RevEng Posted April 6, 2014 Author Share Posted April 6, 2014 No problem on the help. To make the background transparent, the best solution is to make it transparent in The Gimp. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 7, 2014 Share Posted April 7, 2014 Makin' progress! Here's my character in a walk cycle. Is there a better way to do an animation cycle than this? I looked at the code in Adventurer.bas, but it didn't make a lot of sense to me. walking.bas Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 7, 2014 Author Share Posted April 7, 2014 (edited) Looks good! A few tips.... It seems you're setting the palette registers for each imported graphic. When you have sprites with the same colors, you only need to set the palette colors once, for one of the images. ie. ditch the byronr02_color*and byronr03_color* lines. Later, when you want something else on-screen with the bear but using different colors, use a different palette index to display it. (e.g. P1C1=monsterr1_color1) So far as animation, there's nothing wrong with what you've done, but it eats up a bit more ROM. So long as your sprites are next to each other in memory, plotsprite can take an optional "frame" parameter (after the y coordinate parameter) and it will skip sprites depending on the value of that parameter. In your code you're using "a" as an animation index. Currently it ranges from 1 to 3, but if you change that from 0 to 2, you can replace your three "if a=..." lines with a single line: "plotsprite byronr01 0 x y a" When a=0, it will display byronr01, and when a=1 it will display byronr02, etc. The only limitation is that the sprites you skip need to all be the same width. (which they are here) Edited April 7, 2014 by RevEng Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 7, 2014 Share Posted April 7, 2014 Sweet, that's exactly what I needed! Now, can I swap palettes on the fly for the lead character? You know, if his status changes for any reason, I might need to change his color a bit. Also, can I use different sprite widths for other characters? Byron will consistently be 16x16 pixels but his gunfire should be around 8x8. Maybe some of the enemies need to be that size too, I dunno. (I do worry that the Byron sprite is too chunky for the kind of game I want to make, but I'm pretty insistent on him staying that size for detail's sake.) Oh yeah, a couple of other things. Can the sprite be flipped horizontally or will it need to be redrawn depending on the character's direction? Also, is text currently available and if so, can I change its palette on the fly to do that nifty color pulsing that Williams used to do for games like Robotron: 2084? I've got a lot of questions, actually. My apologies in advance if I start to get on your nerves! Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 7, 2014 Author Share Posted April 7, 2014 No worries about the questions, so long as you don't get frustrated if I point you to the Guide when a detailed answer is required. Now, can I swap palettes on the fly for the lead character? You know, if his status changes for any reason, I might need to change his color a bit. Sure. Just change whichever palette register you want whenever you want. You can use hex values, variables, or the _color# constants. If you use Palette 0 to draw your character on the screen with plotsprite, then change P0C# values. If you use Palette 1, then change P1C# values, etc. Also, can I use different sprite widths for other characters? Byron will consistently be 16x16 pixels but his gunfire should be around 8x8. Maybe some of the enemies need to be that size too, I dunno. (I do worry that the Byron sprite is too chunky for the kind of game I want to make, but I'm pretty insistent on him staying that size for detail's sake.) Yep, mix and match away with the widths. The only requirement is that different animation frames of the same sprite need to be the same width and next to each other in memory, and that's only a requirement if you use that "frame" parameter with the sprite in question. Can the sprite be flipped horizontally or will it need to be redrawn depending on the character's direction? Also, is text currently available and if so, can I change its palette on the fly to do that nifty color pulsing that Williams used to do for games like Robotron: 2084? The 7800 has no hardware sprite flipping, so you need to store left and right facing versions of the sprites. Text is currently available. See plotchars and plotvalue in the Guide. Palettes can be changed on the fly to do the color pulsing. I'm working on a game that does the same right now. The one note there is the color palettes are write-only, so you can't do something like "P2C2=P2C2+1". Instead go with "z=z+1" and "P2C2=z". Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 7, 2014 Share Posted April 7, 2014 All helpful information. I'll have to dink around with the compiler for a while and see what I can do with it. Looking at the "Hello World" program makes me wonder how many character blocks I'll have to play with. I could very easily sacrifice the lower case letters for background graphics if I still have the capital letters for text. Also, what's the size of the character blocks, the usual 8x8? Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 7, 2014 Author Share Posted April 7, 2014 The size of the character blocks actually depend on which 7800 graphic mode you're using. There's a table with that info for each mode in the Guide, under the "7800 Hardware Overview->Graphics->Graphics Modes" section. The default mode (which you've used so far) is 160A. Each character in this mode is 4 pixels wide and has 3 colors. You can turn on double-wide characters with "set doublewide on" if you prefer 8 pixel wide characters, but you need to bear in mind that you'll have a maximum of 128 characters with that turned on, rather than 256. These all reflect the underlying hardware architecture, rather than choices I made with the 7800basic design. Its also worth mentioning that can switch the character sets between frames for a different level or screen type, with the characterset command. Quote Link to comment Share on other sites More sharing options...
MAC-42 Posted April 9, 2014 Share Posted April 9, 2014 Here's a question. I'd like to use a PNG to create a number of identical sprites. (Think, for instance, a line of bug ships in Galaxian or a group of robots like in Berzerk or Robotron.) I know I can create as many copies of the PNG and call them individually in the code, but it seems that using a single file would be more efficient, at least on account of the fact that I'm lazy and don't feel like copying the image and renaming all the copies. Is it possible to do this or something like it at this point? Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 9, 2014 Author Share Posted April 9, 2014 (edited) You can call plotsprite as many times as you like with the same image. No need to make png copies. You can even use a different palette with the copies, to create different colored versions of the same sprite.I did this in the multisprite sample. Edited April 9, 2014 by RevEng 1 Quote Link to comment Share on other sites More sharing options...
MAC-42 Posted April 9, 2014 Share Posted April 9, 2014 Well, yes, RevEng. I guess you did. Please note the time of my previous post as I'm entering it in the record along with my plea of vapidity. Thanks for reminding me. Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 9, 2014 Author Share Posted April 9, 2014 (edited) No worries. Just to be clear, I pointed to the multisprite sample so you could have an example to look at, not as a reminder or rebuke. I'm glad to answer any questions! Edited April 9, 2014 by RevEng Quote Link to comment Share on other sites More sharing options...
MAC-42 Posted April 9, 2014 Share Posted April 9, 2014 not as a reminder or rebuke. Actually, I did need the reminder as this example is precisely what I needed. For some reason, though, I forgot all about its existence. So I'll take it as a very kind reminder and I really do appreciate it. 1 Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 9, 2014 Share Posted April 9, 2014 I'm just wondering how I'm going to put a lot of characters on the screen at once. In most dialects of BASIC you can DIM variables to turn them into an array, then put the AI routines in a FOR/NEXT statement for maximum efficiency. Something like: DIM enemyx(10) DIM enemyy(10) FOR I = 1 to 10 enemyy(I) enemyy(I) + 2 ' Move enemies down two spaces NEXT I That doesn't seem to be an option here, since DIM is simply used to rename variables, not array them. What's my best option for dealing with enemy AI if I've got several of them to manage? Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 9, 2014 Author Share Posted April 9, 2014 (edited) In 7800basic you can treat any memory location, RAM or ROM data, like an array. Here's your example in 7800basic'ese. dim enemy1x=a : rem to j dim enemy1y=k : rem to t for i = 0 to 9 enemy1y[i] = enemy1y[i] + 2 : rem Move enemies down two spaces next Edited April 9, 2014 by RevEng Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 11, 2014 Share Posted April 11, 2014 Once again, helpful. Thanks! I just processed the sprites for Byron's walk cycle in all eight directions and discovered that the lot of them came to just shy of 10K in size. Should I be worried? How much can the compiler and system handle before I run out of space? I'm worried that my ambitions might be getting out of hand. Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 11, 2014 Author Share Posted April 11, 2014 No problem. You may find your graphics are more compact when imported, but either way I wouldn't sweat it yet. The ROM size is the limiting factor for the amount of graphics you can use. If you find 32k doesn't cut it, 48k is the next size up and you still don't need to deal with bankswitching with that format. If you go with one of the bankswitching formats (128k, 256k, and 512k) you'll need to group graphics together so the active bank has the graphics for the current screen/level. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 11, 2014 Share Posted April 11, 2014 (edited) Just discovered that multiple JOY statements don't work in IF/THEN statements. if joy0up and joy0right then p = 1 The above line crashes the compiler. Any suggestions as to how I should address this? I'm thinking of storing the values of joy0up/joy0down and joy0left/joy0right into two separate variables. It'd be a kludge, but it would probably work. Edited April 11, 2014 by Jess Ragan Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted April 11, 2014 Share Posted April 11, 2014 If this BASIC is the same as the other BASIC, you can't use and. You have to use symbols: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#boolean 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 11, 2014 Author Share Posted April 11, 2014 RT's got it. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 12, 2014 Share Posted April 12, 2014 Oh, man! I am like, doing backflips here! Got my character running around the screen, facing in all directions. If you use a second joystick, you'll note that he'll continue to hold the gun in the direction that stick is held, regardless of where he's running. That's the first step toward making an omni-directional shooter. The next step, of course, is bullets. Give it a run, let me know what you think. It runs fine in ProSystem if that's your poison; I haven't tried it on MESS or the real hardware. Thanks are in order to RevEng and everyone else who offered their assistance! omnid.zip 6 Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 13, 2014 Author Share Posted April 13, 2014 Looks good in MESS. Promising start! Quote Link to comment Share on other sites More sharing options...
+Trebor Posted April 13, 2014 Share Posted April 13, 2014 Oh, man! I am like, doing backflips here! As you should...It looks great, Jess! Your character seems to be already oozing personality just by the way you handled the facial expressions and overall demeanor. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted April 14, 2014 Share Posted April 14, 2014 Thanks, I really appreciate that! I'll probably work on some of the sprites and background art next. I've got an outline for the basic structure of the game, but although it sounds fun in theory, I'm not sure how enjoyable it will be in practice. I'll have to start a thread in the homebrew section of the forum later, just to bounce some ideas off the members of AtariAge. 1 Quote Link to comment Share on other sites More sharing options...
Cybearg Posted April 19, 2014 Share Posted April 19, 2014 Just going through the manual now. Very excited to see this! A couple of minor typos in the manual: Page 30: psound 7800basic provides the tsound command for conveniently setting the pokey audio registers. Page 2: Graphics ... MARIA was designed with an architecture similar to many arcade games of it's era. That last one is just a nitpick, but there should be no apostrophe. Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 19, 2014 Author Share Posted April 19, 2014 Thanks! I'll fix those up for the next release. Quote Link to comment Share on other sites More sharing options...
