bogax Posted April 27, 2014 Share Posted April 27, 2014 The code produced by the ranged_rand pagejust multiplies what you get from bB randby a fraction.For the most part the bB version and the asmversion are the same except that the asmcan use the carry to do the math with a ninebit result rounded to eight bits. The bBversion truncates to 7 bits in order toget the result to fit into 8 bits.So the asm is more accurate.For ranges greater than 128 the bB codecalculates for range+1 and the truncationresults in it rounding down to the correctrange.I think rand16 is very good for somethingso compact and fast.For something different (hopefully better)I'd try combining rand16 with a differentrandom number generator.Here's an example with a simple LCG myseed = myseed * 16 + myseed + 103 myrand = rand ^ myseed Quote Link to comment Share on other sites More sharing options...
Albert Posted November 2, 2014 Share Posted November 2, 2014 Flappy is now available in cartridge form in the AtariAge Store! http://atariage.com/store/index.php?l=product_detail&p=1038 Piñata and Omicron are also available, as well as "loose" (manual and cartridge) versions of several games released last year. ..Al 2 Quote Link to comment Share on other sites More sharing options...
uNi73 Posted November 3, 2014 Share Posted November 3, 2014 All my secrets? There's a pearl script here that takes a .wav file and converts it to data. First you need an audio program to take your sound and convert it down from 44.1KHz or whatever, down to 7Khz or 4KHz or 3.5KHz or some small rate but that still sounds still okay. Then save it as an 8-bit .wav file. Then in the terminal, I have OSX, run the script ./wave2atari.pl -wav mywav.wav -outfile mydata It will make a text file with the sound data. I hacked it into an assembly file that I edited to use with batari Basic's "include" command. This is the smallest sound I've done so far. I'd say it uses 768 bytes. Dude, Sire, Mate! I understand clearly what you have done here, but when I think about the (ATARI) Hardware, I am confused. That this will work in the end with my Emulator and my PC in the background: Okay! But, will this really work via an ATARI TIA Chip? Or do you use a special Cartridge for the final product that has an extra Sound-Chip included? Thanks in advance for Information Quote Link to comment Share on other sites More sharing options...
Cybearg Posted November 3, 2014 Share Posted November 3, 2014 I think this would require an AtariVox. Correct me if I'm wrong. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 3, 2014 Share Posted November 3, 2014 I think this would require an AtariVox. Correct me if I'm wrong. iesposta has his own proprietary technique to add digitized samples to his batari BASIC games - no extra hardware required. Impressive! UPDATE: See below for wave2atari.pl and more info on how to do this yourself! Thanks iesposta! Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 4, 2014 Author Share Posted November 4, 2014 iesposta has his own proprietary technique to add digitized samples to his batari BASIC games - no extra hardware required. Impressive!Yes. It is a sound sample that the TIA plays. I did say how I make it. It's even quoted above. I did have to edit the asm a bit to use with Basic, but it only involves putting periods in front of labels. I didn't write the script or the assembly. It's all still here on AtariAge. It uses 4 bits to set the volume register (0-15), two values per byte. I would like to hear how 2 bit sound comes out. But with 2 bits you can only set volume 0, 1, 2 or 3... Quote Link to comment Share on other sites More sharing options...
Cybearg Posted November 4, 2014 Share Posted November 4, 2014 I would like to hear how 2 bit sound comes out. But with 2 bits you can only set volume 0, 1, 2 or 3... Couldn't you tweak the interpreter code to multiply the volume value by 8 or something, giving you a range of 0, 8, 16, or 24? Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 4, 2014 Author Share Posted November 4, 2014 FLAPPY is in the AtariAge Store! Get one to support this fun website: Here (link) Also check out the unofficial box: Marc's Blog Version 11 RC2 is the final version. No more changes were made. 1 Quote Link to comment Share on other sites More sharing options...
uNi73 Posted November 4, 2014 Share Posted November 4, 2014 beautiful blue, i want to smell the cartridge! Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 4, 2014 Share Posted November 4, 2014 Yes. It is a sound sample that the TIA plays. I did say how I make it. It's even quoted above. I did have to edit the asm a bit to use with Basic, but it only involves putting periods in front of labels. I didn't write the script or the assembly. It's all still here on AtariAge. It uses 4 bits to set the volume register (0-15), two values per byte. I would like to hear how 2 bit sound comes out. But with 2 bits you can only set volume 0, 1, 2 or 3... Sometimes I'm not a very good reader. I missed where wave2atari.pl was posted for use. Doing a search on "wave2atari.pl" or "wave2atari" leads back to this topic. Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 4, 2014 Author Share Posted November 4, 2014 My mistake! Sorry. http://atariage.com/forums/blog/138/entry-5907-wav2ataripl/ 1 Quote Link to comment Share on other sites More sharing options...
sandmountainslim Posted November 22, 2014 Share Posted November 22, 2014 I never played the phone game but heard a lot about it. IS this the bird from Joust! in this version? It sure reminds me of him. I am digging this game. Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 22, 2014 Author Share Posted November 22, 2014 I never played the phone game but heard a lot about it. IS this the bird from Joust! in this version? It sure reminds me of him. I am digging this game. Thanks for digging my game and taking the time to say so. I had Joust on my mind when programming this. I wanted a long neck funny animation (and I never played the iPhone game either, just watched a YouTube video). There is only so much design you can do with single color double scan line sprites. Quote Link to comment Share on other sites More sharing options...
sandmountainslim Posted November 22, 2014 Share Posted November 22, 2014 Thanks for digging my game and taking the time to say so. I had Joust on my mind when programming this. I wanted a long neck funny animation (and I never played the iPhone game either, just watched a YouTube video). There is only so much design you can do with single color double scan line sprites. You did good Very addictive. I have the 2600emu on my phone and I handed it to my little girl who said "Its like Flappy Bird" and naturally I lost my phone for thirty minutes. 1 Quote Link to comment Share on other sites More sharing options...
Grimakis Posted November 22, 2014 Share Posted November 22, 2014 I actually bought this game and it arrived a few days ago. It's pretty good, it looks nice, and it's rather fun. The only thing is it doesn't play anything similar to the iPhone game. Because you get so little vertical height with each button press, there is little risk of hitting the underside of a pipe, which is what makes Flappy Bird such a difficult game. Regards, George 1 Quote Link to comment Share on other sites More sharing options...
sandmountainslim Posted November 22, 2014 Share Posted November 22, 2014 I actually bought this game and it arrived a few days ago. It's pretty good, it looks nice, and it's rather fun. The only thing is it doesn't play anything similar to the iPhone game. Because you get so little vertical height with each button press, there is little risk of hitting the underside of a pipe, which is what makes Flappy Bird such a difficult game. Regards, George I tried Flappy Bird on my daughter's tablet after playing this game and you are right the control is different. This is more like the Ostrich from Joust! is in the Flappy Bird world I like that because I am a longtime Joust fan. I prefer this to the original phone game. 1 Quote Link to comment Share on other sites More sharing options...
Lucky Man Posted December 12, 2015 Share Posted December 12, 2015 I just purchased this cartridge and found a bug that I also noticed when playring the rom on the Harmony cart. If you get 3 low pipes in a row that don't require you to hit the joystick button to make Flappy go higher, the bird starts rolling fast on the screen. It doesn't seem to affect the pipes or background. I tried to take a picture of the problem, but they came out with black bars on the screen. To my eye I don't see the bars, just Flappy rolling. But if you press the joystick button, he stops rolling and the game continues. Otherwise he dies when the next pipe comes along. I'm surpised nobody else noticed this. I guess I must be the only one lazy enough to let Flappy rest on the clouds when I don't need to flap. Note: The reflection on the left of the screen is the window behind me. Quote Link to comment Share on other sites More sharing options...
+McCallister Posted December 12, 2015 Share Posted December 12, 2015 I just purchased this cartridge and found a bug that I also noticed when playring the rom on the Harmony cart. If you get 3 low pipes in a row that don't require you to hit the joystick button to make Flappy go higher, the bird starts rolling fast on the screen. It doesn't seem to affect the pipes or background. I tried to take a picture of the problem, but they came out with black bars on the screen. To my eye I don't see the bars, just Flappy rolling. But if you press the joystick button, he stops rolling and the game continues. Otherwise he dies when the next pipe comes along. I'm surpised nobody else noticed this. I guess I must be the only one lazy enough to let Flappy rest on the clouds when I don't need to flap. I've noticed this bug as well, so rest assured, you are not the only one that lazy Actually, I always thought of it as coasting to give your finger a rest. Quote Link to comment Share on other sites More sharing options...
iesposta Posted December 12, 2015 Author Share Posted December 12, 2015 Programmer here. Wow, just tried this and it even happens in emulation. This game was the only time I did not use the DPC+ Kernel for batari Basic, to keep costs down. I did not program this behavior, so it is a bug in the Multi-Sprite Kernel, and I wouldn't have the first clue as how to correct it aside from adding a programmed button press after each point.. I hope you'll enjoy my/our other upcoming batari Basic games like DK Arcade 2600, and hacks like Dr. Who Berzerk and Wizard of Wor Arcade! 1 Quote Link to comment Share on other sites More sharing options...
+McCallister Posted December 12, 2015 Share Posted December 12, 2015 I hope you'll enjoy my/our other upcoming batari Basic games like DK Arcade 2600, and hacks like Dr. Who Berzerk and Wizard of Wor Arcade! Yes, looking forward to these games, too! Especially Wizard of Wor Arcade! Quote Link to comment Share on other sites More sharing options...
Lucky Man Posted December 13, 2015 Share Posted December 13, 2015 Yes, DK Arcade looks great! But I was hoping you could figure out how to fix the problem with Flappy. I guess I should have said something when I discovered the bug using the Harmony cart, but I just figured I was using a beta rom. Oh well... Quote Link to comment Share on other sites More sharing options...
doctorclu Posted November 17, 2016 Share Posted November 17, 2016 Recently got a Flashback Portable and decided to try Flappy out. Attached are the results. I would like to try previous versions of Flappy to see if the results would be different/better. 20161117_060607.mp4 Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 17, 2016 Author Share Posted November 17, 2016 Recently got a Flashback Portable and decided to try Flappy out. Attached are the results. I would like to try previous versions of Flappy to see if the results would be different/better. Darn. All kinds of fail here! The cart-added Flashback 2 this is "playable" with some garbage pixels near the bottom that do not affect game play. •The missile dot is too far to the right. It should float around the center of the bird. •The pipe is just Player 0 super tall that moves up/down. Maybe the data extending above and below the visible screen is wrecking the timing because of the skewed display? •The death speech sample also fails. Maybe because there it doesn't generate a 262 stable screen? My ToysRUs preorder was cancelled along with everyone else... Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 17, 2016 Author Share Posted November 17, 2016 Two older Flappy versions. Recently got a Flashback Portable and decided to try Flappy out. Attached are the results. I would like to try previous versions of Flappy to see if the results would be different/better. FlappyOld.zip 1 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted November 17, 2016 Share Posted November 17, 2016 Quick test (at work) shows that R0 was the one that works the best. The pipes are not completely aligned, but more to the middile of the screen. Also after R0 the gap is always towards the bottom of the screen. Which makes for easier game play but... Quote Link to comment Share on other sites More sharing options...
