+9640News Posted July 9, 2020 Share Posted July 9, 2020 1 hour ago, Asmusr said: Here is a a crash course on the debugger. It's quite simple, but it has been good enough for developing several games. Only one breakpoint (CPU, or F18A GPU) is possible To set a breakpoint, enter hex value in the Breakpoint box, or click Stop and then click the left side of the disassembly list to toggle a breakpoint at that address Click Step to single-step Click Start to run to your breakpoint Shift-click Step to run to two words after the current PC. If the current instruction is a branch this is effectively a Step Over Enter hex address of view address in the View Address box The memory split view allows you to view a disassembly of your program together with a selected memory region Note that unlike Classic99, the disassembly is a view of the current memory and not a history of executed instructions. This means you can 'disassemble' data and possibly get offset from your program's instructions The Graphics tab may be useful for inspecting tiles and sprites Classic99 has a far more powerful debugger, and I use it once in a while when I need to do something special like break on memory access or count memory cycles. Thanks for the crash crash course. When I get to the area of concern, I will end up doing a single step as I will want to flip between viewing some VDP contents as well as what then gets copied into CPU from VDP. Somewhere, something isn't playing nice. Beery Quote Link to comment Share on other sites More sharing options...
globeron Posted August 15, 2020 Share Posted August 15, 2020 On 5/11/2014 at 3:30 PM, Asmusr said: I have added a couple of new features (web site? - Mouse support: If you click on a screen character it will simulate a key press of the corresponding key. Great for navigating though menus. - Save/Load buttons: For saving or restoring the state of the 3 disks to persistent storage in you browser (nothing will be sent to the server). Only available in browsers that support IndexedDB (e.g. Chrome and Firefox). This is currently rather primitive. The plan, as you may have noticed, is to include a disk manager that allows you to maintain a library of disks and choose which disks to insert into which drives. Attached is a copy of the the latest full source code for local use. Note that for local use in Chrome you have to run with the --allow-file-access-from-files option. For Ciro and others who want to embed the emulator in your web sites, I have included a file minimal.html that demonstrates how to bring up the core emulator in a canvas without the user interface. This example is using the included parsec.json module file. To create your own modules in json format use the attached rpk2json tool. js99er-1.4.zip 863.56 kB · 25 downloads rpk2json.zip 9.63 kB · 16 downloads I was thinking to setup a small competition with my colleagues on "Munch Man", but they do not have a TI and setup this page: http://www.globeron.com/ti99/munchman.html (as a side note, I never figured out how to integrate a list of cartridges to select from, now I convert it json and that's the only cartridge I can load and if I want another one, I need to adjust the js99er.js and .html with the other converted cartridge). But I see now the following (PS. @Asmusr I am not expecting you to troubleshoot, keep focusing on the important stuff) Just wondering why there is a difference. Apple MacBook Pro: * Chrome - seems to be working okay, but I do not have sound * Safari - seems to be working, no sound Windows 10: * Edge - works + sound * Firefox - works + sound (but they layout is a bit off) * Chrome - works, but again no sound * Internet Explorer - very slow, not playable actually 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted August 15, 2020 Author Share Posted August 15, 2020 It looks like you're using the first generation of the emulator, and maybe an old version of that, because the sound issue was fixed in one of the last versions. You have to call a function (AudioContext.resume()) from a handler triggered by the user. That way browsers prevent websites from making sounds without the user's approval. Internet Explorer has never been supported. Couldn't you just use https://js99er.net/#/cart/munchman for the compo? 2 Quote Link to comment Share on other sites More sharing options...
globeron Posted August 16, 2020 Share Posted August 16, 2020 21 hours ago, Asmusr said: It looks like you're using the first generation of the emulator, and maybe an old version of that, because the sound issue was fixed in one of the last versions. You have to call a function (AudioContext.resume()) from a handler triggered by the user. That way browsers prevent websites from making sounds without the user's approval. Internet Explorer has never been supported. Couldn't you just use https://js99er.net/#/cart/munchman for the compo? I am trying to make a userfriendly user interface (non-technical) and how to press the keys when REDO and BACK appears and the settings (and also a fullcreen mode) and a fullscreen.html mode (but i remember you had last time this html). Thanks for the url. I never figured out how to load a module directly, i will try that. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted August 16, 2020 Share Posted August 16, 2020 51 minutes ago, globeron said: I am trying to make a userfriendly user interface (non-technical) and how to press the keys when REDO and BACK appears and the settings (and also a fullcreen mode) and a fullscreen.html mode (but i remember you had last time this html). Thanks for the url. I never figured out how to load a module directly, i will try that. Globeron, have you also seen the GameRoom here? http://www.ti99iuc.it/web/index.php?pageid=165&pagina=sala_giochi&sezione=5 you can click on a game and play in a frame or just a mouse right click to open the game in another window in full screen. I do not know if it can help. Always thanks Rasmus for this nice emulator Quote Link to comment Share on other sites More sharing options...
globeron Posted August 16, 2020 Share Posted August 16, 2020 Globeron, have you also seen the GameRoom here? http://www.ti99iuc.it/web/index.php?pageid=165&pagina=sala_giochi&sezione=5 you can click on a game and play in a frame or just a mouse right click to open the game in another window in full screen. I do not know if it can help. Always thanks Rasmus for this nice emulator [emoji4] Nice, I know your game shelf, let me test this tomorrow.Is there a direct link to munch man only?Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
globeron Posted August 18, 2020 Share Posted August 18, 2020 On 8/17/2020 at 12:10 AM, globeron said: Nice, I know your game shelf, let me test this tomorrow. Is there a direct link to munch man only? Sent from my iPad using Tapatalk Hi @ti99iuc / Ciro - the interface looks good, but it is the same issue with the sound (i do not hear anything) @Asmusr in js99er the sound works! (I need some more time to analyse it), will try tonight. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted August 18, 2020 Author Share Posted August 18, 2020 You can also manually enable sound for a website. In Chrome, for instance, by clicking the Info or Padlock icon next to the URL and choosing Site Settings. 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted August 18, 2020 Share Posted August 18, 2020 On 8/16/2020 at 7:10 PM, globeron said: Is there a direct link to munch man only? It seems not directly because the rules setted to the website it will open the Main GameRoom page. 8 hours ago, globeron said: Hi @ti99iuc / Ciro - the interface looks good, but it is the same issue with the sound (i do not hear anything) as the sound yes you should active it by your browser, for example Chrome have it here Quote Link to comment Share on other sites More sharing options...
globeron Posted August 18, 2020 Share Posted August 18, 2020 9 hours ago, Asmusr said: You can also manually enable sound for a website. In Chrome, for instance, by clicking the Info or Padlock icon next to the URL and choosing Site Settings. Same for normal chrome and incognito. (And also tried the settings to allow the site). Weird...it must be the browser with some new features? 20200818_201112.mp4 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 31, 2020 Share Posted October 31, 2020 noted in today's zoom meeting that rxb2015 doesn't load properly in js99er If I load cart and select the G file, does that load the C and D files also? it just shows Load module I see if I zip up the files and load it it shows Load module RXBC.Bin RXBD.Bin RXBG.BinRXB CLASSIC99.zip anyway it won't run RXB after it loads just flashes the screen colors 2 Quote Link to comment Share on other sites More sharing options...
DavidC Posted October 31, 2020 Share Posted October 31, 2020 RXB works ok for me on JS99er..unless I am missing something and don't know what I am talking about.. 2 Quote Link to comment Share on other sites More sharing options...
DavidC Posted October 31, 2020 Share Posted October 31, 2020 ...I Just noticed 2.8 GEM was added to the software list. Very Cool! 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 31, 2020 Share Posted October 31, 2020 2 minutes ago, DavidC said: RXB works ok for me on JS99er..unless I am missing something and don't know what I am talking about.. what version? I am seeing different log messages with Version 8.3.2 - 24 October, 2020. 1 Quote Link to comment Share on other sites More sharing options...
DavidC Posted October 31, 2020 Share Posted October 31, 2020 Quote Link to comment Share on other sites More sharing options...
DavidC Posted October 31, 2020 Share Posted October 31, 2020 Software>APPS>RXB 2015 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 31, 2020 Share Posted October 31, 2020 Just now, DavidC said: ahh its in the apps list separate if you search for RXB it doesn't come up with the 2015 list.. thanks! It works that way my problem still exists for loading a cart image that's got more than one grom or rom.. 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted October 31, 2020 Author Share Posted October 31, 2020 (edited) 2 hours ago, arcadeshopper said: noted in today's zoom meeting that rxb2015 doesn't load properly in js99er If I load cart and select the G file, does that load the C and D files also? it just shows Load module I see if I zip up the files and load it it shows Load module RXBC.Bin RXBD.Bin RXBG.BinRXB CLASSIC99.zip anyway it won't run RXB after it loads just flashes the screen colors A browser cannot load any files from you local drive without the explicit consent of the user. So either you have to use the version of RXB under Software/Apps or you have to use an rpk version. That's why rpk is the superior format. If we could agree on zipped files with the naming convention that would also be fine. Edited October 31, 2020 by Asmusr Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 31, 2020 Share Posted October 31, 2020 Ok thanks! I'll try an rpk and report back.Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 4, 2021 Share Posted January 4, 2021 at least for me, it looks like the websocket for tipi emu is not working in 8.3.4 nevermind it was Brave blocking the websocket Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 4, 2021 Share Posted January 4, 2021 On 10/31/2020 at 4:05 PM, arcadeshopper said: Ok thanks! I'll try an rpk and report back. Sent from my LM-V600 using Tapatalk this worked btw Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted May 16, 2021 Share Posted May 16, 2021 Do not miss it ? ? ? ? https://atariage.com/forums/topic/218727-ti-99-photos-thread-post-your-systems-here/?do=findComment&comment=4824302 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted July 10, 2021 Share Posted July 10, 2021 Edit: disregard. The problem was not with js99er nor the routine. When I inspected the GPU memory location at 0x3606, I found garbage in place of my routine. I was using Ti99dir to copy the FIAD program files generated by xdt99 into a disk image, and it seems that one must refresh the source window before each copy operation. I'll share with the author after I do some more testing to rule out my files. I have been trying to test some F18A-related code in JS99er. The GPU is triggered by writing the GPU PC address of >3606 to VR36 and VR37, which then jumps to the routine in the spoiler tags. It is a simple routine to clear the screen and set the text mode attribute. I am using the enhanced mode in 80 column x 30 row text mode. Js99er tells me the GPU is triggered, stopped, and then the F18A is locked. (On real hardware the GPU stays unlocked and has worked for me in the past since I wrote this in ~2017, so I'm hoping there is a simple answer and that maybe along the way I missed a critical register setup? If not, then maybe my GPU code is triggering the lock somehow? I've reviewed the F18a register .ods file but nothing stands out to me). Here is the js99er log: Text 80 mode selected F18A unlocked Text 80 mode selected (2) 30 rows mode enabled. F18A Enhanced Color Mode 0 selected for tiles. F18A Enhanced Color Mode 0 selected for sprites. F18A GPU triggered at >3606 F18A GPU stopped. F18A locked ; code enters at 3606 NTBA EQU >6002 name table CTBA EQU >6003 color table DMA_SRC EQU >8000 DMA_DST EQU >8002 DMA_W EQU >8004 DMA_H EQU >8005 DMA_STRIDE EQU >8006 DMA_CMD EQU >8007 DMA_TRIG EQU >8008 GPUCLR CLR R1 MOVB @NTBA,R1 SLA R1,2 AI R1,80 skip status line LI R2,2000 LI R3,>2020 spaces CLR1 MOVB R3,*R1+ DEC R2 JNE CLR1 CLR R1 MOVB @CTBA,R1 SRL R1,2 AI R1,80 LI R2,2000 MOVB @>3602,R3 attribute passed by caller CLR2 MOVB R3,*R1+ DEC R2 JNE CLR2 CLR @>3600 ; flag for f18a (based on Tursi's detection) IDLE 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 24, 2021 Share Posted October 24, 2021 I can't seem to get CTRL-M to register with a CALL KEY in XB. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted October 25, 2021 Author Share Posted October 25, 2021 8 hours ago, Vorticon said: I can't seem to get CTRL-M to register with a CALL KEY in XB. You need to provide some code to reproduce the issue. Quote Link to comment Share on other sites More sharing options...
