Setting up a 512k cart
Gazoo
Is there something I have to do to get this to run in Classic99? From what I've read in this thread, I'm supposed to be using the Backwards file, but when I try it (and the other one), I still only get select 1 for TI BASIC, nothing else. I'm using the first file that was posted on page 6.
You have to set it up as a type 3 rom in the classic99.ini..
[usercart0]
; *** megamod1
name="megagamemodule1"
rom0=3|0000|80000|MODS\backwardsgamecart.bin
Edited by arcadeshopper
Yes, all 5 carts so far.
Gazoo
Looks like i got 6 poopy eproms from ebay..:P seller is going to replace them.. see if they work.. not one programmed right, this one that i thought programmed bombed out after verifying correctly, tested in the ti.. nothin..then tried again, the last few bits were wrong..
Greg
Looks like i got 6 poopy eproms from ebay.. :P seller is going to replace them.. see if they work.. not one programmed right, this one that i thought programmed bombed out after verifying correctly, tested in the ti.. nothin..then tried again, the last few bits were wrong..
Greg
I pulled four 27C040 EPROMs from a phone system last week. These seem to be 512k... now I just need a burner (and to blank them)... and the 512k cart.
  • 2 weeks later...
Greg
Turns out it was my old burner.. as the new usb minipro i got works fine :)
  • 2 weeks later...
Has there been any progress on building the 512K Educational cart image? I suspect many of the reading ones won't work, just because they used too many GROMs. Most of the math carts should though. . .
I've actually been working on this for the last couple of hours. Everything is working except Early Learning Fun, and that's got me stumped. If I can't figure it out I might just take it off the menu.
Gazoo
I found a small bug in the Educational Cart Rom. When fctn9 was pressed from the menu to quit, it didn't reset the correct Rom bank and the menu selection would disappear until the console was power cycled. That has been corrected and the file has been replaced in the original message. Go up ^ 4 messages to the original message.
Sorry for the inconvenience.
Gazoo
