;jp'd to by exit() XDEF l_dcal ;jp(hl) XDEF _std_seed ;Integer rand() seed XDEF _vfprintf ;jp to the printf() core XDEF exitsp ;atexit() variables XDEF exitcount XDEF __sgoioblk ;stdio info block XDEF heaplast ;Near malloc heap variables XDEF heapblocks XDEF base_graphics ;Graphical variables XDEF coords ;Current xy position XDEF snd_tick ;Sound variable ;;org 14768 ; Mattel relocating loader ;org 14712 ; Simpler loader ;***************************************************************************** ; Begin Main 8K Bank ($E000-$FFFF) org $E000 ; Aquarius Cartridge Header (SuperCart I, 8K Mode) defb $53,$43,$30,$38,$4B,$9C,$B5,$B0,$A8,$6C,$AC,$64,$CC,$A8,$06,$70 ;****************************************************************************** start: ld (start1+1),sp ;Save entry stack ld hl,-64 add hl,sp ld sp,hl ld (exitsp),sp IF !DEFINED_nostreams IF DEFINED_ANSIstdio ; Set up the std* stuff so we can be called again ld hl,__sgoioblk+2 ld (hl),19 ;stdin ld hl,__sgoioblk+6 ld (hl),21 ;stdout ld hl,__sgoioblk+10 ld (hl),21 ;stderr ENDIF ENDIF call _main ;Call user program cleanup: ; ; Deallocate memory which has been allocated here! ; IF !DEFINED_nostreams IF DEFINED_ANSIstdio LIB closeall call closeall ENDIF ENDIF start1: ld sp,0 ;Restore stack to entry value ret l_dcal: jp (hl) ;Used for function pointer calls ;----------- ; Define the stdin/out/err area. For the z88 we have two models - the ; classic (kludgey) one and "ANSI" model ;----------- __sgoioblk: IF DEFINED_ANSIstdio INCLUDE "stdio_fp.asm" ELSE defw -11,-12,-10 ENDIF ;--------------------------------- ; Select which printf core we want ;--------------------------------- _vfprintf: IF DEFINED_floatstdio LIB vfprintf_fp jp vfprintf_fp ELSE IF DEFINED_complexstdio LIB vfprintf_comp jp vfprintf_comp ELSE IF DEFINED_ministdio LIB vfprintf_mini jp vfprintf_mini ENDIF ENDIF ENDIF ;----------- ; Now some variables ;----------- coords: defw 0 ; Current graphics xy coordinates base_graphics: defw $3028 ; Address of the Graphics map ; (text area-second line) _std_seed: defw 0 ; Seed for integer rand() routines exitsp: defw 0 ; Address of where the atexit() stack is exitcount: defb 0 ; How many routines on the atexit() stack heaplast: defw 0 ; Address of last block on heap heapblocks: defw 0 ; Number of blocks IF DEFINED_NEED1bitsound snd_tick: defb 0 ; Sound variable ENDIF defm "Small C+ Aquarius" ;Unnecessary file signature defb 0 ;----------------------- ; Floating point support ;----------------------- IF NEED_floatpack INCLUDE "float.asm" fp_seed: defb $80,$80,0,0,0,0 ;FP seed (unused ATM) extra: defs 6 ;FP register fa: defs 6 ;FP Accumulator fasign: defb 0 ;FP register ENDIF Edited January 18, 2014 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted January 21, 2014 Share Posted January 21, 2014 I really don't have the time to fix everything at the moment but I can tell you where I think this needs to go from here.The Aquarius ROM disassembly shows the stack pointer is initially set to $38a0 in the code following START2: before jumping to the cartridge.The startup code seems to lower it by 64 bytes so it's normally set to $3860 once the C code is called in a cart.The ROM starts out treating the start of user RAM as $3964. You could set the heap to that address if the stack is large enough at it's default location.I don't think the cart needs that much space between the two but you can set it to whatever you like. Perhaps $3861?The ROM routine that checks for RAM is at RAMTEST: in the disassembly and part of that code could be extracted and placed in the crt0 Aquarius module to use for a cartridge if needed. That's also where I found the start of user RAM... or at least where it starts testing for user RAM anyway. The cartridge should never exit so saving the stack pointer and returning to basic in crt0 needs to be changed for a cart. The code should probably just set the stack pointer on entry and jump back to the first executable address of the cart on exit. I think some other stuff could be dumped but this should all be done with IF DEFINDED code blocks so one crt0 file could be used for carts or regular executables. Quote Link to comment Share on other sites More sharing options...
