Classic 99 User Cartridges
Shift838
Use the assembler that comes with Win994A. It can output a binary file which can be used as the cartridge file. You can then open that file in classic 99 (just browser to it). Cartridges need a header in order for the system to see the cart and present it on the cart select screen.
See http://turboforth.net/source/Bank0/0-00-Header.html
Does it output to one binary file or will it chunk it up?
It ouputs to one binary file. You need to split it into relevant chunks for the binaries. @Willsy has a small program that does it by outputting serialized BIN files every time the memory counter goes backwards. I do not know who wrote it, so I will let him (or whoever wrote it) post it.
...lee
I have picked up a couple of UberGrom cart boards and have been told that it should be able to take RXB 2012. (If I can figure out how to get it on there correctly). I was wondering if Tony Knerr's XB 2.5 could be loaded on a cart like this.
Yep, and a lot more, look at this topic.
http://atariage.com/forums/topic/223979-setting-up-a-632k-cart/
Gazoo
...lee
It was Tursi wot wrote it back in 2009 I believe!
I can post it here if needed. Lee, I assume I already furnished you with it?
