BASIC Ten-Liners - Contest 2014
Bunsen
I was thinking to do something, but after seeing this game, it is pure masked ASM :)
But seriously you know it is not? It is just moving with BASIC command MOVE graphics data saved as character strings. No machine code at all.
By the way - when making these 10 liners I have realised how much processor time custom chips save - no probs with smooth vertical scrolling at all, horizontal is a bit more difficult but doable as well (:flappy). Totally inconceivable with simple framebuffer machines like Apple ][ or ST.
Best,
pirx
Best,
pirx
hahaha, sorry my mistake, I didnt look the code :P
Absolutely astonishing what's possible in 10 lines of Turbo Basic.
We have decided to split the contest into 2 categories.a) "E:-Games"; =games that can be typed in with Atari E: device screen editor. b)"unlimited"; =games with longer lines
This is not a change of rules, but only a means to better structure the abundance of games.
The voting will be different to all other contests like Abbuc, kazkompo and silly venture.
Hi,
Ah, good, as my two entries are already type-able on E: :-)
35th game registered :)
Jumpsheep by fdingler
Paddleship by Bill Kendrick
Sijmen by Gunnar Kanold
Squirrel by fdingler
Shmup by Bill Kendrick
Colfusion by Irgendwer
Planets by Bill Kendrick
Slice by Bill Kendrick
GozMind by gozar Retracted
Carrera by Daniel Serpell
Minijong by Bill Kendrick
Jump! by Xuel
Count1ng Zoo by 1NG
Hanged Man by Jakub Husak
Gwobby Micro by Jason Kendall
Minidash by Bill Kendrick
Puzzler 2014 by Sleepy
Drunk Pistol by mgr inz. Rafal
Crack My Luggage by gozar
Roguelike by Jakub Debski
Nimx by Cliff Hatch
Catch by Chris Read
Grue Killer by Reaperman
Joyas by Daniel Serpell
Dodge Racer by Reaperman
Abyss by Jakub Debski
Fuky Bird by 1NG
Puzzler Duell by Sleepy
Flappy by pirx
BluesJam by Savetz
Abduct10 by Savetz
Maze by Bill Kendrick
Bagh Chal by Bill Kendrick
Isol by Bill Kendrick
2047 by pirx
Cavern 10 by Xuel
Now! Finally! My little attempt in creating a game in only 10 lines of »Turbo Basic XL« code. I call this one
ATLAS TXL
ATLAS.zip
I have to admit ... well ... how should I say ... well ... please don't call me as arrogant when I say the following. But in my RL daily life I am used to object oriented programming (OOP) using the programming language PHP and JavaScript. Which means you can relay on well formed and therefore nearly self documented code.
So, this was exactly the opposite: It was WILDE WILDE ANARCHY HACKING. Nothing less. Don't do this at home kids! But I am so glad my little game could fit in those 10 lines of TBXL. :)
You all know this type of game from the glorious company »Imagic« in the mid-80s. They made a game called »Atlantis« for the Atari 2600 and later for other systems as well as for our lovely 8-bit-machine. My game has the same purpose: Defend a city from deadly enemies from above.
You have three canons: One in the middle, one to the left and one to the right. You choose which canon to fire by pressing the joystick to the left, right or leave it in the middle. Hitting a ship gives you 50 points from the middle cannon and 200 points from the side cannons. Every three hits by the side canons you get an extra life. When your score reaches 1000 the enemy ships sometimes get faster than before. Don't let the enemy ships come all the way down to the bottom or you lose a life. When are lives are gone the game is over.
I programmed the game ... err, sorry ... I mean I HACKED the game using »Altirra 2.40« so I am not sure if it runs on real hardware. But I am pretty sure it does. For the ones interested I had two heavy bugs in the program which were extremely hard to track due to the packed content of the program lines. Here's some insight of my TBXL nightmares:
a) Variable Name And Keyword Concatenation
Due to space limitations I first deleted every space characters in the lines. Man, that was a damn bad idea. Look at this statement (originally found in line 4):
IF Q THEN K=0
removing the spaces gives you
IFQTHENK=0
But TBXL interprets this as
IF QTHENK=0
So I now had a variable with the name QTHENK which if course did bad things in the code.
b) IF-THEN-Problems
It appears that TBXL seem to have problems with the following construct:
IF A:IF B=0 THEN C=1:ENDIF
Not sure if this example demonstrates the strange behavior but I had similar code fragments in my game. I wasn't able to track down an error for hours. A voice in my head told me to replace this line with the following:
IF A:IF B=0:C=1:ENDIF:ENDIF
And suddenly everything works as expected. Well ... good old TBXL I guess! :)
I hope you enjoy the game a little. The game was made during the time period of nearly a month hacking here and there. For squeezing the long lines into BASIC I used an external editor named »Notepad++« with the »Hex Editor« PlugIn. This editor is so hot I instantly switched to this for my daily real life work! :)
Oh, and I nearly forgot: I am now so deep into this game and it gave me some ideas ... I am most probably doing a real game written in machine language from it.
Kind regards,
Henrik (Island2Live)
Edited by Island2Live
  • Like 6
Hello pirx,
thank you very much for your comment on my code. I fear there is slight misunderstanding. The code you showed definitely IS totally logic. And that's what I already and finally used in my game as explained in my original posting. The problematic code fragment was this one:
THIS did not work even though it is also logical, did not produce any errors AND works fine when executed on a single program line. It did NOT work in my game though ... probably because Turbo Basic XL got confused by too many IF:ENDIF constructs spanned over too many lines. ;)
Kind regards,
36th game registered :)
Jump! by Xuel
Count1ng Zoo by 1NG
Nimx by Cliff Hatch
Catch by Chris Read
Fuky Bird by 1NG
Flappy by pirx
BluesJam by Savetz
Abduct10 by Savetz
2047 by pirx
Cavern 10 by Xuel
Atlas TXL by island2live
Hi Henrik,
That is because "THEN" means do everything to the end of the line. So the first IF is missing the ENDIF - it is inside the "THEN" block. You just can not mix these two idioms in one line. Basically what I have learnt from this competition is to leave "THEN" alone for good :)
Best,
Pawel /pirx/ Kalinowski
Edited by pirx
OK, my mistake. Wednesday, the 23rd. Would love to see one or two (or three :-)) entries from you.
On Thursday I will drive to Lübeck to NOMAM, there I will have limited access to internet and can't manage things correct (no possibility to bring ATR's from iphone to Atari...)
when i tried to use enter:"filename" for longer lines (up to 256) bytes. Nothing happens.
for sure there is an issue but the emulator doesn't complaint
I encountered the same issue. Program lines for the Atari Basic, »Turbo Basic XL« and probably all text files need to end with the Atari-typical end-of-line character 0x9b instead of the usual CR/LF for Windows. That was an issue I solved by using a Hex-Editor inside my beloved - and beginning from this contest - new editor »Notepad++«.
Hope this helps a little. :)
Kind regards,
If the entrants of the competition were to be released on a datasette, the total code released thus far, combined, would be pretty close to filling up a whole hour , wouldn't it? Or is there still room for.. for a 90 minute cassette ... keep coding...more, more, more.. :D
That Game, Flappy.xex
It seems not working properly.
When I loading up and it will not stop flying. On Commodore 8 bits side, it suppose to wait for the user to press the space bar and start the game. On the Atari version, it automatic start the game WITHOUT wait until pressing the space bar first and play the stage .
to Voy.
Edited by Caterpiggle
Kind regards,
thanks a lot !
I was replacing LF with npp++ however something went wrong, now using the convert tool from a800win+ works correctly.
Hello guys
So to clarify: entries need to arrive by the end of the day Wednesday the 23rd, central european time. Correct?
Yes, correct.
Not sure if it makes any different, but we're at central european daylight savings time. Which gives you one hour less to complete your 10 liner.
Sincerely
Mathy
